Mike Whisky
Posted: Mon May 19, 2008 11:08 pm Post subject: Aerotronics RV-10 Panel |
Is someone on the list who installed the Aerotronics RV-10 panel?
http://www.aerotronics.com/experimental/vans_category.php#rv10
What are your experience, how much additional "fitting" work is required?
Best Regards
Michael
_________________ RV-10 builder (flying)
#511 |
henkjan(at)zme.nl Guest
Posted: Mon May 19, 2008 11:54 pm Post subject: Aerotronics RV-10 Panel |
Look at www.zme.nl and click the kitlog logo, and it will fit your
center console as well!
Additional fitting work?......a lot!
Best regards
Henkjan
-----Oorspronkelijk bericht-----
Van: owner-rv10-list-server(at)matronics.com
[mailto:owner-rv10-list-server(at)matronics.com] Namens Michael Wellenzohn
Verzonden: dinsdag 20 mei 2008 9:09
Aan: rv10-list(at)matronics.com
Onderwerp: Aerotronics RV-10 Panel
<rv-10(at)wellenzohn.net>
required?
Best Regards
Michael
RV-10 builder (engine, prop, finishing)
#511
http://forums.matronics.com/viewtopic.php?p=183983#183983
Deems Davis
Posted: Tue May 20, 2008 12:26 am Post subject: Aerotronics RV-10 Panel |
Michael, I saw Henkjan's pics and 'fell in love' with the panel,
e-mailed him to find out where he got it and then contacted Aerotronics
who warned me that it would require additional fitting. They and Henkjan
are right! I'm not sure I went about it the best way, but the 1st 3-4
links on this page show how I mounted the panel to the fuse/upper fwd
fuse. http://deemsrv10.com/upperfwdfuseinstallationlogindex.html There
are several other pages that show the installation. as well. I am VERY
happy with the end result so far, it is aesthetically pleasing to me,
however it took a lot of additional work. (I still have to reset the
copilot subpanel as it is slightly crooked)
http://deemsrv10.com/album/Panel/slides/DSC05574.html. One thing to be
aware of is that the design of this panel restricts the use of the
available 'real estate' so if you have a lot of components that you want
to put in the panel, make sure they will all fit. I also made a center
console to match to it as well.
http://deemsrv10.com/album/Sec%2041%20Upper%20Fwd%20Fuse%20Install/slides/DSC03024.html
Deems Davis # 406
'Its all done....Its just not put together'
Henkjan van der Zouw wrote:
Best regards
Henkjan
AirMike
Posted: Tue May 20, 2008 6:04 pm Post subject: Aerotronics RV-10 Panel |
They did my panel for me - awesome. See my post previously put on this site under "Aerotronics - Blatant plug for - Plug & Play panel".
They are very complete. You do need to do a lot of finish wiring, but I went to Billings (They are also at OSH) to pick it up. They gave me three hours of training in finish wiring. Basically they give you a bunch of connectors to just conjoin with their connectors already on the panel. Very simple and the directions are excellent (diagrams).
I figure that they saved me about 400 hours of build time and infinite aggravation. Plus it looks really professional. Their pricing is not cheap, but for what you get it is a bargain. If you need support or have questions, it is included - no extra charge for the 1st year.
1.49 MB |
499 Time(s) |
_________________ See you OSH '18
Q/B - sold. |
