nuckolls.bob(at)cox.net Guest
Posted: Mon May 19, 2008 7:02 pm Post subject: Any legacy regulator gurus out there? |
I received some pictures from a reader who is looking for an
adjustment procedure for a Delco-Remy generator regulator.
http://aeroelectric.com/Pictures/Regulators/12VN7E_Delco-Remy_4.jpg
http://aeroelectric.com/Pictures/Regulators/12VN7E_Delco-Remy_3.jpg
http://aeroelectric.com/Pictures/Regulators/12VN7E_Delco-Remy_2.jpg
http://aeroelectric.com/Pictures/Regulators/12VN7E_Delco-Remy_1.jpg
I've never seen an electro-mechanical regulator that was this
sophisticated. It appears to have airgap adjustments as well
as spring tension adjustments for both the V-reg and I-lim
relays.
I'm wondering if anyone on this IS or KNOWS someone WHO IS
familiar adjustment of these devices. I'm afraid that the
"offical" procedure will require test equipment common to
a generator/regulator overhaul shop. Unless I can find
data specific to this device (I think the 12VN7E
numbers on the base plate are a part number) I'm going
to recommend that he not mess with anything other than
the tension spring on the voltage regulator which can
be adjusted with the engine running and a light load
on the system.
( -Thomas Paine 1776- )
jetboy
Posted: Tue May 20, 2008 2:21 am Post subject: Re: Any legacy regulator gurus out there? |
Sir, I dont quite want to claim guru status, working on my previous C150A from '61 it was similar and I did reset the V reg to around 14.4 - it was sitting about 13 - and reset the I reg with a wirewound resistor (one of those old monster types with the sliding clamp) to get the output up to 12 amps or so from the 'as found' 6 amps. It was actually a 20 amp generator but 12 is enough when the professional fix would be 100s of miles and $ away
I dont recall whether I altered the gaps or tension for this but I did it after cleaning the contacts from 40 years of pitting with a burnishing tool.
Some time later I had a low charge again and discovered the aircraft master switch - which thoughtfully includes cutoff contacts for the generator field line - was in need of similar refurbishing. love these old systems because they are actually repairable - just go to where the smoke last escaped from...
Moral of the story for me was I had wrongly assumed I knew enough not to check the aircraft schematics first. In all probability the regulator may have been OK but the worn switch in the field line had reduced the drive. It did no harm checking the regulator and it would have been a shame to have it binned as it looked like new inside just as the ones pictured. So I concur with your notion to have him only mess with the V reg - perhaps after cleaning the contacts and checking the other wiring for hidden resistance.
Ralph
_________________ Ralph - CH701 / 2200a |
