Dana
Posted: Wed May 07, 2008 5:56 pm Post subject: Ultrastar aileron bellcrank? |
I've seen several references to cracking and failure of the Ultrastar
aileron bellcrank and a recommended modification, but nothing on exactly
what the fix is. I'm pretty sure mine doesn't have this fix, which makes
me nervous... does anybody (John Hauck?) have drawings or photographs of
the modified part?
Would love to see pix of the inboard wing spar collar mod too...
-Dana
Resist militant "normality" -- A mind is a terrible thing to erase.
Posted: Wed May 07, 2008 6:24 pm Post subject: Ultrastar aileron bellcrank? |
| Quote: | aileron bellcrank and a recommended modification, but nothing on exactly
the modified part?
-Dana
Dana:
There are two aileron bell cranks on the US. The upper and a larger complex
one the aileron push/pull tubes connect to attached to the boom.
I had a failure of the upper, the small one above the lower bell crank. My
fuselage was welded at the factory. The small tube brace was not welded to
stabalize it. Homer felt it was not needed on the factory cages. The plans
clearly show a small tube strut welded to the rear of the upper aileron bell
crank and was meant to be used by those builders welding their own kit.
The large bell crank on the bottom of the boom tube pivots on a 1/4" bolt
welded to a curved plate and riveted to the boom, IIRC. I have the old US
plans somewhere. They show in detail all this stuff. I put a Z brace made
of 4130 strip to the bolt end after the bell crank was installed, riveting
it to the boom. I did not like all that lateral stress on a bolt welded and
braced on one end only.
My 1984 US did not have a collar on the inboard rib. It used two 4130 tubes
inside the main spar. Did not do much to prevent wing twist. Heavy aileron
input would be canceled out by the wing twisting. The old US had to be
flown gently or one could get into trouble.
_________________ John Hauck
Titus, Alabama |
Dana
Posted: Wed May 07, 2008 7:06 pm Post subject: Ultrastar aileron bellcrank? |
At 10:22 PM 5/7/2008, John Hauck wrote:
| Quote: | There are two aileron bell cranks on the US. The upper and a larger
complex one the aileron push/pull tubes connect to attached to the boom.
crank. My fuselage was welded at the factory. The small tube brace was
not welded to stabalize it. Homer felt it was not needed on the factory
cages. The plans clearly show a small tube strut welded to the rear of
the upper aileron bell crank and was meant to be used by those builders
John, thanks, I see it now... it's a 1/4" tube running diagonally from the
vertical tube that drives the rear crank to the horizontal tube that's
driven by the pushrod from the control stick torque tube. Definitely not
on mine, and not easy to weld in place, either, since the assembly can't be
removed from the fuselage. Hmmm, perhaps a bolted bracket between the
bolts holding the rod ends?
| Quote: | The large bell crank on the bottom of the boom tube pivots on a 1/4" bolt
made of 4130 strip to the bolt end after the bell crank was installed,
riveting it to the boom. I did not like all that lateral stress on a bolt
welded and braced on one end only.
I don't like it, either. Now that you mention it I see that brace is on
the plans as well (and not on my plane). At least that one's easy to retrofit.
| Quote: | My 1984 US did not have a collar on the inboard rib. It used two 4130
tubes inside the main spar. Did not do much to prevent wing twist. Heavy
aileron input would be canceled out by the wing twisting. The old US had
to be flown gently or one could get into trouble.
The one day I flew the plane in excessive turbulence I could see the wings
twisting. That seems like a less urgent change, though.
-Dana
CanYouFixTheSpaceBarOnMyKeyboard?
jb92563
Joined: 23 Mar 2007 Posts: 314 Location: Southern California
Posted: Thu May 08, 2008 11:27 am Post subject: Re: Ultrastar aileron bellcrank? |
Hmmm....better check my bellcranks out as well.
Wing twisting around the main spar tube?.....yikes
I hope it had a dampening effect on the turbulence inputs and not a divergent effect.
Still working to get airbourne with my US.
Just need to take the engine out and pressure test to see why the Fan side front cylinder is running hot, this weekend.
If I can't solve it, the Cuyuna 430 is going in the UL-202's place until I get it rebuilt.
Once that is resolved I'm going flying at my Test Pilot area, El Mirage Dry lake.
Thanks for the good heads up Dana and John.
_________________ Ray
Moni MotorGlider
Schreder HP-11 Glider
Grob 109 Motorglider
Do Not Archive |
jb92563
Posted: Thu May 08, 2008 11:40 am Post subject: Re: Ultrastar aileron bellcrank? |
I was thinking about the wing twisting and wondered if a second wing strut from the trailing edge to a couple feet before the existing struts wing attach point would help.
