Hanger / workshop photo's...
greg(at)case-assembly.com
PostPosted: Mon May 05, 2008 4:55 am    Post subject: Hanger / workshop photo's... Reply with quote
Nice looking polebarn / workshop tom.
I'm thinking of building one on my property.
I'm thinking 40 x 40, I have a few toys that need a nice home.
This may be a good thread to start.
I think a lot of guys have or are thinking about the right workshop or
hanger to build.
If done right the cost can be almost reasonable.
What have others done?
There are building kits or scratch built.
The kitfox photo thread has been great, how about photo's of your workshop?
Greg
N42001 KF-IV in refurb
N81774 PA-32-301 Saratoga
n85ae
PostPosted: Mon May 05, 2008 5:41 am    Post subject: Re: Hanger / workshop photo's... Reply with quote
I built a Series 5, and am about halfway through a Zenith CH801 (4 seat)
both of which I built in my 12x26 single car garage. So a huge amount
of space isn't that necessary. Would sure be nice though Smile
Jeff
 Filesize:  398.27 KB
 Viewed:  722 Time(s)
shinco(at)bright.net
PostPosted: Mon May 05, 2008 6:03 pm    Post subject: Hanger / workshop photo's... Reply with quote
Jeff
http://forums.matronics.com/viewtopic.php?p=181217#181217
http://forums.matronics.com//files/winter_189.jpg
Good picture BUT I had enouff Snow 4 awhile,,,STEVE SHINABERY N554KF KF2
Tom Jones
PostPosted: Mon May 05, 2008 6:07 pm    Post subject: Re: Hanger / workshop photo's... Reply with quote
Here's the outside.
 Filesize:  932.06 KB
 Viewed:  728 Time(s)
Tom Jones
Classic IV
Ellensburg, WA
andynfultz(at)bellsouth.n
PostPosted: Mon May 05, 2008 8:03 pm    Post subject: Hanger / workshop photo's... Reply with quote
It can be done, but what a b*#%^!
Andy F.
n85ae
PostPosted: Tue May 06, 2008 7:18 am    Post subject: Re: Hanger / workshop photo's... Reply with quote
Tom Jones wrote:
Here's the outside.
Tom -
Nothing personal, but I feel a deep feeling of animosity towards anybody
so lucky as you to have a facility like that! Smile
Going back to my closet ...
Jeff
icubob(at)newnorth.net
PostPosted: Fri May 09, 2008 6:04 am    Post subject: Hanger / workshop photo's... Reply with quote
hi all, i built my dakota hawk in a 22x16 shop which is in my30x45 pole
barn. i had enough room in my barn to completely assemble the plane and
adjust all the controls. i live in n. wis. and heating only the shop was no
big deal. completely insulating and heating the barn would have been another
story.if you are thinking of using radiant heat from the floor you are
definitely not in my income class and if you are thinking of using wood that
adds a lot more difficulty to the project. i have a wall mounted non vented
15,000 btu gas heater that always keeps the shop 55 deg when i am not using
it. when i work i use a small vented wall mounted forced air furnace.
although i have tested the nonvented unit for CO emissions and they are nil,
it does give off a little odor. i like using it to keep the temp at 55 deg.
as it is 100% efficient.
i live in one of the colder parts of the country and fuel costs are a
consideration to me.
in the next year i will be moving the plane to my hangar[ if i hadnt broken
my arm and 2 ribs last sunday it would have been this november!] and for
sure i will put a very small heated shop in a corner of my hangar. i see so
many times a pilot has to make several trips to repair something that could
have been done on the spot. shop can be small, 10x12, enough for a bench and
tools. probably a couple electric space heaters will be enough. and a
picture window so i can sit in my chair and drink a beer while i gawk at my
plane when nothing needs tweaking! just my thoughts, bob noffs
PostPosted: Fri May 09, 2008 7:14 am    Post subject: Hanger / workshop photo's... Reply with quote
I'm not sure if building a pole barn using a Steel Building kit is the way
to go or not.
