Elevator trim and Kingfox tires
Catz631(at)AOL.COM
PostPosted: Sun Apr 27, 2008 5:21 am    Post subject: Elevator trim and Kingfox tires Reply with quote
Well, as I mentioned earlier, I am now reporting on my new elevator trim installation. In a word it is fantastic! It makes my Kitfox a new airplane! I have the classic version and it was really bugging me to hold back pressure throughout the landing phase. I have had a trim system in every aircraft I have owned except my Kitfox.
I sent the elevator off to Lowell at http://Highwingllc.com . He stripped the fabric and did the necessary modifications to the elevator,recovered,painted to silver and sent it back. Turnaround was about two weeks. He and Mark plan to have a modified elevator on hand so that you could send yours and he will return a completed modified elevator. I couldn't wait so he agreed to modify mine.
I cannot explain in words how happy I am with this mod. The workmanship is great! I installed a "witches hat' trim on the stick and have a LED trim position indicator on the panel. Now just a "blip" or two on final will trim the aircraft hands off in pitch. Also, I no longer need to extend the flaps a little for cruise trim
If anyone would like more info about my installation give me a call at 850-994-9527 (hanger) or 304-7371 (c)
I also have completed the gap closure on my rudder and fin using foam and fabric. It looks much better. I went from a 2 inch gap to about 1/8 inch.
As to the "Kingfox" tires (actually Nanchang 800) I am not sure if like them or not. I bounce along like a semi on my grass runway and tend to woller all over. I will have to give them some time I guess. They do look nice though (like a pair of doughnuts)
I am still having problems with brake authority. The brakes will hold fine at runup but if you swing the tail, it is a bear getting it back straight using the brakes. The brakes are single Matcos. Maybe new brake calipers or a locking tailwheel will help. My tailwheel is the "standard' Maule
      Dick Maddux
      Fox 4-1200
      Rotax 912UL
      Pensacola,Fl
Need a new ride? Check out the largest site for U.S. used car listings at AOL Autos.
pwmac(at)sisna.com
PostPosted: Sun Apr 27, 2008 7:11 am    Post subject: Elevator trim and Kingfox tires Reply with quote
Spring rate is a function of tire pressure. Lower the pressure a few psi at a time until you like the ride.
Proper break in helps with stopping power. Sand the pucks sand start over on break in.
Lots of details on adjusting the break-away on the tail wheel in the archives.
Paul
At 07:18 AM 4/27/2008, you wrote:
[quote]--snip--
Dick Maddux
Fox 4-1200
Rotax 912UL
Pensacola,Fl
dwight purdy
PostPosted: Sun Apr 27, 2008 4:36 pm    Post subject: Elevator trim and Kingfox tires Reply with quote
What pressure are you running in your tires? I am experiencing about the same feelings. While taxing on hard surface.the plane set up a rhythmic bounce without the tires leaving the ground. I have 6 lbs in left and 7.5 in right as I fly solo most the time. What are the rest of you running?
Dwight
Model ll
Dick Maddux
Fox 4-1200
Rotax 912UL
Pensacola,Fl
dwight
model II
Sbennett3(at)aol.com
PostPosted: Sun Apr 27, 2008 4:59 pm    Post subject: Elevator trim and Kingfox tires Reply with quote
Dwight, Anything around 8 lbs is good. Just my opinion. I've been called reckless and stupid on this group in the last 24 hrs so you might want to look further. Smile
When I learned my fox the first thing I did was remove the wheel pants. (no taildragger experience) Then I aired up the tires. You talk about squirrely. I learned quick that running the atv tires only need 7-9 lbs pressure. Steve Bennett N109BB
Catz631(at)aol.com
PostPosted: Mon Apr 28, 2008 4:52 am    Post subject: Elevator trim and Kingfox tires Reply with quote
Paul, thanks for the info on the tailwheel. I found it in the archives. I will try your suggestion on my weak brakes by installing new pucks although my old ones are fine. I will probably have to get new brakes. I have the original setup with Douglas wheels,single piston Matco brakes and plastic brake lines. (maybe I don't have enough pressure)
Here is a picture of my new elevator trim for my classic I purchased from Highwing LLc
        Dick Maddux
        Fox 4-1200
        Pensacola,Fl
 Filesize:  361.89 KB
 Viewed:  440 Time(s)
FlyboyTR
PostPosted: Mon Apr 28, 2008 5:38 am    Post subject: Re: Elevator trim and Kingfox tires Reply with quote
Dick,
Glad to hear you are back in the air! Elevator with trim looks good. Hope to fly with you soon!
Travis Very Happy
Travis Rayner
Mobile, AL
Skystar Vixen, N-789DF
Continental IO-240, Prince P-Tip Prop
ADI-II Autopilot
AnyWhereMap Navigation with weather
www.enotam.net (My Flying Info Website)
