AV8ORJWC
Posted: Fri May 09, 2008 2:19 pm Post subject: Experience with ethanol blended gasoline |
No. It deals with the lead within the air/fuel mixture (and works at
higher temperatures) but lead which settles out into the oil begins to
coat internal parts in the engine. The clutch is particularly
susceptible.
John.
Float Flyr
What I've read about TCP, all within the past nine months, is it works
really well to keep the top end of the cylinder clean. That means it will
be a great boon to the folks flying anything four stroke.
Two stroke engines are a bit of a different animal... They have roller
bearings on the crankshaft that are exposed to unburned gas. TCP has to be
burned to work and in the base of a two stroke engine there isn't any
burning going on so it will not protect your engine from lead deposits
building up on the main bearings which can cause those bearings to fail. It
will help stop plug fouling and will help keep crud out of your ring gaps
but you will never know when you may get a main bearing lap.
If there is anyone out there who knows how to precipitate the lead out of
100ll please let us all know.
Now I'm thinking out loud ... why not get the appropriate governments
departments to authorize a lead free, ethanol free aviation gasoline. Call
it 95NL (No lead) and make it a consistent formula so you will get the same
gas whether you live in Anchorage, Ottawa, Omaha or Adelaide.
Noel
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Float Flyr
Posted: Fri May 09, 2008 2:59 pm Post subject: Experience with ethanol blended gasoline |
Fortunately for you the chances you will see a phase separation in Arizona
with all its rain, snow, fog and sleet I'd expect to be slim. Too bad the
guys in Nova Scotia, Maine, Connecticut or Washington can't say the same.
BTW when you do get a phase separation (E10) you will get no less than 10%
of your fuel on board separate into water/eth from the gas... So if your
plane has 20 gal aboard and you get a phase separation expect to see a bit
over 2 gal of water in the bottom of your tanks right where the fuel pickup
is. That is one of the dangers of ethanol contaminated fuel there is really
no way, short of doing an on the spot titration, factoring in delta t (temp)
of determining how close you are to a phase separation... If you drip your
tanks/sumps and get any water, you will get a lot of water. Maybe not
enough to sink the Titanic but it will seem to be that much and sure as
there is little green apples, you will get enough water/ethanol mix to stop
any infernal combustion engine.
You might be amazed at how much moisture the eth will absorb in one cool dew
laden night Especially if the tanks are less than full.. In a week you
could easily have enough to cause a phase separation. When you buy your gas
at the service station there is no way for you to check exactly how much
moisture it contains. In other words its like a time bomb... It may never
go off but if it does you have no way of telling when.
If you use this crud in your car a good idea would be to keep the tank
topped up at all times so there is much less space for condensation to form.
Also be sure to only by contaminated fuel from high volume outlets
Noel
Kitfox III-A
gfmjr_20(at)hotmail.com Guest
Posted: Fri May 09, 2008 3:34 pm Post subject: Experience with ethanol blended gasoline |
Noel--
I do not know if you fly a rotax engine. It does not sound like you do. I have been flying both two stroke and four stroke Rotax engines for about 8 years. Most of the flying has been in Maine and New Hampshire and we have been using ethanol based fuels for at least have that time with no problems.
Not that I particularly wanted to used it but it was convienent.
I have never had a phase separation and I do fly year round. Altittudes are usually 1500 to 6000 feet with a few flights at 9-10000 feet. In fact, I do not know of anyone in this area experiencing what you are concerned about. As is good preflight practice, I do check my sumps and gascolator before each flight. The little water I see is usually due to condensation. I do agree with you on the condensation possiblities, especially in the early spring and fall in New England. Common practice is to keep the tanks topped off to avoid the condensation.
Everyone has to evaluate their own issues for each flight, I just think on this point you might be a bit over concerned, at least when dealing with Rotax engines.
George may
601XL 912s
[quote] From: noelloveys(at)yahoo.ca
To: rotaxengines-list(at)matronics.com
Subject: RE: Re: Experience with ethanol blended gasoline
Date: Fri, 9 May 2008 20:25:40 -0230
--> RotaxEngines-List message posted by: "Noel Loveys" <noelloveys(at)yahoo.ca>
Noel
Float Flyr
Sorry... I hit the send button before checking my data.
You will find the data at
http://www.epa.gov/otaq/regs/fuels/rfg/waterphs.pdf
Phase separation from E10 gas occurs when the water reaches .5% water by
volume at 60 F
For 20 U.S. gallons that is .1 gallon or 3.2 OZ. + 2 gal of ethanol.
