Panel Access / Defrost Fans
robin1(at)mrmoisture.com
PostPosted: Mon May 05, 2008 1:51 pm    Post subject: Panel Access / Defrost Fans Reply with quote
Or you can place the world's largest defrost fans in those holes.
Speaking of defrost fans we just installed two high volume computer fans in the dash. They are Vantec Tornado 80mm case fans that put out A LOT of CFM. I believe they pass 84 CFM vs. the typical computer case fans which are in the low to mid 30 CFM. Price under $11.00 each. These units are industrial grade cooling for computer gamers. They are run 55 dBA at full speed but I have a feeling the big fan on the front of the -10 is a little louder.
http://www.newegg.com/Product/Product.aspx?Item=N82E16811999612
Robin
 Filesize:  30.57 KB
 Viewed:  278 Time(s)
jcumins(at)jcis.net
PostPosted: Mon May 05, 2008 2:08 pm    Post subject: Panel Access / Defrost Fans Reply with quote
Can you send pics how you install this I am very interested.
John G. Cumins
President
JC'S Interactive Systems
2499 B1 Martin Rd
Fairfield Ca 94533
707-425-7100
707-425-7576 Fax
Your Total Technology Solution Provider
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Robin Marks
Sent: Monday, May 05, 2008 1:48 PM
Subject: RE: Panel Access / Defrost Fans
Robin
 Filesize:  30.57 KB
 Viewed:  283 Time(s)
Deems Davis
PostPosted: Mon May 05, 2008 2:56 pm    Post subject: Panel Access / Defrost Fans Reply with quote
Here's a link (16-18 pics) to one way to do it,
http://deemsrv10.com/album/Sec%2041%20Upper%20Fwd%20Fuse%20Install/slides/DSC04357.html
Deems Davis # 406
'Its all done....Its just not put together'
John G. Cumins
PostPosted: Mon May 05, 2008 4:17 pm    Post subject: Panel Access / Defrost Fans Reply with quote
John,
  Ours are just like Deems only not as nice. The same goes for anything other photo Deems posts. Anytime we were stuck our mantra was WWDD. What Would Deems Do? Problem solved… or made worse…
Robin
Deems envy…
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Cumins
Sent: Monday, May 05, 2008 4:04 PM
John G. Cumins
President
2499 B1 Martin Rd
Fairfield Ca 94533
707-425-7100
707-425-7576 Fax
Robin
 Filesize:  30.57 KB
 Viewed:  303 Time(s)
jcumins(at)jcis.net
PostPosted: Mon May 05, 2008 4:47 pm    Post subject: Panel Access / Defrost Fans Reply with quote
Thanks Robin, Deem is a true craftsman that’s for sure. I am amazed.
John G. Cumins
President
2499 B1 Martin Rd
Fairfield Ca 94533
707-425-7100
707-425-7576 Fax
Sent: Monday, May 05, 2008 4:15 PM
John,
Robin
Deems envy…
John G. Cumins
President
2499 B1 Martin Rd
Fairfield Ca 94533
707-425-7100
707-425-7576 Fax
Robin
 Filesize:  30.57 KB
 Viewed:  296 Time(s)
Deems Davis
PostPosted: Mon May 05, 2008 6:26 pm    Post subject: Panel Access / Defrost Fans Reply with quote
John, You are too generous, a true craftsman, gets it right the1st time.
There are many builders that truly are craftsmen, I'm just persistent
and trying to get close to their results. I've got some time on my hands
and I also take a lot of pictures (being careful to edit out the OOPS!).
Deems Davis # 406
John G. Cumins
President
Robin
John Ackerman
PostPosted: Tue May 06, 2008 6:36 pm    Post subject: Panel Access / Defrost Fans Reply with quote
Well, Deems, I don't think so. A true craftsman fixes his mistakes to
a high standard.
Don't blush, now!
John Ackerman
time. There are many builders that truly are craftsmen, I'm just
persistent and trying to get close to their results. I've got some
time on my hands and I also take a lot of pictures (being careful to
Deems Davis # 406
> John G. Cumins
> President
> Robin
