dlm46007(at)cox.net Guest
Posted: Wed Jun 11, 2008 6:39 pm Post subject: Emailing: sb08-6-1[1] |
This is what I found about an hour ago. Look at the end of the pdf.
 Download |
| Filename: |
sb08-6-1[1].pdf |
385.76 KB |
| Downloaded: |
711 Time(s) |
Dave(at)AirCraftersLLC.co Guest
Posted: Wed Jun 11, 2008 7:39 pm Post subject: Emailing: sb08-6-1[1] |
Well no wonder--it's the one with the Continental
Seriously, if that's what we're looking for, that area is visible through
the aft inspection plates.
Dave Saylor
AirCrafters LLC
140 Aviation Way
Watsonville, CA
831-722-9141
831-750-0284 CL
www.AirCraftersLLC.com
rv10(at)sinkrate.com Guest
Posted: Wed Jun 11, 2008 8:06 pm Post subject: Emailing: sb08-6-1[1] |
Oops forgot my name on the last one...
Ben Westfall
#40579
Posted: Wed Jun 11, 2008 8:33 pm Post subject: Emailing: sb08-6-1[1] |
I doubt it was the engine. I just talked with someone who flew the 220
version for transition training September 2007. He squawked the aircraft for
inadequate up trim. I have flown the 540 version for 33 hours and never
gotten the trim setting more than 2 bars from neutral. Inadequate up trim
suggest to me that a improperly rigged trim system might have the two
elevator halves fighting each other and twisting the elevators and stressing
the horizontal stab.
daveleikam(at)wi.rr.com Guest
Posted: Wed Jun 11, 2008 9:36 pm Post subject: Emailing: sb08-6-1[1] |
After looking closely at the pictures, it appears that the metal is not only
cracked, but also "crinkled." If you look at the skin to the left of the
crack, it appears to also be deformed which concurs with the failure of the
bulkhead. First thought is there was substantial down pressure
(compression) on the longeron and on the F1010A angle at this point.
Except when rolling, would there ever be uneven force on the HS? And even
then I would think the forces would be very little. Would it be possible to
detect equal tensional stress on the other side?
I agree with the twisted HS theory.
Dave Leikam
#40496 N89DA (Reserved)
Muskego, WI
- Original Message -----
Sent: Wednesday, June 11, 2008 11:29 PM
Subject: RE: Emailing: sb08-6-1[1]
for
stressing
Deems Davis
Posted: Wed Jun 11, 2008 10:13 pm Post subject: Emailing: sb08-6-1[1] |
Dave, i agreeI
If folks take the time and go back through the archive and read the
original posts (12/06) which witnessed the 'twist' and the follow on
discussion regarding the Elevator trim rigging and how following Van's
plan instructions, can and will result in a twisted HS. the situation
described there is entirely consistent with the results depicted in the
picture of the crack. I believe that there is a VERY high likelihood
that the root cause of the crack lies in a twisting moment induced by
the asynchronous movement of the elevator trim tabs. I was the individ
David refers to that flew 220RV late last year, and there was not enough
up elevator trim available to take the significant back pressure off the
elevator during landings. I believe this is also consistent with the
trim rigging and twisting explanation. Here's an excerpt from my post
following transition training.
**This brings up the next point and that is elevator authority. N220RV had
NO balast in the rear when we flew. We initiated our approach with 20
degrees of flaps (second detent), Turning downwind we added full flaps.