There is a graph there that shows at 60 F and 4.5% water by volume a phase
separation will not occur but lower the temperature a measly ten F to 50
degrees an you will have a phase separation. Funny how the temperature
tends to drop as the altitude increases. With fuel so laden with moisture
you will probably experience a phase separation inside the carb which can
show itself as carb ice. Once separated it will not dissolve again when the
temperature increases to 60 F again.
Noel
Kitfox III-A
rparigor(at)suffolk.lib.n Guest
Posted: Fri May 09, 2008 4:24 pm Post subject: Experience with ethanol blended gasoline |
As far as flying with Ethanol laced mogas at altitude, in the event the
Ethanol absorbed a reasonable amount of water to make it close to
saturated, whats thoughts on adding some pure Isopropyl alcohol? Would
that not ward off phase change a bit?
I owned a 1948 C-170, the right tank drain was not at absolute lowest
point due to fact that too much weld was used during addition of tank
drain. No matter how careful would raise a wing and let sit and drain,
after 3 hours of flying water droplets could (and did several times) make
their way into gasculator and quit motor for longer than I cared for.
Twice a year changing of O-Rings on fuel caps did not cure. Twice a year
changing of O-Rings and addition of 1.5 quarts (33 gallons of fuel) of
Isopropyl Alcohol if even 1 drop of water was found worked for me for 15
years.
Ron Parigoris
Float Flyr
Posted: Fri May 09, 2008 4:50 pm Post subject: Experience with ethanol blended gasoline |
FAA doesn't say not to fly above 10,000 ft with any engine I know of. But
the last poster did say the chances of vapour lock while using ethanol
contaminated fuel increased above 10,000 ft. I think that becomes a problem
for guys living in mountain locales.
I have already had warrantee work completed on my 582-UL and except for the
six weeks or so I was without an engine I have no complaints.... BTW in
that six weeks I may have been able to fly only once. Bob Robertson, who's
company is a Canadian Rotax repair depot has been a wealth of info and so
far has not steered me wrong. So I think I'll keep my warrantee for the
time of being.
You do have a point though starting is absolutely the worst thing you can do
to any piston engine. Turbines go from bad to worse.
Noel
Kitfox III-A
Float Flyr
Posted: Fri May 09, 2008 6:04 pm Post subject: Experience with ethanol blended gasoline |
George:
On one occasion I had a snowmobile that, I found out later had ethanol put into the tank to dry up some snow that accidentally got into the tank. The next year I had the worst mess I’ve ever seen in my tank. Moisture and condensation in the tank was absorbed by the ethanol and when fall weather came around the darn stuff had a phase separation. At the time I had no idea what caused it but I saves some in a coffee jar. A friend who owned a commercial lab told me exactly what happened. Having it happen in a parked snowmobile is one thing but having it happen in a plane at altitude ... no thanks.
The problem with ethanol fuel is there is no way to tell how much moisture there is in the fuel. Unless you have a sealed pressurized fuel system and you supplier has the same you can be sure you will have some moisture in your fuel... The question is how much. The answer is impossible to tell until it separates. This is not a problem explicitly for Rotax engines that is why the FAA will not endorse the use of ethanol contaminated fuels for any aircraft. On this point I back them 100%
What I’m saying is there is enough things to go wrong while flying. Being very familiar with Mr. Murphy and his Law, I personally like to minimize the number of things that can go wrong. Ethanol free fuel is a step in that direction. As I said with a sealed CO2 pressurized fuel system and fuel injection and a good fresh source of gas even corrupted with ethanol you’re probably as safe as anything flying. As far as I know they don’t like pressurized fuel systems anywhere in aviation so the only other safe option is to avoid ethanol contaminated fuel.
I realize that is not always convenient so the answer is to lobby for a safe supply of unleaded, non ethanol fuel that is as consistent as 100LL. I’ll bet if you could get such a fuel at your FBO that’s what you’d be using.
As I said last night, I feel a bit guilty talking about this because the chances I’ll have to put up with ethanol contaminated fuel here are about the same as a snowball in hell. It’s the next thing to logistically impossible to get the stuff here what little has arrived here (E5) got a bad rep as poor fuel and had to be diluted down with real gas. The owners of the ship were not impressed with the fact they were carrying ethanol either. I guess we Newfoundlanders will have to be content to imbibe our ethanol after flying... in Rum, Gin or Scotch. If we ever run out of that there is always beer J.
