dlm46007(at)cox.net Guest
Posted: Fri Jun 20, 2008 8:38 pm Post subject: alternator belt |
What is the alternator belt for the IO540; seems like there was a Gates number?
Deems Davis
Posted: Fri Jun 20, 2008 9:39 pm Post subject: alternator belt |
David, the belt that came w/ my B&C alternator is marked : 7365 GATES
XL 110925
Deems
David McNeill wrote:
| Quote: | What is the alternator belt for the IO540; seems like there was a
Gates number?
acs(at)acspropeller.com.a Guest
Posted: Tue Jun 24, 2008 2:23 pm Post subject: Alternator belt |
Anyone know the actual length of the alternator belt to suit the standard alternator as supplied by Vans?
I was supplied a standard belt at 37.6” (Korean made 37A19773-376) but I’m guessing the maximum I can use is around 32-33’’?
I know this was mentioned recently as a Gates number 7365 XL110925 but when I mention these numbers around here I get blank looks.
Do these numbers somehow equate to the length of belt?
Any clues appreciated
John 40315
drfred(at)suddenlinkmail. Guest
Posted: Tue Jun 24, 2008 2:53 pm Post subject: Alternator belt |
John;
Don't know if it helps but the number on my alt belt is a "bando rpf"
2355 9.5 x 900 La
I measured the circumference and got 35 and 3/4 inches. I have a plane
power alternator and the bolt is about 1/2 way.
Fred.
John Dunne wrote:
John 40315
Posted: Tue Jun 24, 2008 3:04 pm Post subject: Alternator belt |
Thanks Fred, I'm gathering that the 2355 number represents 35.5" approx and
therefore maybe the Gates number 7365 is 36.5".
These would still be too big as my bolt is at its maximum and I reckon the
distance around is closer to 32.5" The ring gear is a 10" standard as far as
I can tell.
John
[mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Fred Williams,
M.D.
Sent: Wednesday, 25 June 2008 8:53 AM
Subject: Re: Alternator belt
<drfred(at)suddenlinkmail.com>
John;
2355 9.5 x 900 La
Fred.
John Dunne wrote:
I was supplied a standard belt at 37.6" (Korean made 37A19773-376) but
I'm guessing the maximum I can use is around 32-33''?
John 40315
Jim Berry
Posted: Tue Jun 24, 2008 6:09 pm Post subject: Re: alternator belt |
My Plane Power install instructions call for 15355 Dayco or 7355XL Gates.
Jim Berry
40482
wvu(at)ameritel.net Guest
Posted: Tue Jun 24, 2008 6:48 pm Post subject: Alternator belt |
Mine is a Gates 7312 which was bought at NAPA.
Anh
N591VU-flying
and
as
I can tell.
John
M.D.
John;
2355 9.5 x 900 La
Fred.
> John 40315
Bill Schlatterer
Posted: Fri Jun 27, 2008 7:20 pm Post subject: Alternator belt |
Any reputable auto parts store will sell Gates Belts or can interchange the part number. Gates is a first choice in the parts business. Specs on the 7365 at
http://www.gatespowerpro.com/Comergent/en/US/adirect/gates?cmd=catProductDetail
Hope this helps!
Bill S
7a Ark
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Dunne
Sent: Tuesday, June 24, 2008 5:21 PM
Subject: Alternator belt
John 40315
