dhkey(at)msn.com Guest
Posted: Wed Jun 18, 2008 4:57 pm Post subject: Un-gusts |
Here are some phrases and terms I haven't figured out yet but I don’t need an explanation to. What is concerning is that I've seen them applied to accident scenarios on this list.
<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" />
"kolb drop", "the air went away", and "un-gusts"
I know being a pilot has the built in responsibility of always learning but in these cases I think it could work against you. Un-Gusts LOL!! I'm still cracking up. What's next, un-lift, my plane hit some un-lift and well as you can understand I was screwed. At some point someone has to call fiction fiction and made up made up and bull bull. If it's only to maintain some kind of integrity to this list, the phrases and terms used for years and to prevent new pilots from a total state of confusion. You know there is someone out there thinking “kolb-drop”, “un-gusts” I don’t understand this… (and you shouldn’t)
Have you ever heard this… "the forecast calls for ceilings two thousand broken and winds 180 (at) 16 un-gusts to 21" of course you haven’t and you won’t. Have you ever heard the tower say “use caution we’ve had reports of un-gusts 2 miles off of 18…” me neither and I won’t. Have you ever read in an FAA accident report that the plane went down due to un-gusts? Well your not going to.
But you don’t have to believe me, call a briefer and tell them you were concerned about un-gusts along your route and ask him if he can recommend a alternate route around the un-gusts. Then ponder this answer, “well it’s defiantly gustier to the North so I’d say you should go there I expect much less un-gusting there.”
The weather was pleasant in Texas today there were un-tornados, un-rain and un-wind all day long, un-fortunately it was very un-cold.
Would there be un-gusts if there weren’t gusts and there wasn’t someone there to fly in it?
[quote] Date: Wed, 18 Jun 2008 19:24:23 -0400
Subject: RE: William Sullivans Accident
At 06:46 PM 6/18/2008, David Key wrote:
| Quote: | | I thought I'd heard everything now I'm hearing about un-gusts? LOL!! |
What's so funny? Sailors have spoken of "non puffs" for years. It's a sudden, brief, lull in an otherwise steady wind.
-Dana
Please let me know if you did not receive this. | Quote: |
get=_blank>http://www.matronics.com/Navigator?Kolb-List
p://forums.matronics.com
blank>http://www.matronics.com/contribution
| [b]
russ(at)rkiphoto.com Guest
Posted: Wed Jun 18, 2008 5:26 pm Post subject: Un-gusts |
This is just semantics! -- we all know what they mean by an "un-gust" (though I'd never heard it before). If it confuses a new pilot, he needs more instruction.Okay, better to say "the gust stopped", or "quit", but we all know what was meant.do not archive
On Jun 18, 2008, at 8:55 PM, David Key wrote:
| Quote: | Here are some phrases and terms I haven't figured out yet but I don’t need an explanation to. What is concerning is that I've seen them applied to accident scenarios on this list.
| Quote: | Date: Wed, 18 Jun 2008 19:24:23 -0400
From: d-m-hague(at)comcast.net (d-m-hague(at)comcast.net)
-Dana
Please let me know if you did not receive this.http://www.matronics.com/Navigator?Kolb-List
Dana
Posted: Wed Jun 18, 2008 5:49 pm Post subject: Un-gusts |
At 08:55 PM 6/18/2008, David Key wrote:
| Quote: | | ...Un-Gusts LOL!! I'm still cracking up.... |
OK, fine. "The airplane was flying just above stall speed when a brief lull in the otherwise steady wind put him below stall speed..." Simpler to call it, as sailors do, a "non puff" (as opposed to a puff). I called it an un gust because fliers don't use the term "puff" much. Doesn't matter what you call it, the phenomenon is real.
-Dana
When you get it right
mighty beasts float up into the sky
When you get it wrong
people die
-Roger Bacon (c1384) [quote][b]
Posted: Wed Jun 18, 2008 6:05 pm Post subject: Un-gusts |
I think the term is "wind shear".
Rick Neilsen
Redrive VW powered MKIIIC
Dana
Posted: Wed Jun 18, 2008 6:34 pm Post subject: Un-gusts |
At 10:02 PM 6/18/2008, Richard & Martha Neilsen wrote:
| Quote: | | I think the term is "wind shear". |
I suppose that could apply, but I always thought of wind shear as applying when an aircraft flew from a mass of air steadily moving at one velocity to another steadily moving at another velocity, whereas an un-gust (or gust) is more a transient bit of turbulence moving along with the wind, such that it temporarily cancels (or reinforces) the mainstream wind. Put another way, a gust can be either positive or negative (or sideways, a sudden brief wind shift).