Noel
From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of george may
Sent: Friday, May 09, 2008 8:58 PM
Noel--
George may
601XL 912s
> Noel
Kitfox III-A
Float Flyr
Posted: Fri May 09, 2008 6:11 pm Post subject: Experience with ethanol blended gasoline |
Addition of even more alcohol will stave off phase separation a bit. The
question is how much extra to add and how much moisture is already in the
fuel? My idea is the answer is to that best not to have any moisture in the
fuel that precludes any alcohol in the gas.
I'll bet your A&P and the local FAA didn't know you were using alcohol in
your fuel... They would not have been impressed.
Noel
Kitfox III-A
henry.voris
Joined: 02 Mar 2007 Posts: 116 Location: Pueo Field, Kula, Maui
Posted: Fri May 09, 2008 11:38 pm Post subject: Re: Experience with ethanol blended gasoline |
I had some questions about ethanol, fuel and Mr.Funnel, so I ran some tests...
I used two sample jars, each containing 1,000 cc of fuel (Gasoline/10% Ethanol).
Jar #1: I would add to the fuel 0.3 cc water. The water would form a small bead at the bottom of the jar. I would shake the jar vigorously and the water would dissolve, leaving the fuel a clear liquid.
I repeated this process 15 times... After adding a total of 4.5 cc's of water the fuel became cloudy and began to show signs of phase separation. I continued the water process twice more, (to 5.1 cc's) just to get a good phase separation going.
After observing phase separation between the fuel and the ethanol/water, I shook the jar vigorously to mix the whole mess up again and poured it through my Mr.Funnel. I saved the residue from the trap in a separate sample jar.
Shortly the concoction cleared and there was a big blob of ethanol/water at the bottom of the fuel jar... It had passed right through my Mr.Funnel. Bummer... The fuel from the trap looked the same as the fuel that had passed through the filter, both had water at the bottom.
Jar #2: I added 4.0 cc (just 0.5 cc less than the amount needed to start phase separation) of water to the fuel. The water formed a bead at the bottom of the jar. I shook the jar vigorously and the water dissolved into the fuel leaving it a clear liquid. I poured it through my Mr.Funnel. I saved the residue from the trap in a separate sample jar.
At sunset, some eight hours later the fuel was still crystal clear with no signs of phase separation, no signs of the water I had put in. The temperature during the day was between 70º and 75º.
At 0500 the next morning the temperature was 55º. And the fuel had separated. There was a clear blob of ethanol/water rolling around the bottom of the fuel jar. The fuel saved from Mr.Funnel's trap had separated also. The proportions of junk to fuel in the jar and in the trap seemed to be the same, leading me to believe the water passed through the filter with little to no restrictions.
I suspected that some of the moving parts in my Mr.Funnel were out of tune. I called a pal and even though he flies a Quicksilver, I was able to borrow his Mr.Funnel. I ran the above tests again, and I got the same results...
Conclusions:
Jar #1... Mr.Funnel will not separate the water from a "Gasoline/10% Ethanol" mix that has suffered phase separation. Both the fuel and the water/ethanol sludge pass through the filter.
Jar #2...
A. The "Gasoline/10% Ethanol" mix has the ability to absorb water in a way that is visually undetectable.
B. The water absorbed in this fuel will pass through Mr.Funnel with the fuel.
C. Fuel that has absorbed sufficient water, can suffer phase separation by simply lowering the temperature.
In short, it is possible to have fuel that appears to be good while on the ground. It can be run through Mr.Funnel... But if it is used to fly... it could cool enough to suffer phase separation in the tank. The unburnable ethanol/water mess will sink to the bottom of the tank.
Reality Check:
A. In a perfect world... If you chose a gas station that moves a lot of fuel... the odds of getting fuel with water is quite low. If the refinery to pump system is tight, the ethanol should absorb any stray water as it moves through the system. Thus the delivery system should contain no water at all.... I don't live in a perfect world.
B. I will continue to use my Mr.Funnel to trap all the other junk I keep finding in my fuel...
C. I ordered a gasolator.
Aloha,
Henry
Kolb FireFly Five-Charlie-Bravo
_________________ Henry
Firefly Five-Charlie-Bravo
Do Not Archive |
jd(at)lawsonimaging.ca Guest
Posted: Sat May 10, 2008 4:45 am Post subject: Experience with ethanol blended gasoline |
rampil wrote:
| Quote: | As for the fabled engine warranty, Rotax and every other engine
manufacturer provides a warranty that is pretty close to worthless.
