jpx(at)Qenesis.com Guest
Posted: Wed Apr 16, 2008 6:57 am Post subject: Grommets |
I was surprised to find halves of grommets lying on the floor of my
hangar the other day. In January, they were installed in the leading
edge ribs. It has been too cold here in Toronto to do much work on my
plane since then.
As far as I can tell, the holes in the aluminum ribs shrunk from the
cold and cut the grommets in half. I am glad I found this out before
pulling all the wires through !
The holes were drilled a hair smaller than the grommets, which fit
nicely without bunching up. The holes were carefully deburred and I
can rotate my finger in the holes without feeling a sharp edge.
The grommets I purchased from Spaenaur rather than the local hardware
store. They are specd as material: SBR, hardness: 60 durometer +/-5.
Are these grommets the wrong material ?
Should there be slack around the grommet when fitted in the hole ?
Some other problem I haven't thought of ?
Jeff Page
Dream Aircraft Tundra #10
echristley(at)nc.rr.com Guest
Posted: Wed Apr 16, 2008 7:32 am Post subject: Grommets |
Jeff Page wrote:
plane since then.
That would be my guess. If it was too cold to work on the plane and you
believe the aluminum shrunk, then the grommet were possibly as brittle
as glass. One of the techniques for manufacturing rubber bushings is to
freeze them and then machine them like metal. They got nice and brittle
(but probably didn't shrink much), and then the aluminum closed in on
them. Probably happened several times.
Try keeping a 60W lightbulb turned on in the plane.
sportav8r(at)gmail.com Guest
Posted: Wed Apr 16, 2008 7:57 am Post subject: Grommets |
60W light bulb isn't going to help much at altitude. It gets COLD up there. I'd suggest a re-do with looser holes or different material. Just my $.02
-Bill B
On Wed, Apr 16, 2008 at 11:27 AM, Ernest Christley <echristley(at)nc.rr.com (echristley(at)nc.rr.com)> wrote:
[quote]--> AeroElectric-List message posted by: Ernest Christley <echristley(at)nc.rr.com (echristley(at)nc.rr.com)>
Jeff Page wrote:
| Quote: | --> AeroElectric-List message posted by: Jeff Page <jpx(at)Qenesis.com>
I was surprised to find halves of grommets lying on the floor of my hangar the other day. In January, they were installed in the leading edge ribs. It has been too cold here in Toronto to do much work on my plane since then.
As far as I can tell, the holes in the aluminum ribs shrunk from the cold and cut the grommets in half. I am glad I found this out before pulling all the wires through !
The holes were drilled a hair smaller than the grommets, which fit nicely without bunching up. The holes were carefully deburred and I can rotate my finger in the holes without feeling a sharp edge.
The grommets I purchased from Spaenaur rather than the local hardware store. They are specd as material: SBR, hardness: 60 durometer +/-5.
| That would be my guess. If it was too cold to work on the plane and you believe the aluminum shrunk, then the grommet were possibly as brittle as glass. One of the techniques for manufacturing rubber bushings is to freeze them and then machine them like metal. They got nice and brittle (but probably didn't shrink much), and then the aluminum closed in on them. Probably happened several times.
rob(at)hyperion-ef.com Guest
Posted: Wed Apr 16, 2008 8:20 am Post subject: Grommets |
While not disputing that the grommets failed, I must question your
explanation. The coefficient of thermal expansion for aluminum alloy 3003
(a common sheet alloy) is 12.9 microinch/inch deg F, so doing the math for a
1 inch diameter hole and a temperature change from a really hot 100 deg F
day for installation and a really cold minus 50 deg F day during the winter
you get a worst case diameter change of slightly less than .002 inch. A
half inch diameter hole would change less than .001 inch for the same
temperature change.
Installing the grommets into an undersize hole, thus stressing the grommet,
is probably the culprit, not contraction alone.
