longg(at)pjm.com Guest
Posted: Thu May 08, 2008 8:19 am Post subject: Z-19 Item Clarification |
Thanks for converting Larry.
Scott, you broke the simplification rule, but not the experimental one.
Starting from the grip, wow that's a bit lazy Looks good, thanks for
posting. The always hot deal for the fuel pumps/EFI/ECU is not a bad
thing on these Subes. Do you have a layout of your panel switches?
Glenn
sshook(at)cox.net Guest
Posted: Thu May 08, 2008 8:30 am Post subject: Z-19 Item Clarification |
Here is the PDF
Scott R. Shook
RV-7A (Building)
N696JS (Reserved)
Description: |
 Download |
Filename: |
N696JS_-_Electrical_Layout.pdf |
Filesize: |
300.5 KB |
Downloaded: |
544 Time(s) |
Posted: Thu May 08, 2008 9:34 am Post subject: Z-19 Item Clarification |
I am confused...Simplification rule starting from the grip? Are you talking
about my use of the infinity grips?
Scott R. Shook
RV-7A (Building)
N696JS (Reserved)
Allen Fulmer
Joined: 10 Jan 2006 Posts: 79 Location: Alexander City, AL
Posted: Thu May 08, 2008 10:22 am Post subject: Z-19 Item Clarification |
Scott,
I feel a little inadequate to make any comments except that I am trying to
do the approximately the same thing you are (RV7 with Egg Subaru) and I
might as well go public with my questions now.
These are in no order of importance and are just my first questions after
looking over the drawing:
(I have sort of ignored the annunciator part of the diagram as I have not
thought much about how I might do those.)
1. The extra starter solenoid is required only because you will have a
little bitty pushbutton on the grip. I used to think that would be a good
idea so you didn't have to take your hand off the stick when starting but I
think with our automotive engines it probably is not a problem to reach for
a pushbutton on the panel. Egg manual notes that it is not necessary
(additional starter relay) unless you have a wimpy key switch or stick push
button like you plan. I have seen it suggested to put an "ARM" switch on
the panel so you are not inadvertently pushing the little button when the
engine is already running, etc. I "want badly" (for unknown reason) to have
an automotive style key switch to energize the starter but may finally go
with the panel mounted 20 amp push button.
2. As I understand the function of the LV Monitor module, it is wired up on
Z19RB to energize the Engine/AUX Battery Contactor (not the MAIN Battery
Contactor) but only when the Engine/Bat Off/On/Auto is in the AUTO position.
I think you need a switch like Bob depicts on Z19RB to accomplish this. As
you have it now the contactor will always be energized if you have your
switch in the up position (connected to ground) and the LV Monitor module
will do nothing.
2. (continued) I think I have decided that since we are adopting a somewhat
more manual system of switching batteries using the Egg recommended (Engine)
Bus Master Switch we can manually open the Main Battery Switch and close the
Aux/Engine Battery switch and not even worry about the LV Monitor module.
We would still want a "genius" light (as Bob calls them) to alert us when
the bus voltage drops below 13 Volts (or whatever his stuff recommends) so
we know the Alternator is off line.
3. I guess you are calling your Endurance Bus the Avionics Bus but it
appears to me that if you lose the Main bus ALL your avionics are without a
source of power. Notice that Bob has an Ebus Alt Feed switch that powers a
S-704-1 relay to feed the Endurance Bus (Avionics Bus in your case) from the
always hot Main Battery Bus. Similar to the way we use 4NT1-1 Engine Bus
Master switch select the "alternate feed" from the always hot side of the
AUX Battery.
4. One of the things I am wrestling with is how to power the engine
instruments (GRT EIS4000 in my case; AFS3500 EMS in yours) so ONLY it comes
on when the Engine Bus Master Switch is placed in either ON position. (To
check oil pressure light working and to see the oil pressure come up when
engine starts.) That may require an Avionics Switch/Relay since the starter
requires/prefers to have both Battery Contactors energized. Still thinking
about that issue.
