hammer408(at)comcast.net Guest
Posted: Fri May 16, 2008 12:35 pm Post subject: 6 AWG vs Copper Bar |
Bob:
Insteard of using 6 AWG from starter contctor to Current Limiter, I want to
use .063 copper bar...is that adequate or should I use .125.
thanks
nuckolls.bob(at)cox.net Guest
Posted: Fri May 16, 2008 6:31 pm Post subject: 6 AWG vs Copper Bar |
At 04:37 PM 5/16/2008 -0700, you wrote:
<hammer408(at)comcast.net>
Bob:
thanks
.063 x .75" copper is fine.
Posted: Sun May 18, 2008 6:51 am Post subject: 6 AWG vs Copper Bar |
Bob:
I have .063 X .50"; can I double up and make 2 bars thus giving me .125 x
.50"
Posted: Sun May 18, 2008 10:20 am Post subject: 6 AWG vs Copper Bar |
At 10:56 AM 5/18/2008 -0700, you wrote:
Bob:
.50"
Sure . . . but the .50" width doesn't leave you much edge
margin at the clearance holes for 5/16" studs and there's some
concern for spreading the high currents across the hole
through 3/32" connections at the edges. But lots of folk
have used this width of material and I've not heard of
any problems. In fact, a single layer offers a cross-
section of .063 x .50 = .031 square inches. 4AWG
wire is two, 3AWG-doubling steps larger than 10AWG.
10 AWG is .1" diameter or 3.14 x .05^2 = 0.0078
square inches. Taken times 4 yields .031 square
inches for 4AWG wire. The same as your proposed
straps which will cool better because of larger
surface area and heat-sinks at the studs.
So electrically and thermally, the proposed strips
are fine. How about this? Go to your local well-stocked
hardware store and get some 5/16" brass washers.
Solder to one side of your 0.5" copper strap at the
5/16" hole locations. I think you said you were
working with a shunt at the other end which is a
1/4" stud. No "reinforcement" necessary.
"Doubling up" the strap makes it more difficult
to get the two pieces to lay together. A soldered
on doubler at the 5/16" holes is easier and will
look better when you're finished.
( -Thomas Paine 1776- )
Posted: Sun May 18, 2008 10:35 am Post subject: 6 AWG vs Copper Bar |
Thanks Bob: I like the idea of soldering brass washers.....or better yet, I
may just order .063 x .75" wide copper bar and KISS.