Best regards,
Rob Housman
Irvine, CA
Europa XS Tri-Gear
A070
Airframe complete
Flagstone(at)cox.net Guest
Posted: Wed Apr 16, 2008 8:21 am Post subject: Grommets |
Jeff:
Your finding has me concerned. Could you provide the following details:
1 Grommet Dimensions or Spaenaur part #:
Inside Diameter
Groove Diameter
Outside Diameter
Groove Width
Overall Thickness
2 Hole Diameter
3 Rib thickness
Were the wires in conduit? If so what was the outside diameter of the
conduit.
Do you have a pic of the installed grommet and the split grommet you can
post?
Mark
Posted: Wed Apr 16, 2008 8:53 am Post subject: Grommets |
Bill Boyd wrote:
| Quote: | 60W light bulb isn't going to help much at altitude. It gets COLD up
my $.02
OK. A 120W bulb.....and a really long drop cord. 8*)
Posted: Thu Apr 17, 2008 5:17 am Post subject: Grommets |
Mark,
Here is the link to the grommet info:
http://www.spaenaur.ca/pdf/sectionJ/J69.pdf
The grommets are not all the same size, but most are 315-263. So the
groove diameter is 7/16 and I would have drilled 27/64" holes.
I think the ribs are 6061-T6 32 thou.
Unfortunately, I have a bad cold, so I won't be able to visit the
hangar to take photos. If you held a grommet in your fingers and
sliced it vertically with a dull knife, tearing as well as cutting,
that's what they look like.
I pushed the grommets in when it was about freezing temperature, but
they were still quite pliable. They were not difficult to install
using just my fingers. It didn't run any wire or conduit in them,
just left them there. The frame of the wing is rivetted, but the
skins are not on it yet. It is just sitting on the workbench.
As long as the SBR material is considered aviation quality, I expect I
just need larger holes.
Jeff
| Quote: | Time: 09:21:58 AM PST US
Subject: Re: Grommets
Inside Diameter
Groove Diameter
Outside Diameter
Groove Width
Overall Thickness
2 Hole Diameter
3 Rib thickness
conduit.
post?
Bubblehead
Joined: 26 Oct 2007 Posts: 48 Location: N. Richland Hills, TX
Posted: Thu Apr 17, 2008 6:03 am Post subject: Re: Grommets |
| rob(at)hyperion-ef.com wrote: | While not disputing that the grommets failed, I must question your
temperature change.
Best regards,
Rob Housman
Irvine, CA
Europa XS Tri-Gear
A070
Airframe complete
Rob - I think you're using the coefficient for the aluminum and then computing the change based on the size of the hole. The change in hole size is because of the change in the aluminum size. 1" or 1/2" hole doesn't matter - only the amount of aluminum around the hole!
Actually, as the aluminum cools wouldn't it contract, making the hole bigger? The temperature would have to rise so the aluminum expands to make the hole smaller.
My opinion is the bushings got brittle and maybe had flaws or residual stresses that made them break. I doubt change in hole diameter had anything to do with it.
John
_________________ John
Keller, TX
RV-8 N247TD |
Posted: Thu Apr 17, 2008 6:35 am Post subject: Grommets |
Jeff:
That's all I need to work with. Thanks
Hope you feel better
Mark
bob(at)bob-white.com Guest
Posted: Thu Apr 17, 2008 6:56 am Post subject: Grommets |
On Thu, 17 Apr 2008 07:03:17 -0700
"Bubblehead" <jdalman2000(at)yahoo.com> wrote:
<snip>
John
John Dalman
Elburn, IL
RV-8 N247TD
Hi John,
When you're looking at the dimensional change in the material, you have
to look at the overall dimensions of the item. Say you have a piece of
aluminum 10 inches X 10 inches with a 1 inch dia hole in the center.
If a drop in temperature causes the material to shrink 0.001 inch per
inch (just to pick a number), the new dimensions will be 10 thousandths
less or 9.99 X 9.99 and the inside hole will be .999 inches in dia.
The size of the internal hole will be the same as if the material was
still there.
Bob W.