So there; now I have exposed some of my ignorance for the world to see.
Keep talking, Scott.
Allen Fulmer
RV7 Subaru E6Ti hanging
Working on wiring/avionics
Alexander City, AL
[quote]>>--
_________________ RV7 QB Fuselage
Eggenfellner H6 on orde
N808AF reserved
Alexander City, AL |
klehman(at)albedo.net Guest
Posted: Thu May 08, 2008 1:07 pm Post subject: Z-19 Item Clarification |
FWIW you might consider that you simply don't have the oil pressure
issues that air cooled engines have with single grade oil. I run 5W50
synthetic and I pretty much ignore the oil pressure just like most car
drivers. If it doesn't come up or if it goes out of limits, the EIS will
bring it to my attention. The chances of a secondary failure where the
EIS would be helpful, at the same time as an alternator failure, have
got to to be very small. Keeping it simple has advantages. Do you really
care if the EIS works after an alternator failure? Will it help you fly
the airplane or just be a distraction?
Ken
about that issue.
Allen Fulmer
Posted: Thu May 08, 2008 1:36 pm Post subject: Z-19 Item Clarification |
Thanks Ken,
One of the reasons for turning on the EIS before starting the engine is to
make sure the oil pressure sensor DOES work like it is supposed to. But you
make a good point. Maybe the light could be checked when shutting DOWN the
engine before the EIS is turned OFF? Thoughts?
Allen
[quote]>>--
N808AF reserved
bbradburry(at)bellsouth.n Guest
Posted: Thu May 08, 2008 2:44 pm Post subject: Z-19 Item Clarification |
Scott, I am the last person who should be talking about someone else's
electrical design....
But, I can see your reason for the 200ANLs in front of the batteries, but
you are also protecting the "B" lead of a 60A alternator with a 200ANL...are
you thinking that the alternator itself might somehow short to ground? I
think that ANL is to protect against a runaway alternator and if so, 60A is
all you need.
Also, is that low voltage module just supposed to turn on a light? I think
that relay is to automatically turn on your aux battery in case of low
voltage, if so, I think that the way you have it wired will turn your main
battery contactor back on when you turn it off??? I am willing to be wrong
about this as I speak electric only through an interpreter. :>)
Bill B
Posted: Thu May 08, 2008 3:23 pm Post subject: Z-19 Item Clarification |
I see what you are saying. I was under the impression that the low voltage
module was to measure and warn of low voltage only. I was not aware that
activating the contactor was a function. If that is the case, you are
correct - I would not be able to isolate the Main Battery.
This is precisely the reason I am asking for reviews.
Scott R. Shook
RV-7A (Building)
N696JS (Reserved)
Posted: Thu May 08, 2008 6:36 pm Post subject: Z-19 Item Clarification |
Allen
My EIS comes on any time the master switch is on so it is on before
startup. However I elected not to provide any other power source for it
so it does go dead if I turn off the master switch.
The warning light flashes for everything outside of spec which means you
can cancel them one at a time to confirm they are working. However I
normally just start the engine which removes all the warnings except low
coolant pressure.
At shutdown the warnings come back on for low voltage and low oil
pressure which can again be canceled one at a time as you suggest.
However if the oil pressure indicated normal at any time while the
engine was running, it is very unlikely that the low pressure warning
will not work from the EIS. You can also set the low oil pressure
warning such that it will come on at slow idle just before shutdown (if
the oil is up to temperature). In my case I also wired a small light to
the low pressure switch that was already installed in my stock engine.
The engine is my own conversion and I run a modified Z-14 architecture
with two small alternators and two very small 8AH batteries. The system
actually weighs less than many single alternator single battery
installations.
