nuckolls.bob(at)cox.net Guest
Posted: Tue Apr 22, 2008 5:59 am Post subject: Brownout Battery System P.S. |
I've been pondering this discussion for the last day or so and
I wasn't pleased with the lack of elegance. It seemed that your
design goals were not well served with the present suite of hardware
(too heavy).
An FMEA study of Z-13/8 yields and excellent reliability scenario
but it cannot address the fact that some modern EFIS products are
unable to deal with the real world of millisecond long, bus brownout
during starter-inrush loads. See:
http://www.aeroelectric.com/Pictures/Curves/99_Saturn_SL1.jpg
Indeed, no single-battery systems is designed to provide
a constant source of power that stays inside the operating
envelope of these computer based products.
One obvious solution is a second battery. The question is
how big? It only needs to supply power to a limited suite of
ship's hardware for a few tens of milliseconds while the starter
motor spins up at the onset of each cranking cycle. In terms
of ENERGY, the requirements are trivial. So the real sizing
considerations are for internal impedance of the battery. Ideally,
we'd like to put an array of AA NiMh cells in to support the e-bus
during brownout . . . but these cells have finicky charging
requirements. It's not that they wouldn't do the job . . . but
system design issues are more complex and parts count goes
up.
So what's a reasonable middle ground? Take a peek at:
Take a peek at this drawing I did last night:
http://www.aeroelectric.com/PPS/Adobe_Architecture_Pdfs/Z13-8A(BrownOutBattery).pdf
Here I've suggested that you dump the #2 fat battery and
the fat contactors associated with #2 master and crossfeed.
Install a much smaller (7.2 AH, 5.5# 0.04 ohm) "brownout
battery" and a pair of cube power relays wired such that
the e-bus is supported ONLY by the brownout battery during
engine cranking and only while the main bus is loaded so
heavily that it cannot keep the EFIS from resetting.
This same technique could be added to any single battery
system (or even Z-14 where you wanted to use both batteries
for cranking). This modification to Z-13 does not burden the
SD-8 with supporting fat contactors that are never expected
to carry cranking currents . . . hence may be ably replaced
with smaller, plastic relays.
P.S. Here's an exemplar battery that seems well suited to
this task:
http://aeroelectric.com/Mfgr_Data/Batteries/Panasonic/LC-R127R2P.pdf
Bret Smith
Joined: 09 Jan 2006 Posts: 178 Location: Mineral Bluff, GA
Posted: Tue Apr 22, 2008 7:58 am Post subject: Brownout Battery System P.S. |
At 10:41 AM 4/22/2008 -0400, you wrote:
Yeah . . . but the only time the brownout battery gets
properly attached to the system for charge maintenance is
when the e-bus alternate feed switch is closed.
The architecture I posted keeps the brownout battery
connected across the main battery at all times except while
cranking the engine. Zero demands on pilot for proper
orientation of switches.
grjtucson
Posted: Tue Apr 22, 2008 8:14 am Post subject: Re: Brownout Battery System P.S. |
Bob . . . |
Bob,
I like the new drawing but help me out in understanding how the E-Bus alternate feed relay gets energized and thus energizes the e-bus in the event the master switch is open. If I don't have power to the main bus, there is no power to the e-bus unless the alt. feed relay is closed, but the only way for the alt. feed relay to close is for there to be power to the e-bus.
Shouldn't the alt. feed relay magnet positive terminal come from the BATTERY bus and then go to the switched ground, or be switched power to that positive terminal and then go to ground?
Unless I am totally missing something...
George
Tucson, AZ
RV-7
_________________ George Jenson - http://www.georgejenson.com
Tucson, AZ - RV-7 Standard Build
Empennage Completed 1/06
Wings Completed 11/06
Fuselage in Progress |
rshannon
Posted: Tue Apr 22, 2008 8:35 am Post subject: Brownout Battery System P.S. |
On Tue, Apr 22, 2008 at 6:54 AM, Robert L. Nuckolls, III <nuckolls.bob(at)cox.net (nuckolls.bob(at)cox.net)> wrote:
| Quote: | ..
this task:
Bob,
I like the idea of using the starter switch to trigger brown out protection.
Although my AFS EFIS's aren't subject to the dropout (they will go to their internal backup battery automagically if needed) I'm thinking of using the AUX battery mgmt. module scheme, which includes manual switching to bring the AUX battery back online to extend E-bus life. Presumably, it won't be hard to parallel the starter switch with the AUX battery mgmt. manual switch to combine the functionality.
Also, FWIW, B&C has a similar battery (BC102-1) that is listed as 0.45 pounds lighter than the Panasonic.
Ron
Posted: Tue Apr 22, 2008 8:48 am Post subject: Brownout Battery System P.S. |
Bob,
that positive terminal and then go to ground.