They will assure that the engine runs when you get it (not when you
finish your plane) and after that, practically speaking, forget it.
Actually, the Jabiru warranty starts at the independently verified first
*flight*!
Regards, J.
flying: Zenith STOL CH701/912 C-IGGY, 500 hrs.
building: Sonex #325 (C-FJNJ), Jabiru 3300/6, 99% completed
J. Davis, M.Sc. (computer science)
*NIX consulting, SysAdmin
email: jd at lawsonimaging.ca
voice: 519.289.1527 http://www.cleco.ca
c/o Brandywine Aviation 5507 Irish Dr., Appin, ON
N42 47.33 W081 36.50 31/13 2000+ x 60', elev: 740'
To most people the sky is the limit.
To those who love aviation, the sky is home.
Thom Riddle
Posted: Sat May 10, 2008 4:45 am Post subject: Re: Experience with ethanol blended gasoline |
Henry,
Your careful study is very much appreciated. Now you know why Type Certificated Aircraft all have gascolators and they are also required by the ASTM standards for SLSA.
Another variable worth noting in the E-10 vs pure gasoline vs 100LL is the energy content and anti-knock qualities. See attached table. Note in particular the following:
1. Not all alcohols are the same
2. E-10 has less energy content than pure gasoline
3. E-10 has slightly more energy content than 100LL
80.79 KB |
620 Time(s) |
_________________ Thom Riddle
Buffalo, NY (9G0)
- Anonymous |
Float Flyr
Posted: Sat May 10, 2008 5:59 am Post subject: Experience with ethanol blended gasoline |
The Mr funnel relies on a SG differential in between the
gasoline and water to remove the water. When you introduce ethanol into the
equation you will set up a phase relationship, not quite a solution, between
the ethanol, water and gas this phased liquid will pass right through a Mr.
Funnel.
If you are keeping track of the temperature in your hangar and only fly on
warm days. If you didn't get a phase separation overnight then you probably
won't get a phase separation while you are flying if you don't go near your
overnight low temperature.
I would be interested in finding out how large the water bubble that
separated out was. Knowing that you will know how much water to expect if
you get a separation in flight.
I'd try it here but we fortunately don't have any ethanol laced gas here....
I suppose I could make my own but the only place to buy pure ethanol is the
liquor commission and you have to have a viable reason to purchase it. I
don't think experimentation will cut it.
Noel
Kitfox III-A
rsteele(at)rjsit.com Guest
Posted: Sat May 10, 2008 8:48 am Post subject: Experience with ethanol blended gasoline |
This has been an interesting discussion. What I don't understand, is
that if E10 is as unstable as claimed, how do cars use it? I've had
a car with a 1/2 tank of E10 sitting in near or below freezing
weather for weeks in damp conditions - often - and never had the
slightest problem. I don't live on a mountain, but I've never heard
of people that do having any problems either. This just doesn't gibe
with what I'm reading here.
Something else, ethanol and water mixed is flammable up to 50% water
(the historical reason behind 100 proof liquor being 50% alcohol).
That's not to say it would run an engine, but perhaps it should be
factored into the thinking.
There are obvious risks running E10 in a plane, but there are also
risks running 100LL in a Rotax - like you don't really don't know
what the 100LL is doling to your PRSU - probably the least reliable
part of the whole plane.
Great discussion.
Ron
into the
solution, between
through a Mr.
Funnel.
fly on
probably
near your
expect if
here....
ethanol is the
it. I
Noel
AV8ORJWC
Posted: Sat May 10, 2008 10:05 am Post subject: Experience with ethanol blended gasoline |
Parts which are still used in aircraft with a more primitive and yet
reliable ignition system couple to make use of Ethanol in aircraft a
"non FAA approved activity". Automobiles have replaced products
susceptible to ethanol damage and use sophisticated computer programming
for temperature, load and atmospherics to correct timing for
aberrations.
Aircraft fly at altitudes and in environments not suitable for
automobiles. When the auto suffers from too much contaminate, it starts
fouling plugs and the driver pulls over to the side of the road - then
calls a tow truck. The Reid pressure values are different and hence
greater likelihood of detonation, fuel system icing or vapor lock.
