Speed Brake Switch
jkhults(at)verizon.net
PostPosted: Sun Jun 15, 2008 10:04 am    Post subject: Speed Brake Switch Reply with quote
Bob & All,
I have a 4-way momentary "China hat" switch on my Infinity Aerospace throttle handle that I want to use for flaps (up & down) and speed brakes (fwd & aft). The Precise Flight speed brakes require an ON-OFF switch because once power is removed, they will close.
Let me preface my question with the fact the electricity is "not my area"! My question is how do I use the MOM switch to provide continuous voltage to the speed brake asymmetry module to keep them extended? Does it require a relay or some other electrical equipment? Or should I just use an ON-OFF switch somewhere else?
Jon Hults
Lancair Legacy
jskiba(at)icosa.net
PostPosted: Sun Jun 15, 2008 11:04 am    Post subject: Speed Brake Switch Reply with quote
How about a Flip Flop Circuit?
Something like:
http://ourworld.compuserve.com/homepages/Bill_Bowden/page9.htm
see the section for:
“CMOS Toggle Flip Flop Using Push Button”
You would have to build the circuit.
Hoe that helps
Jeff.
Sent: Sunday, June 15, 2008 1:00 PM
Subject: Speed Brake Switch
Bob & All,
Jon Hults
Lancair Legacy
[quote] [b]
bobf(at)feldtman.com
PostPosted: Sun Jun 15, 2008 12:54 pm    Post subject: Speed Brake Switch Reply with quote
aare the speed brakes on the wings? or on the fuselage (like a cozy or Long EZ)? If on the wings, you'd need to have huge concern about potential assymetric drag if one side has voltage failure and the other doesn't, could flip inverted if the drag was serious enough on the wing.
if it is non-asymmetric, then disregard the above safety concern..
bobf
On Sun, Jun 15, 2008 at 12:59 PM, Jon Hults <jkhults(at)verizon.net (jkhults(at)verizon.net)> wrote:
[quote] Bob & All,
Jon Hults
Lancair Legacy
Bob McC
PostPosted: Sun Jun 15, 2008 7:52 pm    Post subject: Speed Brake Switch Reply with quote
John;
Assuming you wish to use one momentary switch to turn "ON" the circuit and another (opposite side of the "China Hat") to turn "OFF" the circuit, two SPDT relays will do the trick. See attached word document. Please excuse the rudimentary sketch. The quadruple ovals represent the relay coils. The diode is to protect the switch from the load current. (assuming the list accepts the attachment)
Bob McC
Bi-stable_momentary_P-B_relay_circuit.doc
 Filename:  Bi-stable_momentary_P-B_relay_circuit.doc
 Filesize:  22.5 KB
 Downloaded:  348 Time(s)
Bob McC
Falco #908
(just starting)
mlas(at)cox.net
PostPosted: Mon Jun 16, 2008 6:48 am    Post subject: Speed Brake Switch Reply with quote
Jon,
With the Precise Flight speed brakes you have two switches. The first is the main power switch that provides power to the controller. The second switch is the control switch which controls the operation of the speed brake. The first switch is used for removing power from the system altogether. When power is removed the speed brakes go into failsafe which is a hard retract. The control switch works through the computer controller and controls the rate of extension and retraction while providing asymmetry protection during operation. Look at the schematic provided and put together list a of questions from that. The wiring that Precise provides is not very clear. The units were original designed for an engineered installation on certified aircraft and the drawings have not been updated for the typical homebuilt installation.
Here is the response from a post that I made down thread: I used a three position switch for the speed brakes on my Legacy. Center off, momentary on, switched on. That way you can have the best of both worlds. The one word of caution is to have a power switch separate from the control switch. Sometimes switches get hit on the stick unintentionally. You would not want the speed brakes to come out during take off and in my experience you wouldn’t notice right away.
Mike Larkin
Legacy dude
Speedy11(at)aol.com
PostPosted: Mon Jun 16, 2008 10:50 am    Post subject: Speed Brake Switch Reply with quote
John,
If you contact JD at Inifinity Aerospace he can tell you how to do it. I think he has an optional switch you could install in place of the original coolie hat switch that will do what you want.
Stan Sutterfield
Jon Hults
Lancair Legacy
Vote for your city's best dining and nightlife. City's Best 2008.