With full flaps there is NOT enough trim to take the back pressure off
of the stick. I found that the back pressure was much more than I found
comfortable, and flew some landings with 2 hands! Makes it
difficult/impossible to develop a fingertip feel on landings. The other
item has been reported by several others and that is when landing it
takes the full aft movement of the stick. The topic has been discussed &
debated previously, but in my opinion with only 2 people and no
baggage/balast there is not enough elevator. Towards the end of 8.1
hours, I was able to get some of the rust scrubbed off, got a little
less shy about the rapidly approaching ground, and found a way to
'muscle' a couple of good landings. then Mike says " let me show you
something, .... we took another trip around the pattern flew exactly as
before only on our base leg after extending full flaps, he had me 'blip'
off a degree or two of flap at a time until the back pressure I'd grown
unaccustomed to holding was gone..... then flew the rest of the landing
!!!!! WOW!!! what a difference !!!!! Mike why did you keep this little
secret to the end??????? the plane landed almost identical to full
flaps, but the 'feel' was completely different and actually a joy!!!!!**
not only cracked, but also "crinkled." If you look at the skin to the
left of the crack, it appears to also be deformed which concurs with
the failure of the bulkhead. First thought is there was substantial
down pressure (compression) on the longeron and on the F1010A angle at
this point. Except when rolling, would there ever be uneven force on
the HS? And even then I would think the forces would be very
little. Would it be possible to detect equal tensional stress on the
other side?
Dave Leikam
Muskego, WI
- Original Message ----- From: "David McNeill" <dlm46007(at)cox.net>
> aircraft for
> trim
> stressing
msausen
Joined: 25 Oct 2007 Posts: 559 Location: Appleton, WI USA
Posted: Thu Jun 12, 2008 3:52 am Post subject: Emailing: sb08-6-1[1] |
That was the first thing I noticed too. It certainly looks like the cracks were induced from a repeated compression and release of bulkhead in that area. Doublers may only be a band aid for this and I bet we will see more of these as the fleet gain hours. If it really is being partially caused by asymmetric trim tab loading, seems like someone could come up with a mod fairly quickly. I know I'll be looking at the trim servo setup while I have it off.
Michael
bcondrey
Posted: Thu Jun 12, 2008 5:10 am Post subject: Emailing: sb08-6-1[1] |
Interesting. When I flew with Alex D. for my transition training he
carried 2 cases of oil in the baggage area in his IO-540 bird. Also, he
said that he normally lands with half flaps (he has a flap positioning
system) unless there are rear seat passengers. When only front seat
occupants there is a very noticeable nose down pitching when going from
half to full flaps.
Tim Olson
Posted: Thu Jun 12, 2008 6:20 am Post subject: Emailing: sb08-6-1[1] |
This just proves how individual these airplanes will be, based
on equippage. N220RV has a LIGHTER engine than the IO-540,
so if N220RV ran out of elevator, something probably really
wasn't right to begin with. I remain skeptical that following
the plans will absolutely result in a twisted tail. I've looked
back on many flights, and even during stall buffet, and watched
the tail. On my last flight, both elevator horns were about 1/4"
up in cruise, but they were symmetrical. And now for the best
part. I have zero problems trimming my stick for 100% hands
off flight, with full flaps, and a 70kt approach speed. I
actually take most people who are NON-pilots who want to learn,
and show them that their job is to trim to the approach airspeed,
and that at that point, releasing their hand from the stick, or
only touching with fingertips, is what they want to do to test
for good trim. And I show them that if you just put your hands
down for a sec, the plane flies just fine.
So while I do get intrigued by the reports people give of other
RV-10's running out of nose-up trim, or reports of twisted
tails, I'm not really sure I will believe that doing it the
plans way is the cause. I think these planes are naturally
so diverse in layout and weighting and design that you're just
seeing that natural variation. For instance, N220RV is
a pretty stripped down plane, built by Vans. Alex's RV-10
is a John Nys plane equipped with A/C, and we've got people
building with extreme variations in engine choice, battery
positions and quantities, propellers, builder attention to
detail, and builders ability to follow plans.
One other thing to keep in mind is that some planes only have
trim tabs on one side, so our asymmetric trim isn't necessarily
that odd. But, that said, wouldn't it be cool if there was
a trim servo mechanism mod that did allow both tabs to provide
the same nose down and nose up trim amounts, while being
symmetrical.
As far as "the Fix" goes, I'm mixed on that one too. It does
look like perhaps there was a little compression to the
bulkhead, but also that perhaps that bulkhead was pushed
forward or aft, twisting slightly. And when you see that the
patch is just another layer of metal over that area, it kind
of makes me wonder why that patch just won't do it again.
it seems that you'd want it to attach to the side skin, and
especially that you'd want to prevent any movement relative
to the longeron, of that top angle of aluminum. Then again,
you don't always want complete stiffness, so maybe that's
part of it too.
