KolbFlyerJim(at)aol.com Guest
Posted: Mon Apr 21, 2008 1:49 am Post subject: UltraStar |
Hi all Jim here
I'm thinking of selling my Ultra Star. Any suggestions or comments?
Jim VanGarsse
Need a new ride? Check out the largest site for U.S. used car listings at AOL Autos.
jb92563
Joined: 23 Mar 2007 Posts: 314 Location: Southern California
Posted: Mon Apr 21, 2008 11:58 am Post subject: Re: UltraStar |
What condition is it in?
How is the motor?
How did you like flying it?
Does it still meet Part 103 Ultralight specs?
_________________ Ray
Moni MotorGlider
Schreder HP-11 Glider
Grob 109 Motorglider
Do Not Archive |
Posted: Mon Apr 21, 2008 3:02 pm Post subject: UltraStar |
HI Ray.
Jim here.
My UltraStar is in good condition the motor has 175 hrs on a 300 hr rebuild. I have installed a Fire Star nose full instrumentation, ASI dual EGT,CHT,IVSI,ALT, Fuel gauge,slip indicator,Tinny teach, lighted dash.The engine is a Rot ax 503 D.C.SI with a 2.58-1 gearbox turning a 54 in IVO. She has a Quad strobe system (they call me the flying Christmas Tree) She has disc brakes and an unusual differential braking control witch acts as a parking brake.She has 8 inch rims with TUNDRA tires. Some how I have acquired the nickname of the scudd. I have extended the landing gear to give me more prop Clarence but you know how it goes I have increased the prop size to 54 in. ( shouldn't say this but I have done 120 IAS in Straight and level flight not on purpose tho). She is registered as an E.L.S.A and has an airworthiness cert. She will climb at 1000 FPM at 40 Indicated . She fly's like a dream. She has a 9 gallon fuel tank. She cruses at 60-65 at 4700 RPM(what did forget?)?????
Jim VanGarsse
2613 M
BelvidereIll(at)aol.com (BelvidereIll(at)aol.com)
In a message dated 4/21/2008 3:01:37 P.M. Central Daylight Time, jb92563(at)yahoo.com writes:
| Quote: | --> Kolb-List message posted by: "jb92563" <jb92563(at)yahoo.com>
How is the motor?
Ray
Moni MotorGlider
Riverside County, CA
http://forums.matronics.com/viewtopic.php?p=178228#178228
Dana
Posted: Mon Apr 21, 2008 4:54 pm Post subject: UltraStar |
At 06:59 PM 4/21/2008, KolbFlyerJim(at)aol.com wrote:
| Quote: | | My UltraStar is in good condition the motor has 175 hrs on a 300 hr rebuild. I have installed a Fire Star nose full instrumentation, ASI dual EGT,CHT,IVSI,ALT, Fuel gauge,slip indicator,Tinny teach, lighted dash.The engine is a Rot ax 503... I have done 120 IAS in Straight and level... |
An UltraStar with a 503??? Sounds more like a RocketStar! Isn't Vne for the US only 70? But seriously, did you beef it up at all? Funny, just last night I was browsing some archive messages about an early 5 rib FS with a 503, and many were saying it was overloaded and unsafe with that much power. Seems a US would be even more so.
-Dana
Celebrate Freedom... read a banned book. [quote][b]
Posted: Tue Apr 22, 2008 12:37 am Post subject: UltraStar |
HI Dana.
I have chatted with Mr Kolb about my plane and he is ok with the 503.
Jim
In a message dated 4/21/2008 7:55:10 P.M. Central Daylight Time, d-m-hague(at)comcast.net writes:
-Dana
Celebrate Freedom... read a banned book. | Quote: |
="http://www.matronics.com/Navigator?Kolb-List">http://www.matronics.com/Navigator?Kolb-List
.matronics.com/">http://forums.matronics.com
://www.matronics.com/contribution">http://www.matronics.com/contribution
rowedenny
Posted: Tue Apr 22, 2008 2:07 am Post subject: UltraStar |
HI Dana.
