henrysfork1(at)msn.com Guest
Posted: Sat Apr 12, 2008 1:55 pm Post subject: Cutting a windshield |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> I have read mean posts about the cutting of Plexiglas and polycarbonate for windshields. I have cut two windshields, one from each of they materials for my Model II, both of which were cut with a good set of tin snips. I over cut, then trimmed and cleaned up the edges and corners with mill file. I have no crazing or cracking at the wing root or any other problems with this process. Its done quickly and easily.
Dee Young
Model II
N345DY
Lynn Matteson
Posted: Sat Apr 12, 2008 3:18 pm Post subject: Cutting a windshield |
The Kitfox windshield from LP Aeroplastics is about 1/8" thick, and I
wouldn't even try to go after that with snips. The thinner stuff
might handle snipping, but the thicker stuff...at least the
windshield that I have wouldn't tolerate it. Are you talking about
material that is 1/8" thick or the stuff that Skystar sold as
windshield material and is only .093" thick or thinner, with the name
Hyzod on the protective covering?
Lynn Matteson
flying w/487+ hrs/down for annual
On Apr 12, 2008, at 5:52 PM, Dee Young wrote:
| Quote: | I have read mean posts about the cutting of Plexiglas and
Dee Young
Model II
N345DY
http://www.matronics.com/Navigator?Kitfox-List_-
forums.matronics.com_-
contribution_-
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
Posted: Sat Apr 12, 2008 4:39 pm Post subject: Cutting a windshield |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> I cut the .060 polycarbonate for my second windshield using the first one as a pattern.
Dee Young
Posted: Sat Apr 12, 2008 4:51 pm Post subject: Cutting a windshield |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> I miss spoke it was the .093
Dee
7suds(at)Chartermi.net Guest
Posted: Sun Apr 13, 2008 7:51 am Post subject: Cutting a windshield |
All,
My experience is that the LP Aeroplastics will shatter if you try to cut
with snips at any thickness, the Lexan and Plexi I have cut with snips, you
still need to sand the edges because you will still get very slight crazing
on the edge from the snip cut.
Lloyd
Guy Buchanan
Posted: Sun Apr 13, 2008 8:25 pm Post subject: Cutting a windshield |
At 08:48 AM 4/13/2008, you wrote:
| Quote: | My experience is that the LP Aeroplastics will shatter if you try to cut
I know this is in the archives but I'll repeat quickly. I
used a diamond Dremel wheel to cut, then 60, then 220, then 400, then
TCP polish with a Dremel buffing wheel.
Guy Buchanan
San Diego, CA
Deceased K-IV 1200
A glider pilot too. |