Good eye! Thank you. I've published revision B
to correct the error at:
http://www.aeroelectric.com/PPS/Adobe_Architecture_Pdfs/Z13-8B(BrownOutBattery).pdf
Posted: Tue Apr 22, 2008 10:35 am Post subject: Brownout Battery System P.S. |
At 09:30 AM 4/22/2008 -0700, you wrote:
| Quote: | On Tue, Apr 22, 2008 at 6:54 AM, Robert L. Nuckolls, III
><http://www.aeroelectric.com/PPS/Adobe_Architecture_Pdfs/Z13-8A%28BrownOutBattery%29.pdf>http://www.aeroelectric.com/PPS/Adobe_Architecture_Pdfs/Z13-8A(BrownOutBattery).pdf
> this task:
><http://aeroelectric.com/Mfgr_Data/Batteries/Panasonic/LC-R127R2P.pdf>http://aeroelectric.com/Mfgr_Data/Batteries/Panasonic/LC-R127R2P.pdf
Bob,
? if your EFIS is already brown-out proof, what's the
task for an aux battery?
| Quote: | Also, FWIW, B&C has a similar battery (BC102-1) that is listed as 0.45
Yeah, there's a bunch of possibilities. I'm still pondering
a DIY project or perhaps a product for incorporation of some
small capacity (read light weight) energy storage devices
into an automatically managed brown-out battery assembly.
rshannon
Posted: Tue Apr 22, 2008 12:10 pm Post subject: Brownout Battery System P.S. |
task for an aux battery? |
If I do add an AUX battery, it would be for extended E-bus run time. I wouldn't add AUX battery weight for brown out protection alone, unless there was something else....
Wait! It would also keep my IIRG (Intergalactic Ionic Ray Gun) from rebooting! Perfect!
Ron
Posted: Tue Apr 22, 2008 7:17 pm Post subject: Brownout Battery System P.S. |
At 01:06 PM 4/22/2008 -0700, you wrote:
| Quote: | > ? if your EFIS is already brown-out proof, what's the
rebooting! Perfect!
If you have an SD-8 in addition to the ship's main alternator,
then you essentially enjoy unlimited e-bus endurance irrespective
of the capacity of the ship's battery.
Z-13 lets you run a battery until it doesn't crank the engine
any more. Battery only endurance is not part of the "plan-B".
( -Thomas Paine 1776- )
rshannon
Posted: Tue Apr 22, 2008 8:12 pm Post subject: Brownout Battery System P.S. |
| Quote: | If you have an SD-8 in addition to the ship's main alternator,
Understood. Per other thread, I do have an SD-20S for backup ALT, so the plan C,D,E... AUX battery addition here is not compelling, as you suggest.
However, if I do have to go to the E-bus, perhaps due to a stuck starter, requiring shutdown of the main contactor even with an alternator still available, then battery endurance may be an issue, even if not a worry. Other than that, I might want independent capacity for ground ops (light, audio, radios, gizmos...) in the boonies with this mini bush plane. Those are probably the only things that would lead me to commit 6 lbs. (+/-) to an AUX battery system.
Ron
Posted: Wed Apr 23, 2008 5:43 am Post subject: Brownout Battery System P.S. |
At 09:02 PM 4/22/2008 -0700, you wrote:
| Quote: | > If you have an SD-8 in addition to the ship's main alternator,
> Bob . . .
??? how do you get a stuck starter contactor in flight?
| Quote: | . . .requiring shutdown of the main contactor even with an alternator
Agreed.
Thomas.N.Gautier(at)jpl.n Guest
Posted: Wed Apr 23, 2008 9:27 am Post subject: Brownout Battery System P.S. |
Bob,
I looked at your Z13-8B(BrownOutBattery).pdf. It seems to me
that the only reason not to hook a battery like the Panasonic LC-R127R2P
directly to the endurance bus and do away with the brown-out
battery relay, alternate feed relay and the E-bus alternate feed switch
is that the battery won't charge properly through the diode
connecting the main bus to the endurance bus. However, what if you use
a shottky diode for the main bus/endurance bus connection?
The power shottky on the Perihelion Design site apparently has about
0.2v forward drop. The Panasonic spec sheet you pointed to says, if I
read it right, that the battery needs 13.6-13.8 v terminal voltage to trickle
charge. So the brown-out battery should stay charged OK if the alternator
is regulated to supply more than 14.0 v, which I understand it has to do to
keep the main battery charged.
Am I missing something simple (or subtle) that makes this not work or
a bad idea?
Nick Gautier
RV-10, in progress
At 06:59:06 AM PST US 4/22/2008 you wrote:
| Quote: | I've been pondering this discussion for the last day or so and
(too heavy).
~snip~
| Quote: | Here I've suggested that you dump the #2 fat battery and
~snip~
Posted: Thu Apr 24, 2008 8:23 am Post subject: Brownout Battery System P.S. |
At 10:22 AM 4/23/2008 -0700, you wrote:
<Thomas.N.Gautier(at)jpl.nasa.gov>
Bob,
You always need the alternate feed relay (or switch). You don't want
to leave the e-bus hot when the airplane is parked. You also need a way
to pre-flight the normal feedpath.
| Quote: | The power shottky on the Perihelion Design site apparently has about
The Shottky diode is alluring . . . but it needs to
be insulated from ground and perhaps heat-sinked. It's
also probably more expensive than the plastic cube relay.
Having said that, since the brown-out battery is not needed
to bolster capacity and is only expected to carry a load for
tens of milliseonds per flight cycle, then the diode is certainly
an option. Diode isolation would be the architecture of choice for the
capacitor based brown-out technique discussed in the earlier
post.
But in either case, the alternate feedpath switch/relay is
called for.
| Quote: | Am I missing something simple (or subtle) that makes this not work or
a bad idea?
Keep in mind that during battery only operations, this same
diode would be in series with a voltage source that is
already depressed below 'normal' bus voltage. What you
propose would probably function at some level. But for the
moment, I'll have to continue to champion hard-closed contacts
of relays and switches as being more efficient and lower cost
of ownership without impacting system reliability.
Now, a Shottky diode in the normal feedpath is certainly
an option. But the "advantage" of lower voltage drop looses
its luster . . . while the alternator is running you have
watts-to-burn. So I'll suggest that the selection of this
diode should include considerations of cost and convenience
in mounting.
