Spar Cap Extrusion...
SafeAirOne
PostPosted: Sat Jun 21, 2008 5:53 am    Post subject: Spar Cap Extrusion... Reply with quote
I am still preparing to pull my first rivet on a plans-built 701. I have found a reasonably-priced local source for the aluminum sheet and extrusions (Yarde Metals). They have a good selection of 6061 T6 including both square-corner (AA) and radiused corner (AS) angle.
I think I was reading in some European Government document regarding 701 certification, that they required the spar cap angles to be the type with a radiused inside corner.
Is one better than the other? The price is about the same, I'm sure, but is one profile better than the other structurally?
--Mark
larry(at)macsmachine.com
PostPosted: Sat Jun 21, 2008 6:43 am    Post subject: Spar Cap Extrusion... Reply with quote
Hi Mark,
The inside corner would convey stresses better than a sharp inside
corner, but I've never seen 6061-t6 made that way.
If it were available, I'd make a point of obtaining and using it in lieu
of the sharp corner angle to avoid the potential of a stress
fracture.
I think I was reading in some European Government documment regarding 701 certification, that they required the spar cap angles to be the type with a radiused inside corner.
--Mark
http://forums.matronics.com/viewtopic.php?p=188885#188885
randy(at)rjhebertassoc.co
PostPosted: Sat Jun 21, 2008 11:46 am    Post subject: Spar Cap Extrusion... Reply with quote
Mark
I don't know if one is better than the other but consider this
The radiused corner has LESS cross sectional area
I personally do not see a difference.
The material I got was 0.125 at a local aluminum supplier and it has
the rounded corner. The 093 as I understand it is a special run that
ZAC supplies.
Randall J Hebert
Randall J Hebert & Associates, Inc
Consulting Civil / Structural Engineers
Lafayette, Louisiana
PH 337-261-1976 - FX 337-261-1977
dan(at)hillsgun.com
PostPosted: Sat Jun 21, 2008 12:34 pm    Post subject: Spar Cap Extrusion... Reply with quote
I also got my .125 extrusion locally and it has the squared inside corner.
When I looked at the construction cd in the flaperon skeleton, section 1,
page 3 it shows a picture of the hinge bracket in the margin that clearly
shows the extrusion with a square corner so I am confidant that it will be
ok. Dan.
SafeAirOne
PostPosted: Sat Jun 21, 2008 2:55 pm    Post subject: Re: Spar Cap Extrusion... Reply with quote
[quote="randy(at)rjhebertassoc.co"]
The radiused corner has LESS cross sectional area[quote]
Thanks for everyone's help. I wish I could post a picture of the 2 profiles, but the catalog is in PDF format (all 493 pages of it).
Hmm...Just looking at the cross section images in the Yarde Metals catalog, it SEEMS like the angle with the radiused inside corner has the same cross section as the sharp cornered ones with a fillet ADDED to the inside corner.
However, unlike the squared angle, the ends of the rdiused angle's legs are also rounded down, so it may be possible that the overall cross section is less than the squared angle.
I don't think it'll matter a whole lot--the .125 thickness is already more than the plans call for the radiused inside corner will just be a bonus, I guess!
craig(at)craigandjean.com
PostPosted: Sat Jun 21, 2008 7:16 pm    Post subject: Spar Cap Extrusion... Reply with quote
format
You can grab anything even from protected PDF documents. The "Print Screen"
key on your keyboard (or "PrtSc") copies the entire screen to the clipboard.
Print-screen combined with the Alt key only snaps the currently selected
window. Then open your favorite paint or photo editing program and paste the
clipboard into a blank document. It will be a large image so crop it to the
interesting portion.
-- Craig
SafeAirOne
PostPosted: Sun Jun 22, 2008 4:13 am    Post subject: Re: Spar Cap Extrusion... Reply with quote
Thanks!
...Here are the profiles of the angles to which I refer:
 Filesize:  4.39 KB
 Viewed:  28952 Time(s)
dougsnash
PostPosted: Sun Jun 22, 2008 5:11 am    Post subject: Spar Cap Extrusion... Reply with quote
Go with the one on the left.
