temco(at)telusplanet.net Guest
Posted: Sat Jun 14, 2008 7:41 am Post subject: structural epoxy questions |
Jim
The glue that is supplied now is “Hysol 9460” and it comes in tubes that you can attach the missing nozzles to. John McBean at Kitfox has the glue and mixing nozzles. Give him a call and I’m sure he will get what ever you need off to you quickly.
Ted Palamarek
Edmonton Alberta
KF IV-912
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Jim_and_Lucy Chuk
Sent: June 14, 2008 8:39 AM
Subject: structeral epoxy questions
Hi all, I'm about to start working on my Kitfox 4 project wings and have some questions about the epoxy. I got 2 cans of each of the Scotch weld 2216 B/A adhesive, but they are as old as the kit (1994). I mixed some up and left it on a piece of plywood and stuck a 16 penny nail in it. When it harded, I tried to bend the nail out of it sideways, and all that happened was the nail bent. Even though it seems good, I suppose I should get new adhesive. Any thoughts on a good adhesive besides Scotch weld and any ideas on getting accurate mix ratios of the two parts of the glue would help me. I see some of these glues can be pumped through a small double caulk gun and it comes out mixed, anybody use that stuff? Thanks, Jim Chuk Avids, Kitfox 4