Sortof like a Y branch off the main strut going to the trailing edge, and clamped on to avoid putting holes and weakening the main strut.
Perhaps the twisting is not really a big problem except in extreme conditions?
I suppose the Kolb's wings have been twisting this way for some time already with out any detrimental effect?
Moni MotorGlider
Do Not Archive |
Posted: Thu May 08, 2008 12:08 pm Post subject: Ultrastar aileron bellcrank? |
conditions?
Ray
Ray:
The problem was corrected by replacing the two internal tubes off the
inboard rib with a collar. Really stiffened up the Kolb wing in twist.
I would not attach a strut from the trailing edge if it were my airplane.
The trailing edge is not a spar, nor is the leading edge.
The wing twist when the ailerons are operated. The more aileron input the
more wing twist. Wing twist cancels out aileron input. Yes, one could get
into trouble in some situations. The Firestar was a great improvement over
the US in this respect.
I wouldn't bet my butt on your last statement above.
Titus, Alabama |
Dana
Posted: Thu May 08, 2008 3:44 pm Post subject: Ultrastar aileron bellcrank? |
At 03:40 PM 5/8/2008, jb92563 wrote:
| Quote: | I was thinking about the wing twisting and wondered if a second wing strut
As John H. said, I don't think that'd be a good idea. Adding a collar
seems to be the better fix:
http://tinyurl.com/5krl9m
| Quote: | Perhaps the twisting is not really a big problem except in extreme conditions?
Except for the fact that the US's roll rate is not breathtaking, I don't
think it's a big deal. I haven't heard of any failures due to the
twisting. Only once, flying in turbulent conditions that I wished I hadn't
taken off into, did I actually see the effect. I may look into the collar
if I have to open up the wings for any other reason. The aileron bellcrank
fix I'll do as soon as the tubing arrives.
-Dana
Refuse Novocain... Transcend Dental Medication.
Posted: Fri May 09, 2008 3:27 am Post subject: Ultrastar aileron bellcrank? |
Dana,
There is a solution to the problem of slow roll rate and wing twist.
Shorten the chord of the aileron. This will reduce aileron dynamic loading
so that ailerons can be more easily displaced. And at the same time it
reduces the amount of twisting moment which the aileron subjects the wing
for a given aileron tip displacement. This in turn removes significant load
from the aileron control mechanism.
I built one of the early FireFlys and after flying it a few hours, I reduced
the aileron chord to nine inches. As a result, I have a FireFly that is
very light on the controls and it flys like a P-51 if you keep the speed up.
No trouble flying in the middle of the day or during windy conditions, and
I can fly it cross country in the middle of the day with out a sore shoulder.
Jack B. Hart FF004
Winchester, IN
Dana
Posted: Fri May 09, 2008 3:45 am Post subject: Ultrastar aileron bellcrank? |
At 08:14 AM 5/9/2008, Jack B. Hart wrote:
| Quote: | There is a solution to the problem of slow roll rate and wing twist.
from the aileron control mechanism...
Shortening the aileron chord would certainly reduce control forces, but it
won't increase the roll rate for a given aileron deflection. It takes a
certain amount of aerodynamic force to cause a certain roll rate; with less
aileron you need more deflection to achieve that same force. I don't have
a problem with the stick force. The real solution, as John H. and others
have pointed out, is to reinforce the wing spar attachment.
I'm currently not up for a project as large as rebuilding the ailerons. If
I was, I think I'd leave the chord alone but split them, and make the inner
half into flaps... but that's a project for another year.
-Dana
Campaigns to bearproof all garbage containers in some national parka have
been difficult, because as one biologist put it, "There is a considerable
overlap between the intelligence levels of the smartest bears and the
dumbest tourists."
Posted: Fri May 09, 2008 3:49 pm Post subject: Ultrastar aileron bellcrank? |
At 07:42 AM 5/9/08 -0400, you wrote:
Dana,
You are correct in that a shorter chord aileron will not provide the same
roll rate as a longer chord aileron for the same angular displacement.
If one cuts the aileron chord in half, you have to about double the
displacement to get the same change in lift for the same air speed. In
doing this the center of pressure of the short chord aileron will be at
one-fourth as apposed to one-half the chord for the full chord aileron. If
one flys both ailerons at the same speed the full aileron dynamic load will
be 1.2 times that of the short aileron. This means the bell crank torque
required to hold the full aileron in position will be 2.4 times that of the
half chord aileron.
All of the above would be true if the wing was perfectly stiff. But in
reality, the tail of the wing kicks up and lowers the relative AOA from what
it should be. And so one will see a slower roll rate from the full aileron
than the half chord aileron. If you want to reduce wing warping use shorter
chord ailerons with greater displacement.
