Conventional Tail Wheel Conversion
paul.the.aviator(at)gmail
PostPosted: Thu Apr 24, 2008 6:06 pm    Post subject: Conventional Tail Wheel Conversion Reply with quote
Hi all,
I have had a number of "off forum" emails wondering why after nearly
800 hours of monowheel time am I changing to a conventional tail
dragger. Well the reason isn't anything sinister, where I have simply
given up on trying to land the darn thing !!
There are a few things that have prompted my down this route. I had
been doing a bit of research on the topic and it was becoming apparent
that there might not be a drag penalty with conventional gear,
actually after exchanging a few emails with Duncan I am beginning to
think that conventional gear might even have less drag.
Another advantage is that on the ground cooling is much improved. I
find I have a bit of a problem with oil temps bumping up near 250 f
in the summer time.
A few other factors are playing into it, my daughter is wanting to fly
the aircraft and I just can't get comfortable with the idea of her
having to come up to speed with landing it on the pavement. I think I
was probably 100 hours in before I started to feel comfortable.
Getting hull insurance on it with her as PIC would be near impossible.
Why not a Tri gear ? I am not prepared to pay the 40 pound weight penalty
What finally ticked me off was last September the port out rigger
jammed up, I realized it as the aircraft was rolling out so I flicked
the wing up, got it to lock but the violent action caused me to swing
the aircraft around to 90 degrees on the runway and I got a propeller
strike. It was minor, just grazing two blades by a few mm, but it
still put me out of action for 6 weeks and $1500.00 in the hole
I was so irritated by this that I promptly ordered a tail dragger
conversion. The other thing that interests me is that I suspect that
I can make it go faster. Without the wheel in place I can close up
the air outlet, and while I am about it re work the inlet, and re
route the exhaust. I am also speculating that the drag from the "half
wheel" exposed plus the opening is quite significant, perhaps more
than some nicely faired gear legs and wheel pants. Performance
numbers from Duncan suggest that this might be the case.
Lastly the electric flap drive will let get a little more flap travel
so I might be able to add a few degrees of negative reflex in the
flaps.
So, I guess I am going to be busy over the winter.
Cheers, Paul
gregoryf.flyboy(at)comcas
PostPosted: Fri Apr 25, 2008 4:05 am    Post subject: Conventional Tail Wheel Conversion Reply with quote
Thanks, I was silently wondering too.
Greg Fuchs
jrgowing(at)bigpond.net.a
PostPosted: Fri Apr 25, 2008 4:15 pm    Post subject: Conventional Tail Wheel Conversion Reply with quote
Thank you for your thoughts Paul
JR (Bob) Gowing UK Kit 327 in Oz
Venu Rao
PostPosted: Sat Apr 26, 2008 7:46 am    Post subject: Re: Conventional Tail Wheel Conversion Reply with quote
Thanks Paul - a "lurker" on this forum who was also wondering...
still haven't transitioned to the mono and have my concerns
as a very low time pilot.
Venu Rao
Austin, Texas
A058 - Flying
Built by Jim Nelson
Ian Mansfeld
PostPosted: Sat Apr 26, 2008 12:07 pm    Post subject: Re: Conventional Tail Wheel Conversion Reply with quote
I had mine converted about 3 years ago - best move ever (other than the VP prop of course...). It just looks so nice.
I had tailwheel experience and a good check out, but I was never happy balancing on that monowheel. As my instructor said, its not a matter of IF you will groundloop it, just WHEN. It might be 40 hours or 400... The defining moment came when it was parked out overnight and I had a phone call from the airfield to come back as 'something had happened' - it turned out that a wing leg had collapsed while parked! Who wants an aircraft that can't even stay upright while standing still!
With a pair of Duncans lightweight leg fairings, there was no loss of performance. By fitting a set of wheel pants, I probably only gained 3-4 knots but it looks way better. (I used the trigear mains, which looked huge out of the box but when fitted look in proportion. I have had many complementary comments about how right it looks as a taildragger).
And of course ground handling is as easy as any other taildragger. I have handled 15knot crosswinds with no issues (on grass) and the limit is me rather than the aircraft. I self-limit to 12knots crosswind if out of practice for a while.
Ian.
josok-e(at)ukolo.fi
PostPosted: Sat Apr 26, 2008 1:46 pm    Post subject: Conventional Tail Wheel Conversion Reply with quote
Sorry, can't resist, have to take this one on.
There seems to be some guarantee that conventional and tri-gear landings will always be soft and happy. But i can't find any statistics that point in that direction. As a matter of fact, the numbers add up quite differently. And also so far, i have seen more bent trigear legs then tail wheel damage.
My instructors remark about ground looping was made while during circuits in a super cup, and it went like: "There are tail wheel pilots that have ground looped and there are tail wheel pilots that will do it" He had never seen a mono. Now, after some 300 landings in my mono, i am pretty sure that someday i will make the have done class. And i will stay in that "done that be there" class, and blame my own lack lack of proficiency, and not the aircraft. Let alone i change it to something else.
So far the worst landing were when i got confident in nice weather, and the most feared +15 knots crosswind and gusting went off like a dream.
