Gary.Leinberger(at)miller Guest
Posted: Fri May 02, 2008 6:43 am Post subject: Fuel tank - bulges and leakage. |
Nigel - this is beautiful - what is the cost of building another one? Do
you have more detailed plans?
Gary Leinberger
A237
rlborger(at)mac.com Guest
Posted: Fri May 02, 2008 7:09 am Post subject: Fuel tank - bulges and leakage. |
Nigel,
WOW! A magnificent piece of work!
Check six,
Bob Borger
Europa Kit #A221 N914XL, XS Mono, Intercooled 914, Airmaster C/S
http://www.europaowners.org/N914XL
(95% done 95% to go) tail kit done, wings closed, cockpit module
installed, pitch system in, landing gear complete, rudder system in
with Singleton Mod, outrigger mod in, Fuselage Top on, lift/drag/flap
pins in, wing incidence set, tie bar in, flap drive in, baggage bay
in. Fuel system complete. Rotax and Airmaster installed. Mods 62,
66, 70 & 72 done. Completed the instrument panel install. Europa
interior kit being installed. Installed windows. Working in - 25
Electrical, 28 Flaps, 30 Fuel System, 32 Tail, 34 Door Latches & 35
Doors, 37 Finishing. Mostly finishing these days.
3705 Lynchburg Dr.
Corinth, TX 76208
Home: 940-497-2123
Cel: 817-992-1117
On May 2, 2008, at 8:56, Nigel Graham wrote:
[quote] Craig,
I have been watching this thread develop with interest.
I came to the conclusion a long time ago that I was not happy with the
plastic tank. The theory was great - but the execution left a lot to
be
desired.
To cut a long story sideways, I did make a magnesium alloy tank, and
used
the opportunity to increase the volume, and include solid state
liquid level
sensors in addition to the capacitance fuel probe, proper filters
and AN
fittings for alloy fuel pipes.
Don't be under any illusions over how long this will take. All in
all this
set me back about 18 months of careful planning, pattern making and
cutting.
All edges were flanged and riveted to hold everything in precise
place prior
to welding. The conical fuselage section requires some interesting
developments that are nowhere near a simple as they look.
Admittedly, mine is more complex than you will most likely need, as I
extended up into the headrests to increase volume (on the C of G).
FYI take a look at the attached document I provided to our PFA to
secure
approval. It gives you a good idea of what the finished alloy tank
might
look like. Hopefully you can get a neater welder
My tank looked wonderful before welding. I could have cried when I
received
back the crumpled results.
Nigel (the other one) Graham
rparigor(at)suffolk.lib.n Guest
Posted: Fri May 02, 2008 7:50 am Post subject: Fuel tank - bulges and leakage. |
Hi Jan
"As mentioned the aileron drive protection could also be made somewhat
larger. Comments?"
Just a note:
I remember reading years ago a few who had tank bulge and hit aileron
cross tube, just moved the cross tube from aft of arms to forward.
As far as the aft tank supporting brackets, "dang" they are supporting up
to 18 gallons of fuel and weight of tank (over a hundred pounds of
cantilevered weight). Besides the expanding and contracting evil, you have
a severe stress riser here if you follow manual. If my CPM was not bonded
in place, I would not have made all layers of BID end at the same place
but instead taper layer on the tank where first layer if longest and
subsequent layers are shorter. The tunnel bracket is a vulnerable area.
The extra BID I added will not relieve any cantilever loading or
expansion loading in the center, but will distribute load over a larger
area. Distributing loads over a "larger area is a "much more better"
thing. I would rather have my 300 lb passenger wearing flat sole foot
apparel than spike heels which will most likely go right through the floor
of Europa. Foam distributes fuel tank cantilever load (I put Mylar in
there so foam is not bonded to tank and will allow expansion). I mentioned
on the gallery that there was no bulge after foam was applied. I was not
referring to the tank but the bottom of the fuse. The high expansion foam
may very possibly deform it. I think the foam will alleviate a lot of
cantilevered stress on the aft BID brackets.
