Fox5flyer Guest
Posted: Wed Apr 16, 2008 3:09 am Post subject: KF2 Bungie connections |
I received a private email from a Kitfox 2 owner looking for some advice in installing new bungies. He already has the factory new units, but he's having trouble with the configuration of them and not sure how they're connected. What he has is two attach points directly opposite each other, then another underneath a few inches outboard facing down that is perpendicular to the others.
Can someone explain the connections to me or maybe email me a copy of the appropriate page so I can pass it on to him? Would appreciate it.
Deke Morisse
Mikado Michigan
S5/Subaru/CAP 355+ TT
"The aim of an argument or discussion should not be victory, but progress."
- Joseph Joubert
Tom Jones
Posted: Wed Apr 16, 2008 5:58 am Post subject: Re: KF2 Bungie connections |
Deke,
That sounds like it is the same bungee installation system as the Model 4. if you would like that, email me. I can't seem to figure out how to find member emails on here.
_________________ Tom Jones
Classic IV
Ellensburg, WA
Fox5flyer Guest
Posted: Wed Apr 16, 2008 6:24 am Post subject: KF2 Bungie connections |
Thanks Tom. I replied to you offlist.
Deke
Fox5flyer Guest
Posted: Wed Apr 16, 2008 7:04 am Post subject: KF2 Bungie connections |
Thanks Tom. Got the pages just fine and I'll pass them on. Mark will be
very happy.
Deke Morisse
Mikado Michigan
- Joseph Joubert
tc9008(at)aol.com Guest
Posted: Wed Apr 16, 2008 4:32 pm Post subject: KF2 Bungie connections |
I will be changing mine on a 4. Please send the instructions also
Travis
Posted: Wed Apr 16, 2008 4:36 pm Post subject: KF2 Bungie connections |
Travis
Sbennett3(at)aol.com Guest
Posted: Wed Apr 16, 2008 4:48 pm Post subject: KF2 Bungie connections |
I have brand new ones in a box for my classic 4 Can I also get some directions... Thanks in advance. Steve Bennett
Need a new ride? Check out the largest site for U.S. used car listings at AOL Autos.
Catz631(at)aol.com Guest
Posted: Thu Apr 17, 2008 3:06 am Post subject: KF2 Bungie connections |
Me too ! I have new ones also with no directions.Wow ,there are alot of us !
Thanks !
Dick Maddux
Fox 4-1200
Pensacola,Fl
Fox5flyer Guest
Posted: Thu Apr 17, 2008 7:26 am Post subject: Re: KF2 Bungie connections |
| tc9008(at)aol.com wrote: | I will be changing mine on a 4. Please send the instructions also
Travis
To those of you who were asking about the bungie install instructions, thanks to Tom Jones for digging them out, here they are. Hopefully this works.
Deke
S5 Subaru
NE Michigan
51.45 KB |
930 Time(s) |
43.46 KB |
920 Time(s) |
Mark.Summers(at)lwbref.co Guest
Posted: Tue Apr 22, 2008 2:55 am Post subject: KF2 Bungie connections |
A word of caution, the instructions are to grind/file down the aluminum
nico press type sleeve on one end of each bungee. I did this and I have
to assume that the heat caused my brand new bungee rubber bands at the
end to break during the installation. I thought I was going slow enough
to not create that much heat, but the instructions were very good and
very much needed on my part. Thanks
Mark Summers kf2 582 [maybe,eventually]
Beemer
Joined: 26 Aug 2006 Posts: 87 Location: Middle Georgia
Posted: Tue Apr 22, 2008 5:23 am Post subject: Re: KF2 Bungie connections |
WOW!!!
Thanks for posting that. Come to find out, mine are wrong. Guess I'll have to do it correctly now.
Bradley
_________________ Beemer
KF2 (and now an M3!)
Suzuki G10 three-banger
Middle Georgia |
Float Flyr
Posted: Wed Apr 23, 2008 7:34 am Post subject: KF2 Bungie connections |
Mark:
You should never apply any metal that doesn't spark on a grindstone.
Aluminium should only be filed. Filing will cause a little heat but because
it is slower and the filing is more of a cutting action the heat generated
is much lower.
When you grind the aluminium small particles of the aluminium get imbedded
into the stone. The next time the stone is used the particles can expand
and cause the stone to fly apart. With the speed of modern bench top
grinders this can be very dangerous. Fragments of the stone can depart the
grinder at a fearsome rate of knots! I've seen the results of grinding
aluminium in the form of pieces grindstone hanging out of a wall.
Brass, copper and bronze are also best avoided with a grinder.
Noel
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
corbob13
Posted: Wed Apr 23, 2008 6:39 pm Post subject: Re: KF2 Bungie connections |
Timely post on bungee installation. I've just reinstalled a new leg on my machine and was actually attempting the bungee installation earlier this evening. After some colorful comments I thought I should check the forum archives for some tips... and voila, here's a fresh post. I have a comment and a question.
If the bungee is being put on a model 2 (as mine is) the arrangement of the lugs is a bit different than illustrated in the previously posted instruction. I've attached a scan of the manual which illustrates how the cord is wrapped. Note that there are only two lugs; this jives with what's on my plane.
Now the question: How exactly does a guys make six wraps of this thing? Four, easy... Five possible... Six?!? Does anyone have any tricks I could try?