N93BD - Rotary Powered BD-4 - http://www.bob-white.com
3.8 Hours Total Time and holding
Cables for your rotary installation - http://roblinstores.com/cables/
hooverra(at)verizon.net Guest
Posted: Thu Apr 17, 2008 6:57 am Post subject: Grommets |
Jeff,
Just a guess but exposure to solvents could breakdown SBR. I cannot
imagine that hole size alone is the issue.
http://www.alliedrubber.com/Gasket/SBRRubber.cfm.htm
"When exposed to petroleum derivatives, the performance of this rubber is
inferior to many other synthetics. Red SBR rubber is popular for use as a
gasket in low pressure applications such as washers and gaskets for the
heating and plumbing trades. Black SBR is commonly used for abrasion
conditions such as skirtboard and chute lining."
Ralph & Laura Hoover
RV7A N527LR
Posted: Thu Apr 17, 2008 12:39 pm Post subject: Grommets |
I'm glad to hear that I wasn't the only student that did not fall asleep in
freshman physics lecture.
Best regards,
Rob Housman
Irvine, CA
Europa XS Tri-Gear
A070
Airframe complete
bhcishere(at)ca.rr.com Guest
Posted: Thu Apr 17, 2008 1:00 pm Post subject: Grommets |
Heat makes the hole bigger. Haven't you ever had to remove a stubborn bolt?
That is done with a torch to make the hole bigger.
Bryan
mrspudandcompany(at)veriz Guest
Posted: Fri Apr 18, 2008 4:17 am Post subject: Grommets |
[quote]Jeff, Unless you live on the South Pole in the middle of winter, there is no way that normal grommets, as you described them, will just split apart and fall off!! The expansion/contraction of the aluminum is so small as to not be a factor. Are you sure someone didn’t cut them off, just to play a mind game with you?? Roger [b]--
Posted: Fri Apr 18, 2008 6:36 am Post subject: Grommets |
AeroElectric-List Digest Server <aeroelectric-list(at)matronics.com> wrote:
[quote] *
Today's complete AeroElectric-List Digest can also be found in either of the
of the AeroElectric-List Digest and can be viewed with a generic text editor
HTML Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 08-04-17&Archive=AeroElectric
Text Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 08-04-17&Archive=AeroElectric
AeroElectric-List Digest Archive
Total Messages Posted Thu 04/17/08: 22
Today's Message Index:
1. 04:49 AM - Re: Ground Power - Z31A (Robert L. Nuckolls, III)
2. 04:56 AM - Re: Re: Rear Mounted Batteries - more questions
3. 05:49 AM - "Chubby" wires and fuseblocks (Robert L. Nuckolls, III)
4. 06:13 AM - Switch ratings (Robert L. Nuckolls, III)
5. 06:17 AM - Re: Grommets (Jeff Page)
6. 07:06 AM - Re: Grommets (Bubblehead)
7. 07:35 AM - Re: Re: Grommets ()
8. 07:56 AM - Re: Re: Grommets (Bob White)
9. 07:57 AM - Re: Grommets (RALPH HOOVER)
10. 01:39 PM - Re: Re: Grommets (Rob Housman)
11. 02:00 PM - Re: Re: Grommets (Bryan)
12. 02:14 PM - Thermal expansion (was Grommets) (raymondj)
13. 03:12 PM - Re: Rear Mounted Batteries - more questions (n277dl)
14. 05:44 PM - A Bit of Help, Please (Speedy11(at)aol.com)
15. 06:44 PM - Re: A Bit of Help, Please (Joemotis(at)aol.com)
16. 06:55 PM - Questions on avionics ()
17. 07:13 PM - pinout for Softcom ATC-P intercom?? (Charlie England)
18. 07:22 PM - Re: A Bit of Help, Please (Robert L. Nuckolls, III)
19. 07:42 PM - Re: Re: Transponder for sale (mode S) (Charlie England)
20. 07:48 PM - Re: Questions on avionics (Ernest Christley)
21. 08:28 PM - Re: Questions on avionics (Mike)
22. 08:34 PM - Re: Questions on avionics (Mike)
________________________________ Message 1
_____________________________________
Time: 04:49:12 AM PST US
From: "Robert L. Nuckolls, III" <nuckolls.bob(at)cox.net>
Subject: Re: Ground Power - Z31A
At 11:38 PM 4/16/2008 +0200, you wrote:
> Bob
> Please can you confirm the correct procedure for using the ground power on
> Z31a architecture.
