Fibreglass Tail Tip Trim
countzero
PostPosted: Sat Apr 12, 2008 10:57 am    Post subject: Fibreglass Tail Tip Trim Reply with quote
Hi,
I'm trimming the edges of the FTTs and I'm not sure how much I can take off. Drawing 6-X-1 shows the tip to tip width of the tail is 2.3m and the tail skeleton is 2.205m wide without the tips.
I only need to trim 5mm off each FFT to tidy the edges up but the tail measures 2.345m wide with the tips in place as it is. The tail would then be 2.335m wide, too wide.
To get the 2.3m width I would need to remove 22.5mm off each tip, that will not work. Any suggestions?
Many thanks
Rob
 Filesize:  414.79 KB
 Viewed:  726 Time(s)
bryanmmartin
PostPosted: Sat Apr 12, 2008 1:25 pm    Post subject: Fibreglass Tail Tip Trim Reply with quote
Go ahead and trim them for a good fit and don't worry if it's a
little bit wider than the plans show, it won't hurt anything. The
extra width will just give you slightly more pitch stability. The
early 601HD's didn't have the fiberglas tips, they were added to
improve pitch stability.
Hi,
Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus redrive.
do not archive.
Bryan Martin
do not archive.
countzero
PostPosted: Sun Apr 13, 2008 12:50 am    Post subject: Re: Fibreglass Tail Tip Trim Reply with quote
Thanks Byran, it's just that my garage door is only 2.320!
and don't worry if it's a little bit wider than the plans show
bryanmmartin
PostPosted: Sun Apr 13, 2008 7:37 am    Post subject: Fibreglass Tail Tip Trim Reply with quote
I had to wait until the final assembly phase at the airport to rivet
my fiberglas tips on. I built my plane in a 24 foot cargo trailer and
the rear door opening was too narrow to get the fuselage through with
the tips on. But then, I never had any intention of storing the plane
in the trailer after it was finished and flying.
If you are planning on storing the plane in your garage after it's
finished, you might consider attaching the tips with small screws so
that it can be removed. Or you can widen the door. Smile
Bryan Martin
N61BM, CH 601 XL,
do not archive.
Bryan Martin
do not archive.
