peteohms
Posted: Wed Apr 30, 2008 11:23 am Post subject: Model III Tail Spring |
I read the following from an old Kitfox newsletter:
"Tailwheel steering springs."
"Imagine yourself on short final in your brand new KITFOX, all set up for a
perfect 3- point touch-down. You're close now, bring the stick back--back,
it looks perfect. The tail wheel touches-- suddenly the nose veers left,
hard. You apply full right rudder and brake. Still your baby turns left,
ever tighter, the stick is still in your gut, but the tail comes up anyway.
You get a good close-up view of the runway as the nose dips and the prop
strikes pavement. The airplane rocks right and the right wingtip hits the
ground with great gusto. When the dust settles, if you're lucky, your new
darling has a broken prop blade and a damaged wingtip. If you're not so
lucky, she also has crumpled landing gear, a broken wing, engine or gearbox
damage, and a smashed cowling. What happened? When the tailwheel touched,
one of the steering springs popped loose. To prevent an excursion like this,
crimp the hooked ends of the spring around and tie across them with safety
wire so they can't come loose."
My Model III has been flown 328 hrs without this being done, only 8 hrs by
me. I had a similar experience in a KR-2 about 29 years ago practicing
crosswind high speed taxis. Ran off the runway and went up on it's nose
into a sand dune. Motor stopped prior to gentle nose over. No damage.
The thing I'm worried about is bending the spring. Won't that weaken the
spring?
Pete
_________________ Pete
Leander, TX
Kitfox III, 912ul, Grove |
SkySteve
Joined: 16 Dec 2007 Posts: 94 Location: Huntsville, UT
Float Flyr
Posted: Wed Apr 30, 2008 12:15 pm Post subject: Model III Tail Spring |
I lockwired mine on and put a loose twist up the middle of the spring just
in case. I did the same thing for all the springs in my exhaust too.
Simple safe and fast.
Noel
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
clint_bazzill(at)hotmail. Guest
Posted: Wed Apr 30, 2008 12:26 pm Post subject: Model III Tail Spring |
If you use compression springs you won't have that problem.
Clint
[quote] From: noelloveys(at)yahoo.ca
Subject: RE: Model III Tail Spring
Date: Wed, 30 Apr 2008 17:42:55 -0230
--> Kitfox-List message posted by: "Noel Loveys" <noelloveys(at)yahoo.ca>
Noel
Tom Jones
Joined: 12 Mar 2006 Posts: 752 Location: Ellensburg, WA
Posted: Wed Apr 30, 2008 12:31 pm Post subject: Re: Model III Tail Spring |
I used a pair of pliers to pinch the spring ends closed. Thats what Skystar recommended.
_________________ Tom Jones
Classic IV
Ellensburg, WA |
Guy Buchanan
Posted: Wed Apr 30, 2008 8:04 pm Post subject: Model III Tail Spring |
At 12:20 PM 4/30/2008, you wrote:
| Quote: | The thing I'm worried about is bending the spring. Won't that
weaken the spring?
No, you won't weaken the spring bending it once. I use
compression springs because I understand they're less likely to fail
and when they do they're supposed to remain captive.
Guy Buchanan
San Diego, CA
Deceased K-IV 1200
A glider pilot too. |
Tom Jones
Posted: Thu May 01, 2008 3:59 am Post subject: Re: Model III Tail Spring |
If you have a copy of the DVD "Cub Driver Alaska" Look close at the tail wheel on the authors cub. He talks about some of the modifications on the cubs featured but does not mention that there is no mechanical linkage between the tail wheel and the rudder. They use brakes to steer a slow speeds and blast of power to help turn. In several landing scenes you can see the tail wheel is 90 degrees to the rudder on the approach.
Link to teaser http://www.cubdriver749er.com/dvd.php
I guess the thing to keep in the back of your mind is if you ever seem to not have tail wheel linkage hit the opposite brake.
Classic IV
Ellensburg, WA |