Lead contamination from 100LL used at less than 50% concentrations to
MOGAS has a calculated need for maintenance. I would not characterize
it as a risk. It is a known and ROTAX has factored it. Ethanol is an
unknown/variable and Phase Shift is a real phenomena. The difficulty
with aircraft is that the shelf life of 100LL is far greater than MOGAS.
MOGAS spoils. With the high volume at an auto pump versus a relatively
low volume at an airport near you, the risk from moisture is
geometrically greater. For those pilots flying classic aircraft with
EAA or Peterson STCs, they know the FAA does not approve of any presence
of ethanol. Their STC by choice of ethanol becomes invalidated. Regular
fuel testing is a requirement.
Oregon has discounted the significance of those pilots and mandated
ethanol into the entire delivery system. This year is going to show
those willing to wait the risks at running with ethanol. Be patient, it
is a known.
VP Legislative Affairs - Oregon Pilots Association (and blamed for the
passage of this poor legislation)
ROTAX certified technician
Catz631(at)aol.com Guest
Posted: Sun May 11, 2008 3:44 am Post subject: Experience with ethanol blended gasoline |
Henry,
Thanks for the excellent testing you did. You gave a lot of insight into the relationship of alcohol and water. Nothing beats a backyard test in my book!
Dick Maddux
Pensacola,Fl
Wondering what's for Dinner Tonight? Get new twists on family favorites at AOL Food.
Float Flyr
Posted: Sun May 11, 2008 4:53 am Post subject: Experience with ethanol blended gasoline |
Cars now have sealed fuel systems.. That's why they have the warning on the
fuel cap to remove slowly... Planes don't. If you get old fuel or there is
a leak into your gas stations tank which allows a bit of water into the
underground storage facilities you can get a phase separation over a cold
night. In a car , no problem, maybe a little walking. In a plane... keep
up on forced approaches.
As for vapour lock. Aircraft engines tend to live at better than 75% power
for hours at a time. Even in the mountains cars won't run at 75% power for
more than two or three minutes at a time. The other factor is just how many
roads run for miles at better than 10,000 feet? As you can see your
airplane engine lives in a completely different environment than your car.
I've had a phase separation in a snowmobile... believe me it won't burn.
To burn in an engine I believe the minimum is 150 proof, around 75% by
volume.
Certainly the 9xx series Rotax engines share oil with the PSRU and the Lead
is definitely not good for it. The Rotax two strike engines have roller
bearings on the crank shaft and lead can plate out on to the roller bearings
and cause the main bearings to fail... Bad news!
Instead of rolling over and saying this is just something else we have to
live with we should be lobbying every which way we can for a clean supply of
non lead fuel for planes. Twenty years or more ago that's what they did
with the introduction of 100LL for certified aircraft.
Hope this helps.
Noel
Kitfox III-A
Float Flyr
Posted: Sun May 11, 2008 6:24 am Post subject: Experience with ethanol blended gasoline |
Well laid out, well said!
It doesn't sound like you were in any way responsible for the legislation.
Increased lobbying is the only answer I can see. In the short term make
fuels sold at airports, not accessible to road traffic and not applicable to
aircraft. In the long term junk the whole idea of ethanol as an alternative
fuel.
What I can see is, after a few fatalities, states may outlaw the use of
MOGAS in any aircraft. In other words get caught with MOGAS in your planes
tank after an accident and your insurance, life insurance and or drivers
license is cancelled. To protect themselves I understand several gasoline
outlets already have pump signs up, "Not for aviation use."
Noel
Kitfox III-A
AV8ORJWC
Posted: Sun May 11, 2008 7:34 am Post subject: Experience with ethanol blended gasoline |
The request in Oregon through the Department of Agriculture was a complete exemption of ethanol in Unleaded 92 Octane Mogas - Premium. The oil lobby said 100% distribution of ethanol or no deal. The 92 exemption was supported by auto collectors, STC aviators, classic boat owners, recreators and First Responders across the board.
Next year is a new legislature.
AV8ORJWC
Posted: Sun May 11, 2008 7:36 am Post subject: Experience with ethanol blended gasoline |
They wanted a dog to kick and every legislator that vote AYE wanted to
hide. This was a bill that was introduced by the Governor in 2005 and
soundly defeated. He snuck it through in the 2007 Bi-ennium and now it
is policy.
Lobby, lobby, lobby.
Traveling through Oregon in 2008, aviators should diligently monitor
fuel quality. Stay Safe.
