daveleikam(at)wi.rr.com Guest
Posted: Mon Feb 27, 2006 5:47 pm Post subject: Tough to set rudder rivet - Did it! |
I drilled out the AN470AD4-4 rivet closest to the trailing edge of the rudder holding the R-1004A and B together. Rivet tape to hold the rivet in place, upside down now. I then had my son Tyler (AKA co-pilot) hold the R-1004A away enough to squeeze the rivet with a thin nose yoke. Then re-rivet the R-1004A and B. Building is so much fun!
Thanks for the other suggestions.
Dave Leikam
#40496
Posted: Mon Feb 27, 2006 5:53 pm Post subject: Tough to set rudder rivet - Did it! |
Posted: Mon Feb 27, 2006 5:57 pm Post subject: Tough to set rudder rivet - Did it! |
Dave Leikam
#40496
jwik(at)crary.com Guest
Posted: Tue Feb 28, 2006 7:11 am Post subject: Tough to set rudder rivet - Did it! |
I am at that same point with no thin nose yoke. Was considering an approach like shown on this builders tip for dimplinge and setting rivets in those hard to reach places.
http://www.experimentalaero.com/Builders%20Tips.htm
Dave Leikam wrote:
| Quote: | I drilled out the AN470AD4-4 rivet closest to the trailing edge of the rudder holding the R-1004A and B together. Rivet tape to hold the rivet in place, upside down now. I then had my son Tyler (AKA co-pilot) hold the R-1004A away enough to squeeze the rivet with a thin nose yoke. Then re-rivet the R-1004A and B. Building is so much fun!
Dave Leikam
#40496
| Quote: | ----- Original Message -----
Sent: Monday, February 27, 2006 6:08 PM
Subject: Re: Tough to set rudder rivet
Hi Dave,
There are a few approaches that work. I took some meat out of the center of a bucking bar, leaving about a 3/16" thick surface on either side that I could slide in between the rib flanges... allowing me to buck the rivet (my tech counselor was quite impressed). I'd take a picture of it to show you but it's on loan to another builder.
Avery also sells a yoke with a tapered head that will work... but you're looking at $85.00.
Jeff Carpenter
40304
Wings/Forward Leading Edge
On Feb 27, 2006, at 3:27 PM, Dave Leikam wrote:
| Quote: | Probably an old question from a new -10 builder. How do you squeeze or set the rivet on the lower right side of the rudder (You know the one). I am considering using a blind rivet on both sides. Anyone? Thanks!
Dave Leikam
#40496