Ken
Allen Fulmer wrote:
Thanks Ken,
Allen
Allen Fulmer
Posted: Fri May 09, 2008 7:46 am Post subject: Z-19 Item Clarification |
Thanks Ken,
If your panel contains EFIS display units, are they on when your "master
switch" is turned on? Keeping them off until the engine is started is my
desire. I think BobN says it is not an issue with modern day electronics
but I seem to remember that GRT (at least) recommends that you not expose
the display units to the potential voltage drop during engine start.
(Actually, I seriously doubt starting the Subaru with it's geared starter is
going to create much of a drop but . . ..)
Allen
[quote]>>--
N808AF reserved
Mark Sletten
Joined: 10 Jan 2006 Posts: 43 Location: St. Jacob, IL (Near St. Louis, MO)
Posted: Fri May 09, 2008 7:56 am Post subject: Re: Z-19 Item Clarification |
sshook(at)cox.net wrote: | For my Z19/Egg Hybrid wiring, I used all of Jan's recommendations for supplying electrical power to the engine ECU, prop, and fuel pumps.-- |
Ok, I'll be the first to bite... why run power to all critical engine components thru a single point of failure, specifically the four-pole switch? While you have redundant sources feeding redundant poles on the feed side of the switch, the failure of a single pole on the feed side of the switch (bad connection, poor crimp, broken wire, etc.) results in engine shut down.
Additionally, you have both fuel pumps feeding off a single pole on the switch. This seems like a single-point of failure added to a single-point of failure. If this one pole of the switch fails you lose both fuel pumps.
In my mind, the whole point of redundant power supplies is to avoid single points of failure.
_________________ Mark Sletten
Legacy FG N828LM
http://www.legacyfgbuilder.com |
Posted: Fri May 09, 2008 8:47 am Post subject: Z-19 Item Clarification |
I hear what you are saying with the 4P3T switch. I just don't see any other
alternatives to switching bus power while still staying within the
recommendations/requirements of Eggenfellner.
Certainly, if someone has a suggestion or recommendation for me - I am
always ready to hear it.
Eventually, all roads in our redundant electrical systems lead to a single
point of failure - the power wire for the component we are powering. That
will always be a single point of failure as I do not know of many components
that have independent, redundant power sources.
Scott R. Shook
RV-7A (Building)
N696JS (Reserved)
Allen Fulmer
Posted: Fri May 09, 2008 8:59 am Post subject: Z-19 Item Clarification |
Mark and all interested in the Z19/Eggenfellner Subaru electrical system
design discussion:
See if this link works to the thread titled: "Diode verses Switches 101"
http://forums.matronics.com/viewtopic.php?p=169493#169493
Allen Fulmer
[quote]>>--
N808AF reserved
harley(at)AgelessWings.co Guest
Posted: Fri May 09, 2008 9:54 am Post subject: Z-19 Item Clarification |
>>I do not know of many components that have independent, redundant power sources.<<
The P-Mag for one...electrically, anyway
Harley
Scott R. Shook wrote: [quote] [quote]--> AeroElectric-List message posted by: "Scott R. Shook" <sshook(at)cox.net> (sshook(at)cox.net) I hear what you are saying with the 4P3T switch. I just don't see any other alternatives to switching bus power while still staying within the recommendations/requirements of Eggenfellner. Certainly, if someone has a suggestion or recommendation for me - I am always ready to hear it. Eventually, all roads in our redundant electrical systems lead to a single point of failure - the power wire for the component we are powering. That will always be a single point of failure as I do not know of many components that have independent, redundant power sources. Scott R. Shook RV-7A (Building) N696JS (Reserved) --
Posted: Fri May 09, 2008 2:17 pm Post subject: Z-19 Item Clarification |
Hello Allen
No I do not have an EFIS, just a six pack of conventional flight
instruments on my bird.
Computers make wonderful monitoring tools though and my Grand Rapids EIS
(engine instruments only) is always powered during start up. It does not
reboot as far as I know but it wouldn't matter anyway as it comes up
pretty much instantly when turned on. It has survived several hundred
startups so far Thanks to the crowbar overvoltage module, it has
also survived a voltage regulator failure that drove the voltage up.