I'll do the SB as planned but still watch to see what they
come up with next. As far as trim goes though, I just don't
see a problem in my particular plane, with how the trim
functions, built per plans.
half to full flaps.
bcondrey
Posted: Thu Jun 12, 2008 6:57 am Post subject: Emailing: sb08-6-1[1] |
Tim,
You bring up a good point about configuration differences. There is a
lot of focus on empty weight but equally important is where the empty
weight CG winds up.
Regarding Alex's plane - Although John N. built it (but didn't do the
finish work), the airframe itself is in a stock configuration and
doesn't have some of the telltale signs of being built by John N. (i.e.
second set of fuel tanks outboard). That plane does have AC and a heavy
looking interior but even with full flaps on approach there's plenty of
trim authority, he just prefers half flaps.
Regarding comments from Deems, it seems strange that with the small
continental up front that you'd still have a CG in the forward part of
the envelope. I've never flown that plane but do have the numbers from
410RV and its empty weight ARM is at 106.99". You'd think with a
lighter engine that the CG would be a little farther aft
I also notice that your empty weight Arm is 108.67" (from your POH) and
mine is 108.20" which makes a huge difference in the handling feel.
See you Saturday at BNW!
rene(at)felker.com Guest
Posted: Thu Jun 12, 2008 7:19 am Post subject: Emailing: sb08-6-1[1] |
On the trim issue. My empty weight CG is aft of 410RV. During transition
training with no ballast in 410RV I ran out of trim on landing with full
flaps. On my airplane I have plenty of trim and always land full flaps.
Rene' Felker
RV-10 N423CF Flying
801-721-6080
Tim Olson
Posted: Thu Jun 12, 2008 7:23 am Post subject: Emailing: sb08-6-1[1] |
Exactly....lots of differences. Just pointing out that between
all of the planes there are significant equipment differences.
For me, I've been a pretty firm believer that you should not
TRY to "fix" the "noseheavy problem" any more than by doing
things that are natural to your design, because it will be very
easy to go overboard with moving that CG aft. I have a PC925,
and have smaller batteries under the passenger knees. Both
were part of my intended design, and let to a slight shift in
aft CG...which you pointed out. But to go further than that
by much, like if I wanted to switch props, and do some other
funky stuff, won't give the same loading options that I have.
I actually can hold the nose off to REAL slow speeds even
when there are only front-seaters on board., so trim is not
an issue at all, nor is elevator authority. Personally I
think the goal should be to stay as close to the very far
forward CG position like N410RV has as you CAN....only making
the compromises to put weight aft that you need to for your
other goals. It's been said over and over that being aft
CG by too far is the most dangerous...and it's far more
important to be in CG than under gross when considering your
loadings. So preserving as much of the forward CG is
a good idea.
Yep, will see you there at BNW!
Tim,
weight CG winds up.
Posted: Thu Jun 12, 2008 7:47 am Post subject: Emailing: sb08-6-1[1] |
My point with respect to running out of up trim, is: if the trim was not
proper, the left elevator half could be commanding nose down while the right
elevator could be commanding nose up. Could be a real problem at high cruise
speed or even abrupt movement of the controls near maneuvering speed. IIRC
the V tail bonanza used to peel the leading edges of the ruddervators back
in opposite directions until the fifth or so AD fixed it. A mistake on a
factory airplane is hard to believe but not impossible.
Posted: Thu Jun 12, 2008 8:21 am Post subject: Emailing: sb08-6-1[1] |
But also think not only of a twisted HS theory but remember the tail fuse skin is part of this equation, I don't see it so much as compression problem as a shearing problem...the fuse side skin going in a different direction from longeron and the horizontal angle that is going across the top and fastening to the HS stab. As though the HS is not rolling, but rather yawing and cycling with some harmonic.