Jim
Jim,
The nicest Ultrastar I ever saw was 503 powerd and had beefed up landing gear and I'm sure other mods.
I saw it years ago at a fly in in Eastern Ohio, it was built and owned by a fellow named Tom Tchantz (spelling?) and I think he won a major award at Oshkosh that same summer. He later sold it and I always wonder if its still around. It was a true work of art and every Ultrastar owner shoul get a chance to look it over for ideas.
Should be some nice layouts of it in old EAA rags.
Denny Rowe,
worrybear(at)verizon.net Guest
Posted: Tue Apr 22, 2008 2:36 am Post subject: UltraStar |
Jim, How about posting a picture of the plane and 503 installation? Where are you located?
Dan Walter
Druine Turbulent, Ultrastar
bransom(at)ucdavis.edu Guest
Posted: Tue Apr 22, 2008 10:25 am Post subject: UltraStar |
An ultrastar with a 503 is beyond design spec by a lot -- that plane
wasn't even spec'd for a 447. I will acknowledge that a 5 rib original
Firestar wing is not a lot different than a 5 rib Ultrastar wing, but
again, Dennis of old Kolb made a new wing (7 rib) to accommodate the
interest in a 503. But then the E means Experimental, and to each his
own. (Any weight needed on the nose to compensate for a 92 lb engine?)
Then about the 120 indicated, straight and level. Even if the straight
and level was after a fast dive, I just can't fathom anything over 90,
unless the wings were missing at that point. Recall that the ultrastar
is what Dennis flight tested to destruction, in which a wing drag strut
failed coming out of an intentional dive at about 80, and just the dive
(let alone the broken wing) frightened even him in his younger
invincible life.
So, how far from stock are the wings on this thing? Or, am I just
flying my Firestar like a little old lady?
-Ben
FS KXP
| Quote: | HI Ray.
Jim here.
Jim VanGarsse
2613 M
BelvidereIll(at)aol.com <mailto:BelvidereIll(at)aol.com>
How is the motor?
Ray
Moni MotorGlider
at AOL Autos <http://autos.aol.com/used?NCID=aolcmp00300000002851>.
Posted: Tue Apr 22, 2008 12:40 pm Post subject: UltraStar |
Hi Dan.
Jim here.
I have several pics on matronics picture list I'm not sure to get there she is the ivory UltraStar with the Fire Star nose I'm in northern Illinois.
Thanks Jim
In a message dated 4/22/2008 5:37:23 A.M. Central Daylight Time, worrybear(at)verizon.net writes:
[quote] Jim, How about posting a picture of the plane and 503 installation? Where are you located?
Dan Walter
Druine Turbulent, UltraStar
Posted: Tue Apr 22, 2008 1:03 pm Post subject: UltraStar |
Hi Ben.
I have talked to Homer about this installation at length and he is ok with what I have done I normally cruse at 60 indicated at 4600-4700 rpm. I have had her for 4 years and 100 plus hours a season I need to move up to an all season plane. The 120 was done half way down the 2800 ft runway at 20 foot off the deck just after taking off I didn't do it on purpose just forgot to throttle down after take off.
Thanks Jim
In a message dated 4/22/2008 1:25:43 P.M. Central Daylight Time, bransom(at)ucdavis.edu writes:
| Quote: | --> Kolb-List message posted by: Ben Ransom <bransom(at)ucdavis.edu>
An UltraStar with a 503 is beyond design spec by a lot -- that plane
invincible life.
-Ben
FS KXP
| Quote: | HI Ray.
Jim here.
Jim VanGarsse
2613 M
How is the motor?
Ray
Moni MotorGlider
es y --> - MATRONICS WEB FORUMS nbsp; - List Contribution Web Site ; =========================
jb92563
Posted: Tue Apr 29, 2008 12:01 pm Post subject: Re: UltraStar |
Did you mention your asking price yet?
Moni MotorGlider
Do Not Archive |