Ken
Allen Fulmer wrote:
Quote: |
Thanks Ken,
Allen
Mark Sletten
Posted: Sat May 10, 2008 6:57 pm Post subject: Re: Z-19 Item Clarification |
sshook(at)cox.net wrote: | I hear what you are saying with the 4P3T switch. I just don't see any other alternatives to switching bus power while still staying within the recommendations/requirements of Eggenfellner. |
I've read the Eggenfellner install manual. There IS a schematic depicting what the manual refers to as "one way to wire your system" using the switch to which you refer. I couldn't find anything stating the switch as a "requirement." As far as I can see, the ONLY benefit this switch provides is the ability to switch between power supplies with a single switch.
Other than the drawing in the manual, which specific recommendation(s) from Eggenfellner require you to incorporate a single point of failure in your electrical system? Maybe a better question might be how has Eggenfellner justified the recommendation(s) you feel compelled to follow?
sshook(at)cox.net wrote: | Eventually, all roads in our redundant electrical systems lead to a single point of failure - the power wire for the component we are powering. That will always be a single point of failure as I do not know of many components that have independent, redundant power sources. |
Comparing a single, unbroken wire connected at either end with a switch incorporating 12 external connecting points and a multitude of moving parts manipulating several internal contacts is a bit of a stretch...
Even if you are convinced of the invincibility of the switch, what design philosophy drives connecting both fuel pumps to a single pole of the switch?
Legacy FG N828LM
Posted: Sun May 11, 2008 4:09 pm Post subject: Z-19 Item Clarification |
The "requirement" I spoke of came about from an off-field incident in March
which Eggenfellner said that they will not support bridge rectifiers being
used for their engines.
Scott R. Shook
RV-7A (Building)
N696JS (Reserved)
ZuluZephyr
Posted: Sun May 11, 2008 8:52 pm Post subject: Re: Z-19 Item Clarification |
Scott,
The failure that you mention was due to an incorrectly sized rectifier or diode that was not designed to carry the load that was applied. Not because the basic design is faulty. All designs have advantages and disadvantages.
Eggenfellner's design solves certain potential problems and creates others.
Ultimately, it is your plane and your risks. The trick is to make fully informed decisions about the trade-offs in design and decide what your risk tolerance is for the various design options.
Rocky Morrison
Sportsman / H6
Mark Sletten
Posted: Mon May 12, 2008 5:59 am Post subject: Re: Z-19 Item Clarification |
sshook(at)cox.net wrote: | The "requirement" I spoke of came about from an off-field incident in March which Eggenfellner said that they will not support bridge rectifiers being used for their engines. |
Scott,
1. The NTSB has not completed its investigation of this accident yet. I would hesitate to base design decisions on speculation regarding ANY accident -- especially if the speculation comes from a party with an interest in the results of that investigation.
2. I do not believe the accident aircraft to which you refer incorporated a bridge rectifier in the power path to the critical engine components.
3. If you are leery about using bridge rectifiers there are other products capable of controlling power routing besides them.
Legacy FG N828LM
Posted: Mon May 12, 2008 7:23 am Post subject: Z-19 Item Clarification |
I spoke with two Legacy builders from Princeton, NJ on Saturday. One of
their fellow builders was flying their RV-9 and Egg Sube when a $20.00
switch or diode failed. You can have all the batteries and busses you
like, the Sube ignition maintains a single point of failure. That's why
they call it Experimental.
The crash pilot escaped with a mangled foot and broken leg. He is
re-building and now a favorite customer at Lycoming. BTW - If he had
turned right off after take-off there are smoother fields available for
landing. As Murphy would have it, he went left towards the trees.
Performance goes far beyond switches. Nothing is perfect, but Lycoming
still offers the Briggs and Stratton reliability to bring you home again
and again.
Keep it smart; wire for reliability not convenience.
The result:
http://www.ntsb.gov/ntsb/brief.asp?ev_id 080319X00337&key=1