A note on building a metal tank. First off I have seen at least 1 picture,
perhaps 2 that are existing. First choice is to source to ones who already
developed. If can't have them build one more, pick their brains how they
did it. If you can't find pictures or who has them in hangar I have info.
If that comes to a dead end, an idea:
I have a metal melting machine and several chip making machines (Hobart
TRT 250 TIG, 2 laths and 2 milling machines). I welded up a thin wall
aluminium tank for a Sonerai. I purged inside of tank with argon and it
looked great. There was 1 spot in a corner that had a pit of
contamination, easy to file and re-weld.
Now for plan. Someone get hold of weldable aluminium, remember that when
you weld aluminium it goes to T-0, which means it will be soft as
aluminium a soda can is made from. After it sits depending on the
aluminium used, generally it will get harder perhaps to T-3. I am not an
expert and it has been years since I welded up an alumimium folding
balloon basket, but strength does increase with time. Thus someone find
out what type of aluminium is used in a Sonerai and other welded aeroplane
tanks and buy some. Now design up a nice square cornered 5 gallon
container and cut the pieces. File or sand the edges so were the weld is
going there is a 90 degree bevel. Don't make the bevel (22.5 degrees each
side) to form a sharp edge, but bevel only about 2/3rds of thickness. Make
sure you clean aluminium everywhere and of area to be welded, meticulous
and scotchbright 1" on both sides, then wipe down with degreaser. Now
assemble tank with dabs of JB Weld KWIK (4 minute). Oh yea before
assembly, choose a nice weldable opening and cap. Look at aeroplane stuff
in Spruce and Wicks and www.mcmaster.com . I will leave this detail to
you. For an air vent, buy a petcock that Spruce (and probably Wicks) sells
where you drill a hole, insert a grommet and then force petcock in place.
My charge will be that after I send the tank around for critique, I get to
keep it.
For a more aggressive first try, and my preference, make an aux tank for
the port side of mono! Same charge applies.
If all is a go, make the real deal. Same charge applies.
I have had great success hacking up old fork lift Worthington propane
cylinders, cutting them in half, extending and beefing up dip tube and
melting them together. All still in service since early 90s. A lot easier
to keep Europas liquid energy contained compared to a balloons liquid
energy.
My charge can be negotiated, if someone delivered bits and pieces and
helped weld thing up (day to 3??), and helped a bit on my build........
Ron Parigoris
nigel_graham(at)btconnect Guest
Posted: Fri May 02, 2008 8:04 am Post subject: Fuel tank - bulges and leakage. |
Gary,
I just looked back through my records, it seems I spent ?120 ($240 today) on
two sheets of Magnesium alloy (though I only needed one).
I paid the welder ?150 ($300 today).
I had some 3/8" tubing (for the internal breathers) "in stock", and turned
up the fuel hose nozzle, filter housings and all other fittings from stock
material.
The lowest cost was my 18 months labour!!!
I don't have anything as sophisticated as "plans" though I do have a
cupboard full of carefully cut and numbered cardboard templates.
Nigel
Paul Boulet
Joined: 09 Jan 2006 Posts: 57 Location: Malibu, California
Posted: Fri May 02, 2008 10:05 am Post subject: Fuel tank - bulges and leakage. |
Beautiful tank Nigel. Now if I could just get one without going thru the pain you went thru....sigh
Paul Boulet, N914PG- Trigear XS with 914 intercooled engine
Malibu, CA
Nigel Graham <nigel_graham(at)btconnect.com> wrote:
[quote]Craig,
plastic tank. The theory was great - but the execution left a lot to be
desired.
To cut a long story sideways, I did make a magnesium alloy tank, and used
the opportunity to increase the volume, and include solid state liquid level
sensors in addition to the capacitance fuel probe, proper filters and AN
Don't be under any illusions over how long this will take. All in all this
set me back about 18 months of careful planning, pattern making and cutting.
