dlm46007(at)cox.net Guest
Posted: Tue May 13, 2008 2:59 am Post subject: Hartzell prop and IO540D4A5 |
Did anyone have to adjust the low pitch stop on the prop from Van's to get the 2700 RPM? or was the entire adjustment in the governor?
ricksked(at)embarqmail.co Guest
Posted: Tue May 13, 2008 5:24 am Post subject: Hartzell prop and IO540D4A5 |
David,
I don't know if this will help but this was the response I got from MT about setting the governor and low speed RPM.
Rick Sked
40185
"All P-860-( ) governors are basically the same. The - ( ) number only refers
to the control arm position and the max. rpm of the governor. To change the
control arm, loosen the 6 screws, turn the entire center portion to the
desired position, tighten the 6 screws and safety.
To change max rpm the set screw on the high rpm stop is turned
counterclockwise (out) to increase rpm and clockwise (in) to decrease rpm.
If there is not enough adjustment possible ( 1 turn = 25 rpm) the control
arm must be reset on the spline one notch at the time.
All this can be done on the plane.
To have MT Propeller USA, Inc. modify the governor max. rpm would cost
approx. $100.00, unfortunately the control arm position must be adjusted on
the plane"
d_emond(at)mweb.co.za Guest
Posted: Tue May 13, 2008 10:54 am Post subject: Hartzell prop and IO540D4A5 |
If memory serves me right I was only getting 2500 RPM. I had to reset my arm one spline. I made a reference mark, took the screw adjustment up to close to the reference mark, and then screwed it out each flight, until I got to the desired RPM.
Dave Emond
raddatz
Posted: Tue May 13, 2008 6:12 pm Post subject: Re: Hartzell prop and IO540D4A5 |
I believe all the 10's I built where around 2550-2600 out of the box, I just mark the arm and shaft and move the arm one spline.
lessdragprod(at)aol.com Guest
Posted: Tue May 13, 2008 8:41 pm Post subject: Hartzell prop and IO540D4A5 |
If Van's Aircraft sold the P-860-5 governor for the wide deck Lycoming IO-540 engine, you wouldn't even be having this discussion.
The P-860-3 governor is for the narrow deck Lycoming IO-540 engine, which has a different gear ratio to the front mounted governor.
Jim Ayers
Posted: Tue May 13, 2008 9:01 pm Post subject: Hartzell prop and IO540D4A5 |
Yup.....Jim has the correct info in that!! No surprise. Curious.....How many narrow decks are out there?...ummmm NOT MANY!! It's a Dutch think I think, and an ignorance thing on us builders...not so ignorant now though.
Rick Sked
40185
Dick Sipp
Posted: Wed May 14, 2008 6:13 pm Post subject: Hartzell prop and IO540D4A5 |
Jim:
Is re-indexing the arm on the govenor an as others have mentioned a factory acceptable adjustment?
Dick Sipp
Posted: Wed May 14, 2008 7:34 pm Post subject: Hartzell prop and IO540D4A5 |
Dick,
It is...Here as I posted before is the response from MT USA direct from their resident expert and this guy really knows his stuff.
Rick Sked
40185
all P-860-( ) governors are basically the same. The - ( ) number only refers
the plane
Best Regards,
Juergen Zahner
mt-propeller USA, Inc.
ph: [url=callto:+1386-736-7762]386-736-7762[/url]
fax:[url=callto:+1386-736-7696]386-736-7696[/url]
Juergen.Zahner(at)mt-propellerusa.com
www.mt-propellerusa.com
Posted: Thu May 15, 2008 8:09 pm Post subject: Hartzell prop and IO540D4A5 |
Hi Dick,
I received the following comment from MT Propeller in Germany.
"(The) Best way is to send it (the governor) to MT USA as they do it (the adjustment) on the test bench. UPS Ground is not expensive and the better way. In the operating & Installation manual of the governor (it) is stated on page 12 that the modification must be done at an authorized service shop."
Additionally, because of the spring loading, the MT Propeller factory is concerned about the customer loosing track of the position of the splined shaft when the control lever is removed.
Jim Ayers
Posted: Thu May 15, 2008 8:27 pm Post subject: Hartzell prop and IO540D4A5 |
before indexing mark the spline and the handle. and when changing the handle hold the spring.
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of lessdragprod(at)aol.com
Sent: Thursday, May 15, 2008 9:05 PM
Subject: Re: Re: Hartzell prop and IO540D4A5
Hi Dick,
Jim Ayers
Posted: Thu May 15, 2008 8:34 pm Post subject: Hartzell prop and IO540D4A5 |
The MT propellor rep in FL provided info to do it on the aircraft.
Hi Dick,
Jim Ayers
pascal(at)rv10builder.net Guest
Posted: Fri May 16, 2008 6:45 am Post subject: Hartzell prop and IO540D4A5 |
Except, why is Van's Aircraft STILL only selling the MT governor for the NARROW DECK IO-540 engine? Van's Aircraft only sells new WIDE DECK IO-540 engines.
I want to know Why they are still also ONLY selling the 2 blade Hartzell prop when Hartzell has composite blades that work just as well if not better (at a higher cost)..
granted none of this is good for MT but I would like to see the composite Hartzell and give Jim the business directly for MT, which one needs to do anyway.
