blast tubes
dlm46007(at)cox.net
PostPosted: Mon Jun 23, 2008 5:10 am    Post subject: blast tubes Reply with quote
Has anyone installed blast tubes to cool magnetoes or the cool cabin heat valve on the firewall?
ricksked(at)embarqmail.co
PostPosted: Mon Jun 23, 2008 12:09 pm    Post subject: blast tubes Reply with quote
David,
I installed them on the mags and fuel pump, although not flying. I used 1"spun aluminum flanges from ACS. I used safety wired embedded in silicone to keep them at the correct shape and zip ties to secure them to the nearest location at each component
Rick Sked
40185
Tim Olson
PostPosted: Mon Jun 23, 2008 6:23 pm    Post subject: blast tubes Reply with quote
Yes, I have a tube on the magneto, and a larger one on the cabin
heat valves. I'm also planning to eventually add a cooling
shroud to the mechanical fuel pump on the engine, and put a
scat tube into that one as well. Just need to get a good deal
on the shroud.
msausen
PostPosted: Tue Jun 24, 2008 10:02 am    Post subject: blast tubes Reply with quote
Here is a shroud and/or a complete kit.
http://www.glasairaviation.com/options/glasairoptfire.html#fuelpump
Michael
