rV-9A TOW BAR
payaremchuk(at)gmail.com
PostPosted: Fri Jun 13, 2008 8:11 am    Post subject: rV-9A TOW BAR Reply with quote
I am new to the list......
I've seen quite a few posts about tow/push bars, including plans to build.
Not having a welder, I'd like to know if anyone has taken a Cessna or
similar stock 'bar, and widened it an inch to clear the big wheel
pant, or otherwise modified it to fit the axle nuts etc.
I am doing my nose gear SB soon, so would like to do any other mods at
the same time.
thanks for any input
Perry
C-FINT RV-9/a in BC
mkejrj(at)comcast.net
PostPosted: Fri Jun 13, 2008 6:31 pm    Post subject: rV-9A TOW BAR Reply with quote
Perry,
I used a Bogart tow bar available from ACS for about $ 65.00 and sold specifically for RV's. I modified the bar's mechanism to better control the attaching function which would spring closed damaging the paint on the wheel pant. The mod consisted of replacing the stock mechanism with the largest turnbuckle available from Ace Hardware and Aviation Supply company attached with modified cap screws. See photo attachment. Good control and no more chipped paint.
Dick Jordan
RV 8A
es Nav
 Filesize:  701.65 KB
 Viewed:  530 Time(s)