Cory
108.57 KB |
857 Time(s) |
88.92 KB |
866 Time(s) |
_________________ Cory
N903DB
Kitfox Model II, Rotax 582 |
Michel
Posted: Wed Apr 23, 2008 11:21 pm Post subject: KF2 Bungie connections |
| Quote: | From: corbob13 [corbob13(at)netnet.net]
Well ... it's a two-man's job and a lot of cursing. The trick is how not to loose tension as you pull the next loop. Here is what I did at the third attempt but I am not sure it will work for all.
First, in order to keep the gears from collapsing, I make a Spanish windlass with a thick strong rope between the two gears. Then, after the first loop, I use a flat nylon ribbon and tie the bungee with a clove hitch knot. I then tie the end of the ribbon to the thick rope between the gears. Then I do the next loop with another ribbon. Then a third one. Now, I draw the slack in each ribbon and I release the first one to be used as the fourth on.
The reason for using flat nylon ribbons is that it is the only way you can release it from around the bungee loops that are so tight together around the crossbar. The reason for the clove hitch knot is that it is the best knot for anything under constant load. You can untie it very easily. (I have sailed for 50 years!)
Good luck and remember: To curse is human!
Michel Verheughe
Norway
Kitfox 3 - Jabiru 2200
Float Flyr
Posted: Thu Apr 24, 2008 3:39 am Post subject: KF2 Bungie connections |
I put the back loop on first so I would have a straighter pull to tighten
the front. I then put around three turns on the gear and tied a piece of
3/8 rope to it. The rope is also a large loop that I can get a good grab on.
Start at the first loop and tighten it as much as possible. When you have
the third loop tighten continue adding and tightening one turn at a time.
When I got the last turn on and tight I replaced the 38 rope with some
strong string to help me fit the loop over the front stud. What I found
really made installation hard was the small clearance the shock cord has to
pass in the skin.
I have read on past posts where guys have used petroleum jelly to make the
cords slide easier while being installed. I have left my plane on floats
the past two years to avoid having to mess with those chords again
Noel Loveys
AME Intern, RPP
Kitfox III-A, 582,B box
Ivo IFA, Aerocet 1100 floats
Kitfox III-A
dave
Posted: Thu Apr 24, 2008 4:40 am Post subject: Re: KF2 Bungie connections |
| Quote: | Now the question: How exactly does a guys make six wraps of this thing? Four, easy... Five possible... Six?!? Does anyone have any tricks I could try?
Cory |
Well my Model has run last 2 years on wheels and skis with 5 wraps on bungees over 10 years old. Other than about 4 months a year on amphibs. IT a bit softer but it does seem to work. Just make sure you use safety cables although some here will try to tell you different.
I do what works -- eom
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
thesupe(at)hotmail.com Guest
Posted: Thu Apr 24, 2008 5:41 am Post subject: KF2 Bungie connections |
I just put the bungees back on my Avid MK IV yesterday and it took less than 15 minutes for my son and myself. One trick is to mark the bungees with a marker--devide the length of the bungee by the number or raps and mark there and then halfway between each mark. One person above, one person below. Each person now has a mark to strech the bungee to, then he holds it there, passes the end to the other person who pulls the bungee tight to his mark, ect, ect. When you get to the end, the right length of bungee is there to hook on and all the raps have equal tension. Hope this helps, Jim Chuk Avids Kitfox 4 Mn
[quote] From: noelloveys(at)yahoo.ca
Subject: RE: Re: KF2 Bungie connections
Date: Thu, 24 Apr 2008 09:06:48 -0230
--> Kitfox-List message posted by: "Noel Loveys" <noelloveys(at)yahoo.ca>
pass in the skin.
Noel Loveys
AME Intern, RPP
Guy Buchanan
Posted: Thu Apr 24, 2008 7:04 am Post subject: KF2 Bungie connections |
tricks I could try?
Cory,
Check the archives again! This topic gets covered at least
once a year and there are innumerable methods. Mine is to get 4
wraps, then pull the slack to one end using channel-locks, then clamp
the 3rd wrap to the tube using vice grips and leather, then get two
more wraps, repeat until you get six. You can do it solo and with not
much cursing.
Guy Buchanan
San Diego, CA
Deceased K-IV 1200
A glider pilot too. |
peteohms
Posted: Thu Apr 24, 2008 8:04 am Post subject: KF2 Bungie connections |
Don't use petroleum jelly. It attacks rubber. Maybe KY?
Pete
PS I'm still offering a free bungee to anyone in need. Got it with my
Kitfox III. Just pay the shipping.
_________________ Pete
Leander, TX
Kitfox III, 912ul, Grove |
bjones(at)dmv.com Guest
Posted: Thu Apr 24, 2008 8:27 am Post subject: KF2 Bungie connections |
I used a similar method solo. Measured and marked where bungees should go
around tubes when completed, streched bungees till beyond that location
knowing there would likely be some slippage and used padded vice grips to
hold for next wrap or two. Biggest problem was blisters on my apparently
tender paws from not wearing gloves and streching bungees bare pawed. Used
kitfox factory bungees rather than risk wrong material or technique, and
duplicated number of wraps on 10 year old originals that began sagging a
little when loaded.
Bob Jones
N154K/N626NR