There are many vendors out there with, I'm sure, different levels of value.
Anyone have experience?
Greg
peteohms
PostPosted: Fri May 09, 2008 7:45 am    Post subject: Hanger / workshop photo's... Reply with quote
On this topic, I'd love to see some drawings, sketches and pictures from
others.
Pete
Model III, 912ul, N73BH
Pete
Leander, TX
Kitfox III, 912ul, Grove
dwight purdy
PostPosted: Fri May 09, 2008 6:30 pm    Post subject: Hanger / workshop photo's... Reply with quote
How do you deal with the moisture from the unvented heater? It would put
out gobs of water(voice of experience).
Dwight Purdy
Model ll
no big deal. completely insulating and heating the barn would have been
another story.if you are thinking of using radiant heat from the floor you
are definitely not in my income class and if you are thinking of using
wood that adds a lot more difficulty to the project. i have a wall mounted
non vented 15,000 btu gas heater that always keeps the shop 55 deg when i
am not using it. when i work i use a small vented wall mounted forced air
furnace. although i have tested the nonvented unit for CO emissions and
they are nil, it does give off a little odor. i like using it to keep the
temp at 55 deg. as it is 100% efficient.
broken my arm and 2 ribs last sunday it would have been this november!]
and for sure i will put a very small heated shop in a corner of my hangar.
i see so many times a pilot has to make several trips to repair something
that could have been done on the spot. shop can be small, 10x12, enough
for a bench and tools. probably a couple electric space heaters will be
enough. and a picture window so i can sit in my chair and drink a beer
while i gawk at my plane when nothing needs tweaking! just my thoughts,
bob noffs
dwight
model II
Michael Logan
PostPosted: Sat May 10, 2008 3:35 am    Post subject: Hanger / workshop photo's... Reply with quote
Beware of the special low prices, most of the time they don't come with
essentials such as the ends of the building, etc. Miracle Truss does that.
Mike Logan
Fredericksburg, VA
wingnut
PostPosted: Sat May 10, 2008 9:41 am    Post subject: Re: Hanger / workshop photo's... Reply with quote
Here's mine. My plane has to share the building with various tractor implements and a few hay bales. It's just a regular garage style building with an open face. A went to a local builder that specialized in garage buildings and he built this to spec for $10k. That included a bit of grading and gutters. Now I need to figure out a door to keep the ducks out Smile.
 Filesize:  92.46 KB
 Viewed:  658 Time(s)
Luis Rodriguez
Model IV 1200
Rotax 912UL
Flying Weekly
Laurens, SC (34A)
PostPosted: Sat May 10, 2008 4:54 pm    Post subject: Hanger / workshop photo's... Reply with quote
Luis Rodriguez
Model IV 1200
Rotax 912UL
Flying Weekly
Laurens, SC (34A)
http://forums.matronics.com/viewtopic.php?p=182380#182380
http://forums.matronics.com//files/img_14372m_683.jpg
Nice hanger,and what is nice about it is..Is that you can keep it at
home..I wish that i had the room,as you do and a landing strip as you
do,,BUT I live in town :-\ So.I have to do what I have to do,,so I can
fly..STEVE SHINABERY N554KF KF2
jlfernan
PostPosted: Mon Aug 11, 2008 1:39 am    Post subject: Re: Hanger / workshop photo's... Reply with quote
My kit finally came in so I can post my workshop.
Jorge Fernandez
Supersport
Fuselage/Forward Controls
http://websites.expercraft.com/jlfernan/
Tom Jones
PostPosted: Mon Aug 11, 2008 7:36 am    Post subject: Re: Hanger / workshop photo's... Reply with quote
The freshly uncrated kitfox kit. That brings back some fond memories of an exciting time!
 Filesize:  278.33 KB
 Viewed:  583 Time(s)
Tom Jones
Classic IV
Ellensburg, WA
