nuckolls.bob(at)cox.net Guest
Posted: Mon May 12, 2008 6:31 pm Post subject: Use of 700-2-10 switch for Voltage Sense - how to wire? |
At 11:02 AM 5/12/2008 -0700, you wrote:
I am building a Z-19 type electrical system and I have a question
about a switch configuration. I was planning to use a 2-10 / three
position to view voltage on different buses, depending
on the position:
1. E Bus voltage
2. Main Battery Bus voltage
3. Engine Battery Bus voltage
I have a digital volt meter with simple +/- inputs.
First, do you think this switch 2-10 will work or should I use
something else?
I've played around with various wire combinations and a 2-10 switch but
have come up short (not a short, ha!). I just cannot seem to figure out
the right combination that provides the power feed to a single switch
position/combination. So that is the crux of my problem, the right wiring
for this switch (if possible). I know that all three PLUS leads from the
bus to switch to meter need to be isolated through the switch. I seem to
get one source isolated but then another switch position lights up two
power leads.
The ground is common across all buses and batteries.
The 2-10 would work but as others have noted, leaving a
voltmeter connected to a battery bus for long periods of
time may present a battery service readiness issue. If you
use the 2-70 architecture (spring loaded to center) you can
use the center position to read e-bus (which goes down with
the master switches). The extremes are used to measure
batteries and cannot be inadvertently left ON after the
airplane is shut down.
A miniature version of the 2-70 is a C&K 7215SYZQ available
from Digikey at:
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail?name=CKN1134-ND
Wiring for this switch is illustrated at:
http://www.aeroelectric.com/Pictures/Schematics/3-Ch_Voltmeter.pdf
( -Thomas Paine 1776- )
mikefapex
Posted: Tue May 13, 2008 6:00 am Post subject: Re: Use of 700-2-10 switch for Voltage Sense - how to wire |
Bob,
That was the info I was looking for. Thanks very much, seems like a straightforward solution.
Mike
mikefapex
Posted: Sun May 18, 2008 3:33 pm Post subject: Re: Use of 700-2-10 switch for Voltage Sense - how to wire |
I obtained both the Digikey and B&C 2-7 switches.
When wired as indicated on the diagram the Digikey version worked as expected. However the B&C 2-7 did not. The middle position does not show the expected voltage (or any voltage). When I substitute a 2-10 switch it, like the Digikey version, works as expected.
I will play further with the B&C 2-7 but it is either not designed for wiring that way or just a bad switch.
Mike
Posted: Sun May 18, 2008 6:58 pm Post subject: Use of 700-2-10 switch for Voltage Sense - how to wire? |
At 04:33 PM 5/18/2008 -0700, you wrote:
You lost me. Did our conversation start out talking
about the 2-7 functionality?
A 2-7 is double pole, three position, (ON)-OFF-(ON) device
where the parens around the 'ON' denotes a spring-loaded
momentary position.
The 2-10 is a double pole, three position, PROGRESSIVE
TRANSFER, ON-ON-ON device that is stable at all three
positions. No spring loading.
A few of the ways these two switches can be used
are illustrated in:
http://aeroelectric.com/Pictures/Schematics/2-Pole_Switch_Options.pdf
and in Figure 11-14 in the 'Connection.
The 2-7 cannot substitute for a 2-10. A 2-70 (progressive
transfer version of a 2-7) can do the same switching
job as a 2-10 where you WANT the two extreme positions to
be momentary.
I don't think B&C stocks the 2-70 so if you got a 2-7
from them, I would predict mystifying results. The Digikey
number I gave you was for a 2-70 equivalent in a miniature
switch by C&K . . . not a 2-10.
If you've already drilled a hole for a standard size
2-70, there's a version of the miniature 2-70
that sports a standard size toggle and mounting hole.
See:
http://aeroelectric.com/Pictures/Switches/7215TZQE.jpg
and
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail?name=CKN1495-ND
mikefapex
Posted: Mon May 19, 2008 7:33 am Post subject: Re: Use of 700-2-10 switch for Voltage Sense - how to wire |
Bob,
My bad, I mixed up the switch types. I think I will stick with the small Digikey switch and be happy.
Thanks again,
Mike