> Is it imperative to first switch on the "ground power" switch, before
> switching on the master switch?
No. The ground power may be turned on at any time in the
starting sequence without regard to damage to the system.
The ground power circuits as depicted are reverse polarity
and ov protected . . .
> Would I just switch ground power off, once the aircraft has started?
Yes.
> What would happen if ground power switch was inadvertantly left on for an
> indefinite period, or turned on whilst the aircraft engine was running?
No big deal. IF the ground power source voltage was set
higher than your ship's regulator, your alternator
would not come on line and pick up system loads as long
as the ground power was connected. If you're getting a
start from a battery cart - as ship's systems came
alive, your ship's alternator would begin to charge/
re-charge ALL batteries in the system . . . including those
in a still connected ground power cart.
If you're using external power from an engine driven or
AC mains powered cart, then would would expect the external
voltage source to be set at "battery charging" voltage
levels (14.2 or 28.5). In this case, you could turn on
ground power long before closing the master switch and
let ground power replenish you ship's battery. After
15 minutes or so, your ship's battery may well contain
sufficient snort to start your engine and ground power
could be disconnected for the start an subsequent
pre-flight. If the ground power is a battery cart,
then no charging of the ship's battery can take place
and you're obligated to use ground power to get the
engine started. After starting, you'd want to turn
ground power off so that ALL of your ship's alternator
output was being used to replenish stored energy in
the ship's battery.
In cold weather, you may wish to use ground power
as a routine assist for getting the engine
started even if your battery is in good shape.
Aside from the possibility of too much ground power
voltage and/or reversed polarity, there are no risks to
your airplane's systems that warrant concern. Making
ground power managed from the pilot's seat
puts you in control of this resource for the purpose
of addressing the task at hand.
It's an energy management problem with solutions
determined by equipment available, condition of
your battery and immediate goals. I recall reading
a story many moons ago where a pilot used his ground
power jumper cables to get his car started using
his airplane's battery after returning from a trip
and finding the car battery was not up to the task.
> Your assistance as always is appreciated.
Pleased to be of service sir!
________________________________ Message 2
Time: 04:56:17 AM PST US
Subject: Re: Re: Rear Mounted Batteries - more questions
At 02:54 PM 4/16/2008 -0700, you wrote:
> Bob and list,
> Using the previously attached document as reference...
> Assumptions... rear mounted batteries. Main Bat Cntctr, Aux Bat cntctr
> and Xfeed Cntctr all mounted in rear beside the batteries.
Hmmmm . . . normally we'd like to see the cross-feed contactor
mounted on the firewall. This provides nice fat-wire terminals
from both batteries to serve as distribution points for the
two batteries in addressing their respective tasks.
> 2awg ground wire to fwd central gnd bus attached to the engine via stud
> through firewall. XFEED cnctr closed for starting. 2AWG wire from the
> same side of XFEED cntctr that the main bat cntctr is connected to
> starter cntctr.
Okay . . .
> Questions.... Can I then run appropriate sized wire (tbd) from the same
> side of the starter cntctr as the 2awg wire is attached to the main pwr bus?
Yes. If your cross-feed contactor were up front
then the battery distribution tie point would be
on the cross-feed contactor. With the configuration
you've described, then the starter contactor becomes
the tie point.
> If so, I also assume I would run appropriate sized wire ~8-10 awg (but not
> the heavy 2awg) from aux bat side of the XFEED to the Aux bus and use same
> wire to from the aux alt (prob 8 amp b&C alternator).
Oops . . . sounds like you're describing a Z-14
architecture using an SD-8 on the aux side. Not
recommended due to aux battery contactor loads being
such a significant portion of the SD-8's output.