Oregonians, walk over and put some pressure on Van's to update their prop selections.. please!!
Pascal
From: lessdragprod(at)aol.com (lessdragprod(at)aol.com)
Sent: Friday, May 16, 2008 7:10 AM
The MT Propeller factory in Germany recommends sending the governor to the MT Propeller rep in Florida. (This is a what is best for everyone answer. Everyone is assured of getting a governor set up for their engine.)
The MT Propeller rep in Florida provided information for those people that want to try to do this themselves. As they are getting the aircraft ready for Phase 1 testing. (Like there's nothing better to do? )
Now we've both said it twice.
Jim Ayers
-----Original Message-----
Sent: Thu, 15 May 2008 9:28 pm
Subject: RE: Re: Hartzell prop and IO540D4A5
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com ([email]owner-rv10-list-server(at)matronics.com?[/email])] On Behalf Of lessdragprod(at)aol.com (lessdragprod(at)aol.com)
Hi Dick,
Jim Ayers
rv(at)thelefflers.com Guest
Posted: Fri May 16, 2008 7:18 am Post subject: Hartzell prop and IO540D4A5 |
Our EAA chapter took a tour of Hartzell last week. Although they wouldn’t say anything specific, they did hint that we would have more Hartzell choices from Van’s in the next month.
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of pascal
Sent: Friday, May 16, 2008 10:43 AM
Pascal
Jim Ayers
Posted: Fri May 16, 2008 7:56 am Post subject: Hartzell prop and IO540D4A5 |
Thanks for the status Bob, that is great news! Maybe my constant e-mails asking for the consideration went somewhere afterall.
Pascal
Sent: Friday, May 16, 2008 8:15 AM
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of pascal
Pascal
Jim Ayers
RobHickman(at)aol.com Guest
Posted: Fri May 16, 2008 8:46 am Post subject: Hartzell prop and IO540D4A5 |
"I want to know Why they are still also ONLY selling the 2 blade Hartzell prop when Hartzell has composite blades that work just as well if not better (at a higher cost).."
You should have gone to the RV-10 dinner last weekend, I just happen to know who is testing the new 2 blade composite Hartzell prop on a RV-4.
Extremely smooth, much lighter, and it looks and sounds cool.
Rob Hickman
Wondering what's for Dinner Tonight? Get new twists on family favorites at AOL Food.
Posted: Fri May 16, 2008 11:12 am Post subject: Hartzell prop and IO540D4A5 |
Haha, gone to a dinner 1000 miles away? .. you crack me up [img]cid:0789E2DF7C254D20A25FFEE39C3C668F(at)pascaldell[/img]. By the way, thanks for sponsoring it.
Any performance difference noticed? climb, cruise, etc.. with the composite prop?
Any updates (unofficially) on the DECK and future plans for it's expanded capabilities?
Thanks!
From: RobHickman(at)aol.com (RobHickman(at)aol.com)
Sent: Friday, May 16, 2008 9:43 AM
Rob Hickman
1.31 KB |
13581 Time(s) |
Posted: Fri May 16, 2008 12:34 pm Post subject: Hartzell prop and IO540D4A5 |
In a message dated 5/16/2008 12:14:51 P.M. Pacific Daylight Time, pascal(at)rv10builder.net writes:
| Quote: | Haha, gone to a dinner 1000 miles away? .. you crack me up . By the way, thanks for sponsoring it.
Thanks!
I am still gathering data on the prop, should have it in another week or so. I am currently flying the flight director, autopilot interface, and weather. We currently have six full time engineers and four of them are only working on software.
Rob Hickman
1.31 KB |
13584 Time(s) |
AV8ORJWC
Posted: Fri May 16, 2008 6:25 pm Post subject: Hartzell prop and IO540D4A5 |
At the Pacific NW RV-10 Builder Dinner, Rob Hickman was displaying his test bed Hartzell prototype 2 blade Scimitar II Composite prop on is RV-4. I am sure he is under a gag order but I stole a Hi-Res picture (which has been Matronic neutered here). The identification on each blade read "Des. No. N7605-2X.
Skunkworks NW
John C.
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bob Leffler
Sent: Friday, May 16, 2008 8:16 AM
Pascal
Jim Ayers
 Download |
| Filename: |
Rob's_Test_Prop.pdf |
399.76 KB |
| Downloaded: |
697 Time(s) |
AV8ORJWC
Posted: Fri May 16, 2008 6:33 pm Post subject: Hartzell prop and IO540D4A5 |
Rick Sked, Deems Davis and Les Kearney all exceeded the 1,000 miles from home rule to make the dinner. The Hickman's were gracious hosting the event. All things are possible for the Fall get to gather.
Still LOL.
Sent: Friday, May 16, 2008 12:10 PM
Haha, gone to a dinner 1000 miles away? .. you crack me up [img]cid:image001.gif(at)01C8B78B.0C46E8D0[/img]. By the way, thanks for sponsoring it.
Thanks!
Rob Hickman
| Quote: | | href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-Listhref="http://forums.matronics.com">http://forums.matronics.comhref="http://www.matronics.com/contribution">http://www.matronics.com/c |
1.31 KB |
13581 Time(s) |
