Mike Whisky
Posted: Sun Jun 22, 2008 1:50 pm Post subject: How to fasten this exhaust nut? |
Hello There,
it looks as if this hole was drilled too close the exhaust pipe. I can not reach it with a ratchet nut or an jaw wrench. Any idea ho tow to go about it in order to achieve the requested torque (140)
Michael
839.19 KB |
491 Time(s) |
_________________ RV-10 builder (flying)
#511 |
VHMUM(at)bigpond.com Guest
Posted: Sun Jun 22, 2008 2:11 pm Post subject: How to fasten this exhaust nut? |
1/4 inch drive with extention. I had the same and with the thinner socket i
was anle to do it
Chris
AV8ORJWC
Posted: Sun Jun 22, 2008 2:27 pm Post subject: How to fasten this exhaust nut? |
Wow! Challenging picture:
Four ideas. 1)A 1/4" drive "thinwall" deep socket on an extension. 2)A
Torque Adapter(Snap-On makes them). Or 3)a sacrificial crows foot -
modified with your die-grinder and 4)remove the studs and use Hex driven
bolts into the head. Automotive racing headers use the Hex ones all the
time for such close interference.
Note: I have always found value in using S.Steel exhaust nuts as once
regular nuts corrode, the removal technique down the road is 3X as
challenging for non S.S. This nut and the related internal star washer
appear 'standard cadmium' plated.
John Cox
#600
bcondrey
Posted: Sun Jun 22, 2008 2:32 pm Post subject: Re: How to fasten this exhaust nut? |
1/4" drive "wobble sockets" work great too. I've found them locally at Sears.
Kelly McMullen
Posted: Sun Jun 22, 2008 4:16 pm Post subject: How to fasten this exhaust nut? |
#1 or # 2. Loosen the nut just enough to be able to move the pipe a
little. Place socket on each nut to ensure the pipe is centered
between the studs.
Every Lycoming exhaust port is just like this.
John Cox
#600
A&P/IA, EAA Tech Counselor
KCHD |
Kelly McMullen
Posted: Sun Jun 22, 2008 4:28 pm Post subject: How to fasten this exhaust nut? |
Forgot to mention...my Mooney calls for an AN-310-3 nut there. Key is
to replace those nuts every few hundred hours, as soon as they show
any signs of corrosion.
On Sun, Jun 22, 2008 at 5:11 PM, Kelly McMullen <apilot2(at)gmail.com> wrote:
[quote] #1 or # 2. Loosen the nut just enough to be able to move the pipe a
between the studs.
> John Cox
> #600
KCHD |
Posted: Sun Jun 22, 2008 5:10 pm Post subject: How to fasten this exhaust nut? |
John Cox wrote:
snip
| Quote: | Note: I have always found value in using S.Steel exhaust nuts as once
Brass nuts also work well without 'bonding' to the stud.
Linn
[quote] John Cox
#600
Mike Whisky
jcumins(at)jcis.net Guest
Posted: Mon Jun 23, 2008 1:26 pm Post subject: How to fasten this exhaust nut? |
Take a very old socket that size and start grinding it down to size to make
it fit then you will always have the socket that will fit.
I have a tool box full of modified tools.
John G. Cumins
President
JC'S Interactive Systems
2499 B1 Martin Rd
Fairfield Ca 94533
707-425-7100
707-425-7576 Fax
Your Total Technology Solution Provider