Makes sense, at least to me.
But let there be more airplanes then opinions, and everybody will be happy.
Jos Okhuijsen
Visit - www.EuropaOwners.org
nwcmc(at)tiscali.co.uk
PostPosted: Sun Apr 27, 2008 1:16 am    Post subject: Conventional Tail Wheel Conversion Reply with quote
Conventional gear aircraft are not much less demanding than monowheel.
The main lesson that had to be learnt with monowheel was to keep the
tail on the ground to 40kts on take-off. Also the vulnerable period on
take-off (40 - 50kts)is much reduced with the use of higher power
engines and CS props. I know of one conventional gear Europa has
departed the side of a tarmac runway and sheared off the bottom of its
gear leg so they are not immune to loss of control. The nosewheel on
trigears can receive a lot of loading on grass and nosewheel collapse
has happened on several occasions. Trigears are great if you are only
going to use tarmac runways and are prepared to sacrifice payload, speed
and fuel consumption. With monowheel aircraft landings are more
difficult on tarmac due to the increased directional instability. This
also applies to conventional gear to a slightly lesser extent. The
monowheel has a weight advantage as the reinforced area of the fuselage
for the landing gear coincides with that of the engine. Due to the need
to reinforce the fuselage in a different area both the trigear (and to a
lesser extent the conventional gear) suffer weight penalties.
In my opinion too much blame is placed on the aircraft. Without doubt
greater skill is required to handle the monowheel but most of the
accidents/incidents are down to the pilot which is why the number of
events have reduced over the years as technique and training have been
developed. I know many pilots with many hours of monowheel experience
who haven't groundlooped their aircraft. Many never will, but it would
be tempting fate to claim it. The secret seems to be to take proper
specific type training, learn the specific techniques and operate within
your own limitations which will often be more limiting than that of the
aircraft. After 250hrs I still try to avoid crosswinds of over 10kts
even though I have operated at higher crosswinds on a few occasions.
Crosswind handling is always going to be a bigger challenge for
monowheel and conventional gear aircraft over trigear. Gradually
increasing your personal limit and making an allowance for gusty
conditions is a wise precaution.
In monowheel form the Europa still stands out as a unique aircraft in
terms of grass strip operation combined with fuel efficient cruising.
Once you choose other types of gear there are several similarly
competetive types around such as the Sportcruiser. With the recent hike
in fuel prices even the RV series (another good strip/touring machine)
is starting to feel the pinch in terms of operating costs.
Nigel Charles
grahamsingleton(at)btinte
PostPosted: Sun Apr 27, 2008 1:51 am    Post subject: Conventional Tail Wheel Conversion Reply with quote
Nigel Charles
Nigel
I couldn't agree more. The monowheel was chosen to enable operation from
muddy fields, and it can. There was an occasion when the grass was
longish and the tri gear would not take off 2 up. Jon Tye's monowheel
was used to ferry the passenger to a nearby hard strip. (Ivan was flying
the tri)
Walter Binder's early Classic mono was outstanding, he retracted the
outriggers electrically into the wing, modified the cowlings and the
windscreen. He claimed he cruised at 140kts with an 80hp 912. He also
towed gliders with it.
Walter is a unique character, wish I knew him but my German is not good
enough.
Graham
Venu Rao
PostPosted: Sun Apr 27, 2008 8:39 am    Post subject: Re: Conventional Tail Wheel Conversion Reply with quote
Nigel and Graham,
Thanks for the terrific feedback. I concur that it's all about pilot experience and personal comfort-levels. There are many of us new to the mono's, and several who are in the latter stages of completion, and would dearly like to get some "authorized" training and are willing to pay for it too.
The mono config is unique and elegant, but after reading several threads in the archives about "sensitive handling" and failing to find anyone in the States (Texas!) who can provide some transition training it has me second guessing if I should indeed convert Jim Nelson's beautifully crafted A058 to a conventional gear.
There seems to be a lot of ambivalence in the community on this subject, and it could in large part be mitigated if we had some "formal" training. No doubt hull insurance will go down with fewer accidents to sully the reputation of one of the most beautiful a/c in aviation!
BTW - how can I get more info on Walter's elec. retract outriggers and can they be incorporated as a post build mod?
Thanks, and looking forward to joining you in the skies soon - mono or conventional....Wink
Venu
Nigel Charles
Nigel
the tri)
enough.
Graham
Venu Rao
Austin, TX
Europa Mono
Builder: Jim Nelson
TTAE 119.1 hrs
PostPosted: Sun Apr 27, 2008 3:28 pm    Post subject: Conventional Tail Wheel Conversion Reply with quote
I only have two piks of the outrigger; this was a German guy near
Hamburg whose name I don't have. It was at least 8 years ago. Jens
Gralfs <Jens.Gralfs(at)airbus.dasa.de> might know. Failing him Harald
linke <0406055601-0001(at)T-Online.de>
Graham
Venu Rao wrote:
Nigel and Graham,
Venu
 Filesize:  141.35 KB
 Viewed:  680 Time(s)
 Filesize:  188.7 KB
 Viewed:  684 Time(s)
