tomhanaway
Posted: Sun Jun 08, 2008 2:36 pm Post subject: Initial Canopy trimming |
I just want to double check on canopy trimming.
With the canopy fitting nicely and flush within the door space, I still have about 3/16" of jog space exposed on both sides of the rear bottom of the canopy over the mid side skin. Lip is cut back to just under 3/4" so it isn't bottoming and preventing canopy from going all the way down.
So-- I've already trimmed past the scribe marks in the doorway area. It looks like if I trim (the door area) enough to bring the back lower part of the canopy flush with the jog line, I'll have sanded away almost all of the bottom of the canopy door frame.
Does this sound familiar???
Tom
davelammers(at)mchsi.com Guest
Posted: Sun Jun 08, 2008 2:52 pm Post subject: Initial Canopy trimming |
Tom,
Sounds very familiar.
Grit your teeth and sand away.
Dave Lammers
finishing
tomhanaway wrote:
Tom
http://forums.matronics.com/viewtopic.php?p=186877#186877
johngoodman
Posted: Sun Jun 08, 2008 2:55 pm Post subject: Re: Initial Canopy trimming |
Tom,
I recently did mine and I'll admit it get's pretty thin on the bottom. However, I think the plans show an outside measure of a little over an inch in that area. I'm not looking at the plans so I can't be specific.
Tim Olson
Posted: Sun Jun 08, 2008 3:18 pm Post subject: Initial Canopy trimming |
Yep, that's how it turns out. You'll want to fill that area anyway to
smooth it for painting, so just drill and rivet and keep on moving
forward if everything else looks good.
tomhanaway wrote:
Tom
AirMike
MauleDriver(at)nc.rr.com Guest
Posted: Mon Jun 09, 2008 3:33 am Post subject: Initial Canopy trimming |
Yes it is. I ended up with some thin spots.
FWIW, I used a variety of power tools to remove the material around the
door sill. Once I got to the point of getting the whole thing to settle
down close to the jog line, I finally found the Van's recommended 5'
sanding block to be an effective tool.
Bill "continuing to worry the doors into compliance" Watson
Durham NC
Tom
Albert Gardner
Posted: Mon Jun 09, 2008 9:25 am Post subject: Initial Canopy trimming |
When I was trimming my canopy I borrowed a Fein power tool from a friend.
This is one of those that the blade, although semi-circular in shape,
vibrates rather than rotates. Didn't throw off chips and dust and made it
very easy to cut the fiberglass. Beat the cut-off tool in every way. Worked
very well on the windows also.
Albert Gardner
N991RV
Yuma, AZ
(I hope he has forgotten who he lent it to by now)
_________________ RV-9A N872RV
RV-10 N991RV |
Lew Gallagher
Posted: Mon Jun 09, 2008 5:11 pm Post subject: Re: Initial Canopy trimming |
Hey Tom,
Just to second the others -- I stopped when the door sill started to look thin, and left the gap that Tim says will be filled at final fit before painting.
Here are some pictures I took today so you can compare. At one point I noticed that the edge along the longerons needed to be shaved to allow the cabin back to settle as I shaved the door sill -- it's a bit fuzzy (too lazy to climb inside to take the pic) but see "interior cabin gap".
Later, - Lew
27.99 KB |
651 Time(s) |
37.56 KB |
620 Time(s) |
111.15 KB |
584 Time(s) |
76.61 KB |
662 Time(s) |
_________________ non-pilot
crazy about building
NOW OFICIALLY BUILDER #40549
Fly off completed ! |
tomhanaway
Posted: Mon Jun 09, 2008 5:50 pm Post subject: Re: Initial Canopy trimming |
Thanks to all. Got it to where I feel pretty good about the fit all around. One nice thing is that all the fiberglass dust made the other scribe lines really easy to see.
I feel like I just pledged a fraternity and went through hazing by fiberglass.
Nice to feel all the community sharing of experiences.
Tom
