Recommendations for front air vents
drfred(at)suddenlinkmail.
PostPosted: Mon Apr 14, 2008 1:11 pm    Post subject: Recommendations for front air vents Reply with quote
Any recommendations for the front air vents?
Vans wants $145 for the aluminum ones
Aircraft Spruce has several varieties in the $175 price range.
Is this is the part of the building where you say to the dealer?
....... hit me . Smile
Lew: good job on the wheel pants. Thanks for the reference, but I just
added the pics. Our late friend, Mark Ritter showed me how to do it
when I looked at his plane a couple of months ago. And I will be
"displeased" if you get flying before I do.
Fred Williams
40515.
rv10(at)sinkrate.com
PostPosted: Mon Apr 14, 2008 1:47 pm    Post subject: Recommendations for front air vents Reply with quote
Stein has some for $90-100 per copy.
I don't recall if I sent out this link before but there are some pictures of
Dave Saylor's RV-10 here:
http://www.sinkrate.com/rv10/aircrafters-fiberglass-class/
that show some pictures of his completed wheel pants with a similar setup.
-Ben
40579.
msausen
PostPosted: Mon Apr 14, 2008 1:54 pm    Post subject: Recommendations for front air vents Reply with quote
Our illustrious Stein has a popular vent:
http://www.steinair.com/eyeballvents.htm
Looks like he is out of stock on some though. Stein, any idea when you will have more?
Michael
Deems Davis
PostPosted: Mon Apr 14, 2008 1:56 pm    Post subject: Recommendations for front air vents Reply with quote
Check out Stein, He's got the best prices on Vents, and they are TOP
quality. http://steinair.com/eyeballvents.htm
Deems Davis # 406
'Its all done....Its just not put together'
http://deemsrv10.com/
Fred Williams, M.D. wrote:
<drfred(at)suddenlinkmail.com>
........ hit me . Smile
stein(at)steinair.com
PostPosted: Mon Apr 14, 2008 2:40 pm    Post subject: Recommendations for front air vents Reply with quote
We should have more of the smaller ones back in stock within a couple weeks.
Lockheed called and bought every last one we had on the shelf so the stock
situation has been hard to keep up with on those smaller ones! We're trying
to keep up, but when someone just buys all of them in one fell swoop it
takes us a bit to catch back up.
Stein
[quote]--
PostPosted: Mon Apr 14, 2008 3:02 pm    Post subject: Recommendations for front air vents Reply with quote
Deems, Michael and Ben.
Thanks.
Will give Stein a day to get over Sun -n Fun and call in am to see when
some will be available. He'll probably see this later today. Now I can
tell my wife I saved $100 today.
Fred Williams
toaster73(at)embarqmail.c
PostPosted: Mon Apr 14, 2008 5:36 pm    Post subject: Recommendations for front air vents Reply with quote
Fred,
I got 4 from a salvage yard not a scratch on them, nice Aluminum for less
than $100 after some negotiations. So there are other avenues.
-Chris
#40072
Tim Olson
PostPosted: Mon Apr 14, 2008 5:40 pm    Post subject: Recommendations for front air vents Reply with quote
Having done it both ways now, I'd say ABSOLUTELY go with
the aluminum ones...the plastic ones suck.
Anyone want a hot deal on plastic vents? Smile
Fred Williams
40515.
AirMike
PostPosted: Mon Apr 14, 2008 7:05 pm    Post subject: Recommendations for front air vents Reply with quote
I ordered the one from Spruce, but the $56 is too small for the RV10 vent.
I had to return it. They were good on the refund.
Tim is correct on the metal ones. I bit the bullet and bought Van's vents for $145 (ouch). They do have a nice mounting flange that married up to the vent perfectly. I am unimpressed by them at that price, but I tried the junks and Wentworth, but could not get any. Stein's look good.
It just about kills me to think that I saw a bunch of them at a crash site a few years ago and did not salvage them. They were in perfect condition. Good lesson.
See you OSH '18
Q/B - sold.
thane
PostPosted: Tue Apr 15, 2008 2:54 pm    Post subject: Recommendations for front air vents Reply with quote
Stein sells tem for just under $100. They are very nice and I found a great
way to install them with no hardware or Proseal.
Thane
Working on finish kit: I hate fiberglass!!
ron.mcgann(at)baesystems.