John G. 409
[quote] From: daveleikam(at)wi.rr.com
Subject: Re: Emailing: sb08-6-1[1]
Date: Thu, 12 Jun 2008 00:36:05 -0500
--> RV10-List message posted by: "Dave Leikam" <daveleikam(at)wi.rr.com>
Dave Leikam
Muskego, WI
Subject: RE: RV10-List: Emailing: sb08-6-1[1]
> --> RV10-List message posted by: "David McNeill" <dlm46007(at)cox.net>
> for
> stressing
Posted: Thu Jun 12, 2008 12:23 pm Post subject: Emailing: sb08-6-1[1] |
Tim, I fell into the forward CG trap. I put moving the CG aft as one of my
design objectives based on discussions on the old Yahoo list and this list.
In doing so I did move the CG back a little and now I am regretting it
because it limits the amount of weight I can put in the back of the plane
without running out of the aft CG. In the end I like what I did from a
design point and may have done it that way anyway.
I have a bigger battery in the back and I put my O2 system behind the
baggage compartment bulkhead.
I am now thinking of adding a little weight to the engine......got any ideas
on some useful things I could put up there?
Rene' Felker
RV-10 N423CF Flying
801-721-6080
AV8ORJWC
Posted: Thu Jun 12, 2008 2:38 pm Post subject: Emailing: sb08-6-1[1] |
Know your aircraft's mission! It is time for Tim James to provide
discussion and pictures on his roll bar, VGs and low slow speed
improvements. While he is at it, he can mention the tail
counter-weights which brought his CG "Dead nuts on".
Like Clint said..."A man has to know his limitations". Following the
plan is great and safe. It should never be discouraged. Knowing why the
10 is built or designed the way it is, is important as a baseline. When
you know more or are trying something Experimental there are lots of
options available to those with proper training, technical education and
skill.
I don't think there will ever be a factory discussion on what led to
this crack. Or why the J stringer make contact or that the doubler is
the final solution or that the bulkhead might have been spec'ed with a
beefier stock of material. It is just a fix without meaningful
discussion. Those who are on to asymmetric horizontal trim control may
just have stubbed their toe on a potential cause. Great discussions.
More fleet hours and less accidents are a good thing.
Tim mentioned several of the variables. Now why would N220RV have it
and N410RV with significantly more hours be okay?
John Cox
Kelly McMullen
Posted: Thu Jun 12, 2008 3:35 pm Post subject: Emailing: sb08-6-1[1] |
Is the target empty wt CG what 410RV has or something else? I believe
it has well over 1000 hours on it now, as it was over 900 last August
when I flew in it.
It would seem desirable to start planning towards whatever the goal is
from the start of the tail cone on. Wonder if
Vans will spec that bulkhead in subsequent kits for the next thickness
up. I expect I will have the same as all others when I pickup my
empenage kit, allegedly arriving tomorrow.
Kelly
Builder # yet to come.
On Thu, Jun 12, 2008 at 3:34 PM, John Cox <johnwcox(at)pacificnw.com> wrote:
A&P/IA, EAA Tech Counselor
KCHD |
jcumins(at)jcis.net Guest
Posted: Thu Jun 12, 2008 3:54 pm Post subject: Emailing: sb08-6-1[1] |
I talked to Vans yesterday to ask that exact question. There is no plans to
change the bulkhead to a thicker product. The doublers are the final fix to
it as of yesterday.
I received my Emp. Kit today and now have a very full garage. Kelly make
lots of room the box is 11 ft long almost 4 ft wide and weights 300 pounds.
I am serial number 40864 and anything after 40866 will have the sb kit
included in build kit.
So the fun begins.
John G. Cumins
#40864 Inventory starting soon.
Your Total Technology Solution Provider
partner14
Posted: Thu Jun 12, 2008 5:23 pm Post subject: Emailing: sb08-6-1[1] |
Rene, I added a dry sump oil seperator that looks pretty cool.... might add a couple of pounds. I wanted to do what I could to keep the crud off the bottom of the plane. Designed for big block engines, so it should handle the IO540.
Don McDonald
#40636 Still Finishing.
Rene Felker <rene(at)felker.com> wrote:
[quote]--> RV10-List message posted by: "Rene Felker"
Rene' Felker
RV-10 N423CF Flying
801-721-6080
176.86 KB |
352 Time(s) |
40636 |
