chuckp
Posted: Sat May 31, 2008 5:58 am Post subject: Ethanol?Ethanol? |
I’ve been flying my Avid A model for about 14 years with pure gasoline. About 2 years ago 10% ethanol was mandated in Maryland, and I have had several incidents which have caused me to make off-airport landings or abort take-offs due to engine malfunction. Extensive analysis has led to the inescapable conclusion that the ethanol had dissolved some of the polyester resin of my 1990 vintage wing tank and the dissolved resin plugged up the fuel filter. Examination of the filter showed that the element was covered with a slimy goo, and I could barely blow through it. I have since scouted out distant areas which still have pure fuel, which I now buy and transport in large quantities, and have had no more trouble since! I understand that Avid and Kitfox changed their wing tank resin to epoxy or vinylester at some point (anybody know when?), and that the later manufactured tanks probably won’t have this problem.
Chuck
Flying and grinning since 1956
Checked by AVG.
5/30/2008 2:53 PM
_________________ Pops
Avid STOL N113P
Flying and grinning since 1956 |
Float Flyr
Posted: Sat May 31, 2008 11:33 am Post subject: Ethanol?Ethanol? |
Vinylester fillers are supposed to be “ethanol resistant” whatever that means. I’d wait to see something “ethanol proof”. In the mean time Dave, of this list, has the address for slip in tanks that will fit the wings. Those tanks are rotary moulded HDPE which is just about as close to ethanol proof as you can get. Check back through the archives or wait a few hours I’m sure Dave will post the address again for you.
Noel Loveys
Campbellton, NL, Canada
CDN AME intern, PP-Rec
C-FINB, Kitfox III-A
582 B box, Ivo IFA, Aerocet 1100 floats
[url=noelloveys(at)yahoo.ca]noelloveys(at)yahoo.ca[/url]
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Chuck Popenoe
Sent: Saturday, May 31, 2008 11:26 AM
Subject: Re: Re: Ethanol?Ethanol?
Chuck
Checked by AVG.
5/30/2008 2:53 PM | Quote: | | http://www.matronics.com/Navigator?Kitfox-List | 0123456789
7.29 KB |
4621 Time(s) |
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
temco(at)telusplanet.net Guest
Posted: Sat May 31, 2008 12:41 pm Post subject: Ethanol?Ethanol? |
Noel
The site is http://wingtanks.com/
Ted Palamarek
Edmonton
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Noel Loveys
Sent: May 31, 2008 1:29 PM
Subject: RE: Re: Ethanol?Ethanol?
Noel Loveys
Guy Buchanan
Posted: Sat May 31, 2008 1:59 pm Post subject: Ethanol?Ethanol? |
At 12:29 PM 5/31/2008, you wrote:
| Quote: | Vinylester fillers are supposed to be "ethanol resistant" whatever
that means. I'd wait to see something "ethanol proof".
There are vinylesters that are "ethanol proof". They are used to make
tanks for gas stations, most of which are now fiberglass. I'm
guessing John's using such a formulation for his current crop of wing tanks.
Guy Buchanan
San Diego, CA
Deceased K-IV 1200
A glider pilot too. |
Float Flyr
Posted: Sun Jun 01, 2008 4:28 pm Post subject: Ethanol?Ethanol? |
Thanks Ted
Noel
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Ted Palamarek
Sent: Saturday, May 31, 2008 6:07 PM
Noel
Ted Palamarek
Edmonton
Noel Loveys | Quote: | | http://www.matronics.com/Navigator?Kitfox-List | 0123456789
Kitfox III-A