All edges were flanged and riveted to hold everything in precise place prior
FYI take a look at the attached document I provided to our PFA to secure
approval. It gives you a good idea of what the finished alloy tank might
My tank looked wonderful before welding. I could have cried when I received
wdaniell(at)etb.net.co Guest
Posted: Fri May 02, 2008 10:18 am Post subject: Fuel tank - bulges and leakage. |
Can anyone tell me the process for putting the top of the CM back on once you have taken out the old tank and put in the new one? I am assuming that you cut the top off very carefully and then glass it back. How many plies/orientation is recommended?
Will
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Paul Boulet
Sent: Friday, May 02, 2008 13:02
Subject: RE: Fuel tank - bulges and leakage.
Malibu, CA
Craig,
desired.
fklein(at)orcasonline.com Guest
Posted: Fri May 02, 2008 11:44 am Post subject: Fuel tank - bulges and leakage. |
I've been lookin about for tank scraps from opening of drain holes etc.
w/ the idea of sending a chunk to a lab for analysis re: fluoride
treatment. Though I've a box of misc. cuttings and bits, somehow my
tank scraps got tossed.
If by any chance, someone kept theirs and have a kit number close to
A194 please contact me off list.
Fred
believed to be clean.
Posted: Fri May 02, 2008 12:27 pm Post subject: Fuel tank - bulges and leakage. |
thats a great job, few wrinkles from the welding heat but hey it wont effect
the performance, the extra
capacity is good, my measurements indicated that an increase of about 27
litres was possible
but i didnt fill in the tunnel as you have, or included head rests, just
curious, how do you
vent the head rests to allow them to fill fully, I didnt see any holes there
other than the
one for the fuel sender.
craig
Posted: Fri May 02, 2008 11:55 pm Post subject: Fuel tank - bulges and leakage. |
Hi! Ralf
No one has commented ? Personally I thought it a good suggestion,
however the connections would be a challenge ? Still it was good enough
for Concord.
Bob Harrison G-PTAG
ami(at)mcfadyean.freeserv Guest
Posted: Sat May 03, 2008 12:32 am Post subject: Fuel tank - bulges and leakage. |
How would you get it into the tank?
Duncan McF
Posted: Sat May 03, 2008 1:32 am Post subject: Fuel tank - bulges and leakage. |
Same as they run in most race cars, one problem I can see is that they still
havnt worked out the logistics
of a fuel sender as far as i am aware, so you would be stuck with the sight
glass level I guess, also from what
I have seen, you would be basically creating a new tank plus bladder, so
wouldnt the alloy tank be simpler
and cheaper. Other than that, it would probably be the overall best option,
if it is a proper fuel cell, then fuel surge
and vapours are virtually eliminated
craig
Posted: Sat May 03, 2008 1:43 am Post subject: Fuel tank - bulges and leakage. |
Hi! Duncan
Obviously there are some challenges, however Getting it in through the
oval fuel sender cut out in the tank op wouldn't be a problem.
Bob H G-PTAG
PS the major problem would be getting acceptance from the LAA !
Posted: Sat May 03, 2008 1:44 pm Post subject: Fuel tank - bulges and leakage. |
Yes i know thanks, I was referring to the logistics of fitting a fuel sender
to a tank
with a bladder in it. Which to my knowledge even top level motorsport teams
still
havn't managed to do. I have a capacitance probe in my tank, but thankyou.
craig
jrgowing(at)bigpond.net.a Guest
Posted: Sat May 03, 2008 4:03 pm Post subject: Fuel tank - bulges and leakage. |
Craig
Tony Krzyzewski's site mayh interest you if you have never looked at
it.....
Electronic Fuel gauge fitted. Builder developed modification
Don't quite know what you were thinking but if I were confident in wiring I
think this gauge would be good - IF YOUR TANK WAS A REGULAR SHAPE! But you
don't actually see the fuel level.
Anyway I must make time to go over his site myself for a good look.
Best Wishes
JR
n100rh(at)sbcglobal.net Guest
Posted: Sat May 03, 2008 5:34 pm Post subject: Fuel tank - bulges and leakage. |
If I've remember correctly auto racing safety tanks use a rubber
bladder. I will check Simpson et al and see if it is possible to have a
custom bladder made to fit inside our existing plastic tank. If I loose
some useful volume, I really don't care.
