DanFM01(at)butter.toast.n Guest
Posted: Fri Apr 25, 2008 8:52 am Post subject: Hope someone can point me in the right direction for trou |
| Quote: | >When I next started the engine, I could hear what sounded like a loose
>strap blowing and hitting against the bottom of the plane. I have since
>found that this sound is caused by one of the solenoids making a clicking
>noise. This sound would go away if I turned the alternator off, but the
>alternator was outputting power when it was on. The next day, I found
>that I could not get the alternator to output power at all. But&the
>clicking sound was gone!
FYI the clicking sound when starting is a result of low battery voltage.
I've seen this several times in autos. What happens is you turn on the
starter switch which causes the starter solenoid to engage. The starter
comes on line putting humongous load on battery. Battery can't cope and
voltage drops so far that starter solenoid disengages. Starter load is
gone and battery voltage recovers and starter solenoid reengages etc.
The result is a rapid clicking sound.
This can be the result of an old battery or corroded battery cables or
corroded battery terminals or discharged battery or alternator failing
to charge the battery or bad starter or intermittent connections etc.
Basically you just have to check everything.
