Tires
HawkerPilot2015
PostPosted: Wed Mar 01, 2006 5:51 am    Post subject: Tires Reply with quote
I need to put some new skins on my airplane and was looking for some input.
I know Desser supplies some but was curious what everyone else has done....
Thanks in advance!
Model Numbers and Prices would be helpful too. Quality is number one though...
DSAVARESE(at)elmore.rr.co
PostPosted: Wed Mar 01, 2006 6:04 am    Post subject: Tires Reply with quote
Tim, That is basically your only option unless you have Desser recap
your existing tires. Ski's are another option of course. Smile
Dennis
rkent(at)wlacrussianeng.c
PostPosted: Wed Mar 01, 2006 8:54 am    Post subject: Tires Reply with quote
Tim,
We regularly use the Aero Classic tires from Speciality tires of America for
the main wheels (500x150). We would use the 400x150 (nose) also if it were
not for the fact that they are only rated to 35psi and the Manuals say 3-3.5
bar (approx 50psi). Our local CAA won't accept them, even though we used
these tires for a number of years before we were forced to migrate to the
G-reg. We got pulled up about these on a Su-26 and had to change them, since
then we use Polish tires. These are purchased from a tire supplier n the UK
who import them and they are certainly not cheap.
Rob Kent
Stores Manager
WLAC - Russian Engineering
www.wlacrussianeng.co.uk
Tel: +44 1628 829 165
Fax: +44 1628 828 961
Of course if you want a set of ski's, I've got some here. Smile
Rob Kent
HawkerPilot2015
PostPosted: Wed Mar 01, 2006 9:01 am    Post subject: Re: Tires Reply with quote
A Yak-50 on skis??
How will that effect my climb performance?
viperdoc(at)mindspring.co
PostPosted: Wed Mar 01, 2006 10:03 am    Post subject: Tires Reply with quote
How does a fence affect your takeoff roll?
Doc
[Original Message]
To: <yak-list(at)matronics.com>
Date: 3/1/2006 11:13:34 AM
Subject: Re: Tires
A Yak-50 on skis??
http://forums.matronics.com/viewtopic.php?p=18761#18761
brian
PostPosted: Wed Mar 01, 2006 10:25 am    Post subject: Tires Reply with quote
Rate of climb is reduced as a function of the amount of fence remaining
attached to your skis.
Note: it is possible for rate-of-climb to be less than zero leading to
operation in an undesirable flight regime. Unwanted ground-contact is
possible in this flight configuration.
Brian Lloyd 361 Catterline Way
brian-yak at lloyd dot com Folsom, CA 95630
- Antoine de Saint-Exupery
Brian Lloyd
PostPosted: Thu Mar 02, 2006 5:11 am    Post subject: Tires Reply with quote
Sorry Tim,
I forgot you've got a 50. I've got a set of ski's for a Yk-52 here. No use
for them here in the UK. Anyone got any pics of a Yk-52 on ski's? I've only
ever seen a small pic. Can't see much from that.
Rob Kent
Stores Manager
anabar(at)ogmios.lt
PostPosted: Thu Mar 02, 2006 5:42 am    Post subject: Tires Reply with quote
Hi all,
Here is one picture of a Yak-52 on ski's.
Best regards,
Antanas
 Filesize:  37.27 KB
 Viewed:  502 Time(s)