Adding a steel root rib as used in the FireFly does nothing for the main
spar attachment point but it will help to transfer some of the twist load to
the wing rear attachment point. But it will not completely stiffen the
whole wing. High roll rates at speed will still warp or twist the wing.
Fly safe
Jack B. Hart FF004
Winchester, IN
Dana
Posted: Fri May 09, 2008 5:06 pm Post subject: Ultrastar aileron bellcrank? |
At 08:35 PM 5/9/2008, Jack B. Hart wrote:
| Quote: | If one cuts the aileron chord in half, you have to about double the
OK, I'll buy that. Not sure it's really linear but let's go with it.
| Quote: | If one flys both ailerons at the same speed the full aileron dynamic load
will
half chord aileron.
Where do you get the 1.2 from... and thus the 2.4?
If you have to move the aileron twice as far to get the same effect (same
aerodynamic force), but the moment arm to the center of pressure is halved,
then the torque applied to the aileron is also halved. However, you have
to move the stick twice as far (not possible on the US, at least not on mine).
To get the same control authority for a given stick deflection, then you
have to adjust the control linkage to get double the aileron movement for
the same stick deflection, which multiplies the torque by a factor of
two... net result, same stick force.
| Quote: | All of the above would be true if the wing was perfectly stiff. But in
I don't see that at all. If the rolling force (regardless of the aileron
size) is the same, then the amount of twist it causes in the wing should be
the same.
| Quote: | Adding a steel root rib as used in the FireFly does nothing for the main
The modification suggested for the US is not a steel root rib (which it
already has), but a collar to reinforce the main spar attachment to the
root rib, keep the spar tube round, and keep the spar from twisting...
though I'm not convinced how the modification, as I understand it, would
help that much.
-Dana
If at first you don't succeed, skydiving is not for you.
Posted: Fri May 09, 2008 7:43 pm Post subject: Ultrastar aileron bellcrank? |
what
aileron
shorter
to
Fly safe
Jack B. Hart FF004
Jack H:
I have a feeling you don't know what you are talking about. You say, "But
in reality, the tail of the wing kicks up and lowers the relative AOA from
what it should be." How do you know this is reality? Have you been there
and done that?
I believe I tried previously to explain what actually happens to the early
model US wing when the ailerons are actuated. The entire wing twist with
the main spar because the main spare "oil cans". The two internal tubes
butt welded to the inboard rib, then riveted to the inside of themain spar,
top and bottom, can not keep the main spar in its original round shape.
This effectively cancels out all the aileron input. No, it does not happen
as the result of docile control input. One has to be a bit agressive to
twist the wing.
Old Kolb discovered there was a better way to attach the main spar to the
inboard rib, thus, the 4130 ring. Some models the ring slipped inside the
main spar and some models the spar slipped inside the ring. My FS had the
ring and it fixed the problem. No more wing twist when the ailerons were
actuated.
To the best of my knowledge, all the subsequent model Kolbs, after the early
US, do not suffer from wing twist. The problem was solved.
Titus, Alabama |
Posted: Wed May 14, 2008 6:35 pm Post subject: Ultrastar aileron bellcrank? |
Dana & List,
I apologize for tossing out some numbers with out explanation. I used a
quick graphical solution to come up with relative numbers for an aileron
one-half the chord.
It rained today so I worked up a similar graphical approach to match the
modifications I have made to the FireFly. The results can be seen at:
http://www.thirdshift.com/jack/firefly/firefly139.html
I inserted some responses below.
At 08:57 PM 5/9/08 -0400, you wrote:
If your maximum aileron down deflection is 20 degrees, there is more than
enough stick deflection.
| Quote: | To get the same control authority for a given stick deflection, then you
In my case, I was able to reduce "Tee" hole spacing to gain greater
mechanical advantage and therefore reduce stick force required.
the same.
All that extra effort that you have to exert to deflect the aileron has to
go some where. Some of it goes into twisting the aileron torque tube. The
rest and probably most of it goes into twisting the wing ribs about the main
spar.
help that much.
In the FireFly, there is one pin through the main spar attachment point to
the cage. Also a second through the rear wing universal attachment point.
And two more through the wing struts. The only thing that keeps the wing
from kicking up in the back with down aileron is the most inboard steel rib.
This leaves the outboard portion of the wing to progressively twist up
under this condition. Since the airfoil lift profile usually centers over
the main spar this twist is not usually harmful.
I hope this helps to explain why reasonably small ailerons may be of
benefit. Would I change back? No way!
Jack B. Hart FF004
Winchester, IN