Doug MacDonald
CH-701 Scratch Builder
NW Ontario, Canada
--- SafeAirOne <safeairone(at)verizon.net> wrote:
"SafeAirOne" <safeairone(at)verizon.net>
Thanks!
refer:
http://forums.matronics.com//files/angles_438.jpg
ricklach
PostPosted: Sun Jun 22, 2008 6:25 am    Post subject: Re: Spar Cap Extrusion... Reply with quote
Could any one take a look at their factory kit and clarify exactly what Zenith is supplying in the factory kits.
Rick
bobefx(at)yahoo.com
PostPosted: Mon Jun 23, 2008 5:36 am    Post subject: Spar Cap Extrusion... Reply with quote
The square one is called architectural extrusion, and the round web is called structural aluminum. The structural is just that, structural. The architectural is not as strong and us used for architectural, or decoration, windows, trim, etc. the square inside allows it to be used on outside corners, as a slider, and where ever a square corner is needed. The web of the structural gives it more strength.
Bobefx
PostPosted: Mon Jun 23, 2008 5:43 am    Post subject: Spar Cap Extrusion... Reply with quote
If they are both 6061-T6, they are both the same strength.
The difference in geometric properties has very little effect in overall strength.
I treat them the same structurally.
As you said, however, they are used in different applications.
Randall J Hebert
From: owner-zenith701801-list-server(at)matronics.com [mailto:owner-zenith701801-list-server(at)matronics.com] On Behalf Of Bob Sturgis
Sent: Monday, June 23, 2008 8:36 AM
To: zenith701801-list(at)matronics.com
Subject: Re: Re: Spar Cap Extrusion...
Bobefx
----- Original Message ----
Sent: Sunday, June 22, 2008 5:13:57 AM
Subject: Re: Spar Cap Extrusion...
--> Zenith701801-List message posted by: "SafeAirOne" <safeairone(at)verizon.net (safeairone(at)verizon.net)>
Thanks!
http://forums.matronics.com/viewtopic.php?p=189023#189023
available via the
href='3D"http://forums.matronics.com"'>http://forums.matronics.com
generous support!
href='3D"http://www.matronics.com/contribution"'>http://www.matronics.com/contribution
[/b][quote][b]
bobefx(at)yahoo.com
PostPosted: Mon Jun 23, 2008 6:32 am    Post subject: Spar Cap Extrusion... Reply with quote
Randall,
Put them in a vice and twist them, pound them, and the architectural will fail long before the structural. Them tell me they are the same. We use a lot of aluminum in the motion picture industry to build props, and some time a persons life depends on what we build. I would never use architectural aluminum any case. The web on the structural is much better than the square inside corner of the architectural. That is where the strength is.
The reason one is called structural and the other is called architectural, is that they do not want you to use architectural for structural purposes, it will fail.
By studio regulations we have all of our designs checked out by a structural engineer and they never approve the use of architectural aluminum in structures.
Bobefx
ricklach
PostPosted: Tue Jun 24, 2008 6:15 am    Post subject: Re: Spar Cap Extrusion... Reply with quote
This is a very interesting conversation, but what is the factory providing? The factory is the decider. Can some one please take a look at their kit and provide that very important piece of information to us. I would if I had a kit but I do not.
Rick
dan(at)hillsgun.com
PostPosted: Tue Jun 24, 2008 6:54 am    Post subject: Spar Cap Extrusion... Reply with quote
Hi Rick: See my post from Yesterday. I talked to Zenith Yesterday and they
are providing .093 thickness with square inside corner, Dan.
PostPosted: Tue Jun 24, 2008 11:52 am    Post subject: Spar Cap Extrusion... Reply with quote
Rick,
1 x 1 x 1/8th extruded structural aluminum angle, 6061-t6, with a proper
radius is available from Aircraft Spruce as p/n 03-48000. If the
dimensions suit you, or if you need something that can be resized, the
prices quoted are reasonable (if Zenith is not providing the angle with
the radius).
Rick
http://forums.matronics.com/viewtopic.php?p=189553#189553
ricklach
PostPosted: Tue Jun 24, 2008 3:12 pm    Post subject: Re: Spar Cap Extrusion... Reply with quote
Thank You both Dan and Larry for your information.
Rick
SafeAirOne
PostPosted: Wed Jun 25, 2008 8:07 am    Post subject: Re: Spar Cap Extrusion... Reply with quote
larry(at)macsmachine.com wrote:
Rick,
Careful, the plans (for the 701, at least) call for 3/4 x 3/4 angle. Using 1 x 1 would likely create clearance issues with the rear ribs.
--Mark
