h&jeuropa
Posted: Thu May 08, 2008 10:16 am Post subject: Fuel Sight Gague Tubing |
During the repair of our Europa, I replaced the fuel system tubing and sight gauge tubing which was original. It was getting hard and discolored. I used Tygon F4040 tubing which the data sheet says is gasoline tolerent.
After doing all that, I had reason to inspect a section of Tygon F4040 that serves as the siphon hose in the main fuel tank when the Europa Aux fuel tank is fitted. That Tygon was discolored and quite hard after being in place for a couple of years. This is making me wonder about my use of it elsewhere in the fuel system.
What tubing have others used with success for fuel tank venting and fuel sight gauge?
Jim & Heather
N241BW
loboloda(at)execulink.com Guest
Posted: Fri May 09, 2008 6:11 am Post subject: Fuel Sight Gague Tubing |
Jim & Heather.
I've had no luck with any of the flexible plastic tubing.
As far as possible, I have replaced it with auto fuel injector hose.
Aircraft Spruce list clear PVC pipe, used in Quickie as fuel level
gauge, p/n 03-54100,
however the diameter is larger, and I could not see an easy way of
plumbing it in
without risking a further source of fuel leakage.
Dave
gasoline tolerent.
fuel sight gauge?
Jim & Heather
N241BW
http://forums.matronics.com/viewtopic.php?p=181965#181965
