Zenith601-List Digest: 8 Msgs - 06/09/08
sdthatcher
PostPosted: Tue Jun 10, 2008 5:39 am    Post subject: Zenith601-List Digest: 8 Msgs - 06/09/08 Reply with quote
Actually, it appears that the right hand side may need stiffeners. The trim
tab should not have any movement (or very little), but if you try to move
the tab up and down you will note that the motor will move the skin up and
down. A stiffener here would stop that motion since any motion of trim tabs
and/or flaps (while not being moved by the motor) is a bad thing. Check
with Sebastion or Caleb however for an OK before stiffening any surface.
Scott Thatcher, Palm Beach Gardens, FL
601XL with Corvair, Registered as E-LSA
N601EL, http://placestofly.com, EAA203
N601EL, EAA203 90 hours and flying.
sdthatcher
PostPosted: Tue Jun 10, 2008 5:41 am    Post subject: Zenith601-List Digest: 8 Msgs - 06/09/08 Reply with quote
Sorry for sending entire list! I usually make replies from the list and
always have to remember to delete the list first then snip the portion I
want to respond to.
My humble apologies!