Suggest a Z-13 architecture is more appropriate to
maximizing the capabilities of the SD-8.
> Hope this makes sense. Really just trying to understand if I can only run
> two fat wires from the batteries to the firewall if I want to ground at
> the firewall or need to pull the extra "hot fat wire".
Let's talk about your architecture and choices
of hardware to fill the various slots. What
shortcomings do you perceive with a Z-13 architecture
that drives you toward dual batteries?
( -Thomas Paine 1776- )
________________________________ Message 3
Time: 05:49:19 AM PST US
Subject: "Chubby" wires and fuseblocks
> Comments/Questions: I dont' undestand how to connect large current loads
> to FASTON fuse blocks.
> Max wire into FASTON seems to be #10
> Fuses up 30A are sold by B&C
> Most #10 wire is not rated for 30A.
I don't know of any #10 wire that is not rated for
30A in airplanes.
> What am I missing?
I don't recommend any fuses beyond 14AWG/15A be used
in the fuse blocks. What systems are you wiring
that demand the use of larger wire/fuses?
________________________________ Message 4
Time: 06:13:51 AM PST US
Subject: Switch ratings
> Comments/Questions: Hi Bob,
> Re: S700-2-10 switch
> What is the current rating for this switch?
The S700 series switches are Carling G-series devices.
The data sheet for this line of products may be reviewed
at:
http://www.aeroelectric.com/Mfgr_Data/Switches/Carling_G-series.pdf
Note that these are rated at up to 20A in 120VAC systems.
In the article at:
http://aeroelectric.com/articles/Switch_Ratings.pdf
we explore the simple ideas behind current ratings
and service life of switches as installed in various
working environments.
> I would like to use this switch to turn on rotating beacons (12 amps) and
> strobe lights (11 amps) using the circuit in figure 11-18 (page 11-19) in
> the 11th edition of your book. The B&C catalog lists the rating as '15VAC
> maximum'. How does this rating apply to a 14 volt system?
> My application would run 23 amps through the switch. Will the switch
> handle this load?
Yes, you'll probably get a satisfactory service life
using the S700-2-10 for this application. But I'm curious
as to where you got these current values. I'm also curious
as to why you have a combination of strobes and rotating
beacons on the same airplane.
________________________________ Message 5
Time: 06:17:15 AM PST US
Mark,
Jeff
> From: <Flagstone(at)cox.net>
> Inside Diameter
> Groove Diameter
> Outside Diameter
> Groove Width
> Overall Thickness
> 2 Hole Diameter
> 3 Rib thickness
> conduit.
> post?
________________________________ Message 6
Time: 07:06:31 AM PST US
> temperature change.
> Best regards,
> Rob Housman
> Irvine, CA
> Europa XS Tri-Gear
> A070
> Airframe complete
computing
because of
only the amount
hole bigger? The
hole smaller.
residual stresses
it.
John
John Dalman
Elburn, IL
RV-8 N247TD
http://forums.matronics.com/viewtopic.php?p=177406#177406
________________________________ Message 7
Time: 07:35:53 AM PST US
Subject: Re: Re: Grommets
Jeff:
Mark
Posted: Fri Apr 18, 2008 6:46 am Post subject: Grommets |
In this case, the grommets were not exposed to anything other than
temperature change. I took them out of the box, installed them in the
ribs and let them wait in the cold until things warmed up and I could
continue my work.
The rubber is soft enough that I think the holes would have to become
dramatically smaller to cut the grommets.
Since 15 or 20 of them were halved, I don't think it is just a
defective grommet. I will be inspecting all the rest when I get back
to the hangar.
Assuming I started cuts in the grooves during installation, I still
wouldn't expect to find them in half on the floor
Jeff
| Quote: | Jeff,
RV7A N527LR
n801bh(at)NetZero.com Guest
Posted: Fri Apr 18, 2008 1:54 pm Post subject: Grommets |
I will chime in and comment.... This is really hard to believe they split all by themselves. Are you sure someone didn't remove them and split them with a razor and them drop them on the floor as a joke/ prank etc...
