moorecomp
Posted: Tue May 13, 2008 7:01 am Post subject: Re: Trim tab play |
Andy,
Check out how Larry Martin put spring loaded nosewheel steering on his 701. Larry is a master tinkerer.
http://www.skyhawg.com/petals.html
(yes, pedals is mispelled)
Best regards,
Craig Moore A&P
Mancelona, MI
Gig Giacona
Posted: Tue May 13, 2008 8:16 am Post subject: Re: Trim tab play |
Three reason, complexity, complexity and complexity. Did I mention complexity?
I don't have my engine on the mount yet but I do have a big piece of concrete that is there to counter balance somewhat but it is not stretching the bungee at all. I can with some force move the gear stop to stop sitting in the hanger. I have not put any lube on it at all. I just can't see changing the design for what is really just a transient issue that will work itself out as the system wears in a little.
You are also planing to put a Corvair engine in as I am and the Corvair is on the up end of the weight scale for the 601. You don't need any extra weight out there in front.
[quote="ashontz"]What's wrong with it?
[quote="Gig Giacona"]Good God Why?
do not archive.
| ashontz wrote: | Is anyone using a Cessna style spring loaded front wheel steering instead of a hard mount on the wheel? I kind of figured that's the way I'd like to go when the time comes.
601XL Under Construction
Terry Phillips
Joined: 11 Jan 2006 Posts: 346 Location: Corvallis, MT
Posted: Tue May 13, 2008 10:09 am Post subject: Trim tab play |
At 08:01 AM 5/13/2008 -0700, Craig Moore wrote:
| Quote: | Check out how Larry Martin put spring loaded nosewheel steering on his
Best regards,
Craig Moore A&P
Mancelona, MI
Craig
Thank you for this post. I've been concerned about the interaction between
the direct link nose wheel and the behavior in Montana's winds, and Larry's
solution looks to be a good way to go.
Terry
Terry Phillips
ttp44~at~rkymtn.net
Corvallis MT
601XL/Jab 3300 s .. l .. o .. o .. w build kit - Tail, flaps, & ailerons
are done; working on the wings
http://www.mykitlog.com/N47TP/
_________________ Terry Phillips
Corvallis, MT
ttp44<at>rkymtn.net
Zenith 601XL/Jab 3300 slow build kit - Tail feathers done; working on the wings. |
ggower_99(at)yahoo.com Guest
Gig Giacona
Posted: Tue May 13, 2008 12:54 pm Post subject: Re: Trim tab play |
I fully understand the whole experimental aviation thing. BUT to do it before you know there is a problem is just silly UNLESS you are wanting to just test different ideas.
Andy, who I was responding to, has not said he wants to be a tester, he wants to have a safe aircraft. If a problem is there after he puts the gear on then fix it. If it is done before you even know there is a problem you won't know if a problem that the change causes is better or worse than the problem that might or might not be there.
| ggower_99(at)yahoo.com wrote: | Probably because in Experimental Aviation, we all are test pilots