Ralph
Robert C Harrison wrote:
Hi! Ralf
for Concord.
Bob Harrison G-PTAG
Posted: Sat May 03, 2008 10:53 pm Post subject: Fuel tank - bulges and leakage. |
I think Tony's fuel gauge could be callibrated for any shape tank. Paul?
Graham
JR Gowing wrote:
Craig
it.....
wiring I think this gauge would be good - IF YOUR TANK WAS A REGULAR
SHAPE! But you don't actually see the fuel level.
Best Wishes
JR
paul.the.aviator(at)gmail Guest
Posted: Sun May 04, 2008 5:45 am Post subject: Fuel tank - bulges and leakage. |
Hi All,
Yes to Grahams point, the fuel gauge system that Tony designed
calibrates to any shape. For those who aren't aware of Tony's gauge
system it works by weighing the contents of the fuel tank. It uses a
sensor in the lowest point of the tank which is connected to an
analogue to digital converter. A microprocessor uses a set of look up
tables that you create during the calibration processes to compensate
for the tank shape. The output can be either a 10 segment bar graph
or a signal to drive a conventional analogue meter.
Although not as simple, this system gets around the issues associated
with sight gauges, and IMHO, is far superior to any capacitance or
float system
I have had mine in place since May 2004 and it has worked faultlessly.
Paul
Graham
Posted: Sun May 04, 2008 8:23 am Post subject: Fuel tank - bulges and leakage. |
Here's an article I found informative on this topic.
http://www.tms.org/pubs/journals/JOM/9607/Alvarado-9607.html#ToC7
Venu Rao
Posted: Sun May 04, 2008 9:41 am Post subject: Fuel tank - bulges and leakage. |
A friend who used to race shared this company's name.
They're apparently the gold standard for fuel cell bladders
in the racing world.
http://www.atlinc.com/racing.html
He also suggested that most rubber bladder tanks have
2 major drawbacks:
1/ 5 year lifespan
2/ Temp variance effecting fuel capacity (range typically is 30ºF to 120ºF (0º to 50ºC)
I've also attached a .pdf which includes a "Product Safety Bulletin" section.
Rather keen to get this issue resolved!
Description: |
 Download |
Filename: |
BladderTanks.pdf |
Filesize: |
425.95 KB |
Downloaded: |
614 Time(s) |
_________________ Venu Rao
Austin, TX
Europa Mono
Builder: Jim Nelson
TTAE 119.1 hrs |
Posted: Sun May 04, 2008 3:21 pm Post subject: Fuel tank - bulges and leakage. |
On Thursday, May 1, 2008, at 13:22 US/Pacific, Alan Burrows wrote:
Quote: | Having had to replace a tank and had the heartache of seeing fuel
running
out of the bottom of my aircraft TWICE (second time after attempting to
repair the old tank).
Alan,
Could you elaborate on the products and techniques used in your
attempts to repair the old tank?
I apologize for asking you to open old wounds, but your accounts may
allow us to focus better on finding something that just might work.
No doubt folks will tend towards solutions which address the situation
in which they find themselves. For some, a metal tank will be the
obvious solution. For someone w/ a bulging but no signs of a leak,
another strategy may be persuasive. For myself, w/ an empty tank
installed which has yet to smell any fuel, I'm looking hard for a "fill
and drain" agent which I can slosh around the tank interior which will
provide an impervious coating to keep fuel out of the HDPE and hence
eliminate the tank expansion as fuel would be otherwise absorbed.
Because of the widespread use of HDPE tanks in the automobile industry,
and the relatively rapid evolution of both HDPE and fuel formulations,
my hunch is that there are hundreds of thousands of HDPE tanks which
are vulnerable to current and future fuel blends. If that is so, there
will be huge need and market for precisely what I'm looking for.
Cheers...as they say, "better living (and flying) thru chemistry"
Fred