Ben Haas
N801BH
www.haaspowerair.com
continue my work.
to the hangar.
Jeff
| Quote: | Jeff,
RV7A N527L========================; - The AeroElectric-List===============================================================================================
_____________________________________________________________
Save for the future with great IRA Funds. Click now!
Posted: Sat Apr 19, 2008 7:10 pm Post subject: Grommets |
Two of you both thought my grommet problem so absurd that it must be a prank.
I wish that were true, but my T hangar is locked.
They were exposed only to cold air, darkness, time and my installation.
When I get to the hangar next, i will be taking a close look at all of
them, to see if the ones remaining are partly torn, or if some of them
are perfectly intact.
I will also try to do some tests with some still in the box to see if
I can tear them like that.
Sure is weird though. We install grommets to protect the wires, so
they should be tougher than the insulation.
Jeff
| Quote: | Are you sure someone didn't cut them off, just to play a mind game with
you??
Roger
| Quote: | > Just a guess but exposure to solvents could breakdown SBR. I cannot
Ben Haas
Eric M. Jones
Posted: Sun Apr 20, 2008 4:59 am Post subject: Re: Grommets |
Holes and temperature had nothing to do with it. Extract from:
Neoprene is known for its resistance to oil, gasoline, sunlight, ozone and oxidation; however, there are other polymers that have better resistance to these same elements. Neoprene's most important advantage is its ability to combine these properties moderately into one all-purpose polymer.
Resistance to corrosive actions of chemicals is good. Neoprene exhibits resilience, tensile strength, tear resistance and dynamic properties; abrasion resistance and compression set properties.
COLOR Black
DURO 40,50,60,70,80
TENSILE900
ELONGATION300%
TEMP-20°F to 170°F
OIL RESIST Good
Nitrile's (Buna-N) resistance to the more aromatic distillates of petroleum is better than neoprene, and it exhibits excellent resistance to mineral and vegetable oils, but relatively poor resistance to the swelling action of oxygenated solvents such as acetone and the ketones. Resistance to heat aging is good.
Nitrile exhibits good resilience, low permanent set, good abrasion resistance and some ozone resistance. Tear resistance is inferior to natural rubber.
Nitrile accommodates applications where oils and heat are prevalent.
COLOR Black/ White
DURO 60
TENSILE300
ELONGATION900%
TEMP-20°F to 170°F
OIL RESIST. Good
SBR: Certain types of SBR offer improved wear resistance in tire treads while others provide better low temperature flexibility. SBR has similar resistance to solvents and chemicals as natural rubber and it can be successfully bonded to a wide range of materials.
When exposed to petroleum derivatives, the performance of this rubber is inferior to many other synthetics. Red SBR rubber is popular for use as a gasket in low pressure applications such as washers and gaskets for the heating and plumbing trades.
COLOR Red/Black
DURO 75
TENSILE400
ELONGATION150%
TEMP-29°F to 170°F
OIL RESIST. None [This should be a clue]
Summary. SBR should NEVER be used for grommets near petroleum vapors, oils or solvents.
General advice: It is always a surprise when modern materials fail. Companies spend a lot of money to prevent problems like this, and even materials "not recommended" for an application usually don't fail quickly. But beware inexpensive materials made for specific applications not-your-own. Surprises happen. Things break.
"In times of rapid change, experience could be your worst enemy."
---Jean Paul Getty
www.PerihelionDesign.com
113 Brentwood Drive
Southbridge, MA 01550
(508) 764-2072
emjones(at)charter.net |
klehman(at)albedo.net Guest
Posted: Sun Apr 20, 2008 5:50 am Post subject: Grommets |
Another product that may be suitable is the plastic snap bushings such
as Spruce 04-05730. I never liked putting soft grommets from any source
in very thin metal.
Ken
Jeff Page wrote:
prank.
I will also try to do some tests with some still in the box to see if I
Sure is weird though. We install grommets to protect the wires, so they
Jeff
> you??
> Roger
> Ben Haas
