SkyTec Starter Wiring Warning
n212pj(at)gmail.com
PostPosted: Thu Apr 17, 2008 7:50 am    Post subject: SkyTec Starter Wiring Warning Reply with quote
Probably everyone knows about this but me, but since I just fried my
oil-soaked SkyTec starter on my GlaStar, I was perusing their web pages and
found this:
http://www.skytecair.com/Wiring_diag.htm
Scroll down to the RV-10 wiring warning. If the shoe fits...
John Jessen
40328 building
GlaStar flying
VHMUM(at)bigpond.com
PostPosted: Thu Apr 17, 2008 2:25 pm    Post subject: SkyTec Starter Wiring Warning Reply with quote
No I did not know this does anyone know if Vans updated there plans as mine
show to remove the jumper which will make it 24 volts!.
regards Chris
msausen
PostPosted: Fri Apr 18, 2008 6:26 am    Post subject: SkyTec Starter Wiring Warning Reply with quote
Which starter is Van selling with the FWF now? If it's the LS then I believe the original diagram is correct. If it's now the NL then the new diagram is correct. As always you should review the instructions from the manufacturer in addition to Van's. You know they will always fall back on what the manufacturer says.
Michael
Tim Olson
PostPosted: Fri Apr 18, 2008 6:43 am    Post subject: SkyTec Starter Wiring Warning Reply with quote
Mine wasn't from Van's, but it was recommended to me to go
with the HT.
RV Builder (Michael Sausen) wrote:
<rvbuilder(at)sausen.net>
Michael
Ray.R.Doerr(at)sprint.com
PostPosted: Fri Apr 18, 2008 6:45 am    Post subject: SkyTec Starter Wiring Warning Reply with quote
You don't get a Starter in the Van's FWF Kit.
Thank You
Ray Doerr
jesse(at)saintaviation.co
PostPosted: Fri Apr 18, 2008 6:50 am    Post subject: SkyTec Starter Wiring Warning Reply with quote
The starter isn't part of the FWF. It's part of the engine. I don't
know which one is included with which engine, but that depends on
where you buy your engine, I imagine. The alternator is included in
the FWF, and it is currently the Plane Power 60A.
Jesse Saint
Saint Aviation, Inc.
jesse(at)saintaviation.com
Cell: 352-427-0285
Fax: 815-377-3694
Michael
Deems Davis
PostPosted: Fri Apr 18, 2008 7:12 am    Post subject: SkyTec Starter Wiring Warning Reply with quote
IF you have a prop/blade 'kick-back' the lightweight starter (LS) will
fail. (It's happened to many). The Hi Torque starter was designed to
eliminate that problem. Initially my engine had the LS but I upgraded it
to the Hi Torque upon learning about the kickback issue. when you order
your engine you should speficy the Hi Torque. (NL) starter.
Deems Davis # 406
'Its all done....Its just not put together'
http://deemsrv10.com/
with the HT.
> Michael
msausen
PostPosted: Fri Apr 18, 2008 7:35 am    Post subject: SkyTec Starter Wiring Warning Reply with quote
I wasn't sure anymore what came with the FWF kit as I deleted so many things from it and added a couple like the PP alternator which wasn't standard yet then.
One thing to note, if you end up with an LS there is a good chance Skytec will swap it for you for the difference assuming it's still NIB. If not you can probably sell it on eBay fairly easily considering how often the LS get mangled. The NL is definitely preferred for our engines nowadays.
Michael
ricksked(at)embarqmail.co
PostPosted: Fri Apr 18, 2008 8:08 am    Post subject: SkyTec Starter Wiring Warning Reply with quote
If you should shear the shearpin from kickback on the HT model, Skytec has placed a spare in RTV in the recess on top of the starter. A pretty easy fix away from home.
Rick Sked
40185
tomhanaway
PostPosted: Fri Apr 18, 2008 9:00 am    Post subject: Re: SkyTec Starter Wiring Warning Reply with quote
Ok, I've got a dog in this fight since I just ordered an IO-540 from Van's as part of their promotion.
The Van's Lycoming engine comes with the LS starter on the crated engine. Since it's part of the OEM contract with Van's, it can't be changed. If you're ordering from an after market builder, you can specify the NL.
I then spoke to the tech at Sky-Tech. The LS has a higher current draw than the NL and may not turn over the engine IF you've done a shoddy wiring job. The NL is recommended for that reason.
As to kickback, that can happen depending on settings of a magneto. In my case, I plan to go with PMags for both. Skytech advised that they worked specifically with the PMag system guys to ensure that a kickback won't happen.
Bottom line-Skytech changed the recommendation from LS to NL based on several engines having slow turnover due to restrictive wiring or low battery power.
So I'll stay with the LS unless I do have a problem. If I was starting from scratch on the engine, I'd get the NL.
Tom H.
Boynton Beach, FL[color=black]
[/color]
