Work bench size?
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> RV12-List
PostPosted: Mon May 12, 2008 6:34 am    Post subject: Work bench size? Reply with quote
I am getting ready to build a work bench to use for constructing the RV-12. What is an ideal size? I was thinking 4' x 12'. Is that too wide or too short? What do you think is best?
Thanks, Joe
- The Matronics RV12-List Email Forum -
http://www.matronics.com/Navigator?RV12-List
Joe Gores
jdubner(at)yahoo.com
PostPosted: Tue May 13, 2008 5:32 am    Post subject: Work bench size? Reply with quote
Joe
I think 4 feet is too wide -- it's too hard to reach across. I'm happy
with the 3' X 8' overall top surface dimensions for my RV-8A project
table. Two smaller tables are handier than one large one so build
another (later) if you underestimate your needs.
I (along with many builders over the years) built a "standard EAA
Chapter 1000 workbench". I don't think you can go wrong with it and all
the details are already worked out for you. Click on the "Work Table
Plans" link near the top of this page to see the details.
http://www.eaa1000.av.org/technicl/worktabl/worktabl.htm
As I mentioned, I modified the dimensions to make mine 3' X 8'
(including overhang). I also made a couple of modifications (suggested
to me by others) that I'm very pleased with:
1. Allow enough overhang of the table top surface on all sides to allow
for clamping.
2. Put the table on casters (locking preferred) so it can be moved.
Even if you have a fixed location for it, sooner or later it'll need to
be moved and the thing is HEAVY!
Best Regards,
Joe
Long-EZ flying, RV-8A building
http://www.mail2600.com
Time: 07:34:00 AM PST US
Subject: Work bench size?
Thanks, Joe
PostPosted: Wed May 14, 2008 5:46 am    Post subject: Work bench size? Reply with quote
Joe Dubner,Thanks for input on table size. And the EAA plans will help too.
Joe Gores
Joe Gores
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> RV12-List All times are GMT - 8 Hours