I suppose I should've said "lull" instead... but I think of a "non puff" (or "un gust") as a particularly short and sharp edged lull.
-Dana
Press any key... no, no, no, NOT THAT ONE! [quote][b]
Possums
Posted: Wed Jun 18, 2008 7:56 pm Post subject: Un-gusts |
I have to land on this postage stamp every time I fly (at least
1,400 landings here - so far).
Only one way out and in. (Always land up hill) and we got trees at
the north end anyway.
I learned a long time ago that if I have a 10 mph headwind while landing, I add
10 mph to the landing speed because it's going to "ungust" or quit
when I get below
the trees. BUT I hate the south/tail winds the most. You still have
to add speed to the
landing so you don't have loose controls (that adds 10 mph for the
wind & 10 mph for
what you added - VGs are nice) . We are not allowed a "bounce" with
downwind landings.
These Kolbs are like a horse, you've got to have enough wind going
over the surfaces to make
it do what you want it to do. If you want that left wing up, you
better have wind going over it
to make it do what you want it to do. Called "Horsing it in".
http://video.google.com/videoplay?docid 63159682459782825&hl=en
60.64 KB |
392 Time(s) |
_________________ Possum |
David Lucas
Joined: 10 Jan 2006 Posts: 79 Location: Europe. based Amsterdam NL
Posted: Thu Jun 19, 2008 1:08 am Post subject: Re: Un-gusts |
Reminds me of a story of a young WWI pilot who crashed his Bi-Plane on Take-Off. The ensuing 'Inquiry' found him guilty of poor technique and both grounded and demoted him. His appeal's to his superiors established a review committee that quashed the initial finding and instead attributed the accident to attempting a take off in meteorological conditions when there was no 'lift' in the air. His demotion was canceled and he was restored to flying status forthwith.
The review committee also took the opportunity of congratulating the pilot on the occasion of his engagement to the commanders daughter.
(Nudge, nudge, wink, wink, say no more !)
David.
Posted: Thu Jun 19, 2008 5:32 am Post subject: Un-gusts |
Wind shear is quite different! But can also cause an unexpected drop in airspeeddo not archive
On Jun 18, 2008, at 10:02 PM, Richard & Martha Neilsen wrote:
[quote]I think the term is "wind shear".
Rick Neilsen
[quote]---
jlsk1(at)frontiernet.net Guest
Posted: Thu Jun 19, 2008 5:53 am Post subject: Un-gusts |
In 26 years of reading all sorts of magazines, catalogs, training materials, Practical Test Standards, Advisory Circulars, & Accident reports, I`m laughing at this term, un-gust, cuz I`ve never heard of it before.To me, un-gust is the equivalent of "Suck".
Jim "delete button" Kmet
Cookeville, TN
MK-3C
Kolbra
Posted: Thu Jun 19, 2008 6:08 am Post subject: Un-gusts |
Kolbers,
Here is the FAA's definition of wind shear:
http://www.alphatrainer.com/handouts/new%20learning/FAA-H-8083-25/pg_10-9.pdf
Glider pilots are very familiar with wind shear.
Google did not reveal a FAA definition of "un-gust" or "ungust"
Jack B. Hart FF004
Winchester, IN
lcottrell
Posted: Thu Jun 19, 2008 6:53 am Post subject: Un-gusts |
Jack B. Hart FF004
Winchester, IN
It is fairly obvious why you fellas are having trouble finding anything on
"Un-Gust". You are looking in the wrong part of the regs. You should look
under "D" for Dis-gust. That is what happens when you are flying into a
headwind that suddenly abandons you and leaves you hanging rather than
flying.
Larry C
Firestar II
409 hours
gaman(at)att.net Guest
Posted: Thu Jun 19, 2008 4:11 pm Post subject: Un-gusts |
Possum,
We could start a new thread here ( and leave William alone for a while) .I'll start it with; :you call that a postage stamp?I've seen aircraft carriers smaller than that!
Posted: Thu Jun 19, 2008 4:21 pm Post subject: Un-gusts |
Lar,
I'll buy your first book.Wish you were my neighbor
Do not archivre.
Possums
Posted: Thu Jun 19, 2008 8:04 pm Post subject: Un-gusts |
At 08:08 PM 6/19/2008, you wrote:
| Quote: | Possum,
Aaaah .......the luxury.
Having a carrier to land on,
no more down wind landings.
Something to dream about.