PostPosted: Tue Apr 15, 2008 3:18 pm    Post subject: Recommendations for front air vents Reply with quote
Thane - don't be coy. I am about to instal Steins vents and was
thinking of E6000 to attach them to the NACA ducts. What was your
method? Contact me off list if this is a secret <grin>.
Ron
187, almost there.
rene(at)felker.com
OK, so tell us the secret..........
Rene' Felker
RV-10 N423CF Flying
801-721-6080
timrvator(at)comcast.net
PostPosted: Wed Apr 16, 2008 2:39 am    Post subject: Recommendations for front air vents Reply with quote
The $18 plastic ones from Vans (approximate price) work fine if you add
a little RTV to seal the leak in the "closed" position. I believe the
process is discussed in 21 Years of the RVator. It's also discussed in
the RV-list archives. I used it in my -6A, works well. I'm doing the
same thing for my RV-10.
Tim Lewis -- HEF (Manassas, VA)
RV-6A N47TD -- 1000 hrs
RV-10 #40059 under construction
just added the pics. Our late friend, Mark Ritter showed me how to do
it when I looked at his plane a couple of months ago. And I will be
Fred Williams
40515.
Tim Olson
PostPosted: Wed Apr 16, 2008 3:51 am    Post subject: Recommendations for front air vents Reply with quote
Depends on what is "fine". They leak without sealant,
that's for sure, and they have no where near the flow
of the aluminum. I was lucky enough to get a pile of
time with the old, and then switch to the aluminum.
I'd never go back....they're actually worth the difference.
But, for those on a super tight budget, it's an easy
thing to use plastic for a while...one of the more
painless future upgrades.
thane
PostPosted: Thu Apr 17, 2008 1:54 pm    Post subject: Recommendations for front air vents Reply with quote
No secret, I just didn't know if anyone cared to hear. But glad to share.
Here goes; Go to lowes or H.D and B-line it for the plumbing department,
then look for the rubber fittings to attach PVC, in line, 1 1/2". Get a
coupling for 1 1/2" pipe, it will be about 4" long and have two hose clamps
on each end. You will need to cut the two ends off with a band saw, or your
weapon of choice. Cut just inside of the groove where the clamp sets. You
will now have two couplings for each vent.
Then you can use a dremal to cut the big flange off the NACA inlets, about
1/4 inch from the seam, or so you have 1 1/2" diameter left. Then with the
nut ring still on the eyeball vent insert it into the rubber coupling and
place the whole unit over the NACA vent, and tighten the hose clamp.
Sound complicated but take around 30 minutes.
Let me know if you have questions. I also have a pic of the end product,
looks real clean, is easy to remove, and eliminates the ugly white flange,
and requires no hardware or glue.
Thane
803-396-8865
pitts_pilot(at)bellsouth.
PostPosted: Thu Apr 17, 2008 3:13 pm    Post subject: Recommendations for front air vents Reply with quote
Thane States wrote:
snip
product, looks real clean, is easy to remove, and eliminates the ugly
white flange, and requires no hardware or glue.
So, where's the picture??? Holding out for cash offers??? Smile
Linn
Thane
803-396-8865
thane
PostPosted: Thu Apr 17, 2008 5:21 pm    Post subject: Recommendations for front air vents Reply with quote
Sorry the wife has camera. I will post some pics tomorrow.
Thane
thane
PostPosted: Fri Apr 18, 2008 5:42 pm    Post subject: Recommendations for front air vents Reply with quote
Here are a few pics of my eyeball vent install as promised. Hope these are
OK.
Thane
 Filesize:  112.7 KB
 Viewed:  692 Time(s)
 Filesize:  172.28 KB
 Viewed:  577 Time(s)
ricksked(at)embarqmail.co
PostPosted: Sun Apr 20, 2008 1:52 pm    Post subject: Recommendations for front air vents Reply with quote
Thane,
I am doing the same thing but what did you use to attach the vents to the inlet? I haven't installed them permanently yet but I was going to just use a 2" pipe clamp.
Rick Sked
40185
thane
PostPosted: Sun Apr 20, 2008 5:29 pm    Post subject: Recommendations for front air vents Reply with quote
Rick, the coupling I used had the hose clamps already on each end, so I just
used them. It holds very tight and you can barely see the clamp once it is
installed.
Good luck, I am very pleased with the final look and function.
Thane
