ernieth(at)gmail.com Guest
Posted: Wed Apr 09, 2008 5:52 pm Post subject: Vfe Va Vne AC 90-89A |
Hi
the UK report on the pa-181
had an interest technical explantion what Va
I am using my phone and can't get to it easly
The short answer is I don't think it is tested value
E
On 4/9/08, Sabrina <chicago2paris(at)msn.com> wrote:
For those of you who have flown off your 40 hours, what are your values for
Vfe, Va, Vne as listed in your POH?
Did anyone actually apply swift full control inputs at 1320 pounds at ever
increasing speeds approaching Va and record the G force values?
Would the FAA have required detailed G force values at various air speeds
and control inputs to prove Va for the prototype CAW and AMD S-LSAs?
http://forums.matronics.com/viewtopic.php?p=175836#175836
pchapman(at)ionsys.com Guest
Posted: Wed Apr 09, 2008 9:07 pm Post subject: Vfe Va Vne AC 90-89A |
At 00:02 10-04-08, you wrote:
I understand it is a calculated value. My question is, has anyone,
tested it. Since the rule of thumb is that a 4G aircraft's Va is
2X its stall speed, if the CAW stalls at 26, Va would be 52 knots if
it were 4G, since it is 6Gs, what is its calculated Va at 1320?
You'd only want to go as far as the limit load, which might be 4g
here. (I haven't been following the discussions closely.)
The speed vs G relationship is just based on lift squaring with
speed. So for 6g the stall speed would be up by root(6) = 2.45* the
one g stall speed.
| Quote: | One would expect "full from neutral" deflections to equal 4Gs at 2X
stall. My question is, has anyone done it?
I'm not really up on my flight testing theory, but as far as I recall
nobody tests for Va. Planes do get tested for Vne in flight. I don't
think testing a G-loading is all that common, although it may be
done, such as for aerobatic aircraft or by pilots who just want to
check their own homebuilt. That's usually left more for ground static
tests, checking for no permenant set at limit load, and no complete
failure at ultimate load.
For Va it would be awkward to test in flight. If everything isn't
perfect, one could overstress the aircraft (past limit load). In any
case one might get some nasty high G accelerated stalls going on when
one hits the stall break. But as you wrote, one could start at low
speeds and low loadings and work ones way up. Still, it sounds more
like something to do only on an aerobatic aircraft, and keeping the
tests below Va to avoid overstressing.
There need not be any particular relationship between elevator
deflection and the Va stall point. The elevator angle available may
be chosen for any number of reasons, including being able to raise
the nose on a forward C of G landing, and just selecting a convenient
number (eg, +/- 25 degrees). So who knows what the elevator angle
will be at a high speed high G stall.
I think Va is normally just something calculated on a graph, rather
than something flight tested. As long as one knows the limit load,
and the 1g stall speed, Va can be calculated. (Of course as one
learns, somewhat counterintuitively as a student pilot, Va goes down
when the plane is loaded more lightly than gross.)
What is done in flight testing is to check the stick force per g (at
some chosen speed or speeds, like Va). That'll give some idea how
sensitive the aircraft feels and whether someone rough on the
controls is likely to overstress the aircraft. An aerobatic aircraft
can get away with a lower stick force per g as more g is needed
before damaging things, and the pilot has to be able to access the
higher g regime without too much stick pressure.
Some of the old CAFE flight test reports in Sport Aviation in the
late 90s were good for all the stick force per g type of techy reporting.
(http://www.cafefoundation.org/v2/research_aprs.php) E.g., at Va
one RV-6A was getting to 2.5 g with 7 lbs force, compared to a C-152
needing 27 lbs.
That's the best I can do for a quick late-at-night answer.
Peter Chapman
Toronto, ON 601 HDS / 912 / C-GZDC
grant.corriveau(at)TELUS. Guest
Posted: Thu Apr 10, 2008 10:44 am Post subject: Vfe Va Vne AC 90-89A |
I wonder if any of these (expensive) test programs required for
certified aircraft are performed for amateur built? After all, our
aircraft do carry a big sticker (varies by country) that says to
effect: "This Is Not A Certified Aircraft"
The manufacturer's reputation and track record is mostly what we have
to go on when deciding which Kit we buy and build. Then of course
the actual quality of the build will vary, and folks will (often)
make their own non-certified, untested "improvements" ...
Worst of all, many pilots fly their Zodiacs as if the "Aerobatics
Prohibited" admonition did not exist -- ("but it looks so sporty, it
must be aerobatic!" not!).
BTW - Could someone please confirm or deny that this recent crash was
an XL version?
Thanks.
randy(at)rjhebertassoc.co Guest
bryanmmartin
Posted: Thu Apr 10, 2008 12:44 pm Post subject: Vfe Va Vne AC 90-89A |
That 26 knot stall speed was listed as IAS and with full flaps. I
suspect that the actual stall speed (CAS) is significantly higher than
that and Va is stated for the no flaps configuration. The Zenith web
site list the XL's stall speed as 44 knots CAS. The Czech built model
should be about the same.
The information I got from Zenith was Va = 110 MPH, Vfe = 80 MPH and Vne
= 180 Mph.
I have flight tested my airplane for Vne. I have also tested it to 4Gs
at gross weight. I did not test full control deflection at Va. For one
thing, just because you are flying below Va doesn't mean you can't break
the airplane by applying full control deflection. It just means that the
wing will stall before it can exceed the positive G flight load limit in
in a wings level attitude. I.e. you can apply full back stick without
tearing the wings off, but not necessarily full forward stick and not
necessarily full back stick with a large roll input.
Sabrina wrote:
I understand it is a calculated value. My question is, has anyone, tested it. Since the rule of thumb is that a 4G aircraft's Va is 2X its stall speed, if the CAW stalls at 26, Va would be 52 knots if it were 4G, since it is 6Gs, what is its calculated Va at 1320?
One would think someone would have flown the airplane at 5 knots above stall, used "full from neutral" elevator deflection and recorded the G forces. Then at 10 knots above stall, etc. upto at least 2X stall speed.
One would expect "full from neutral" deflections to equal 4Gs at 2X stall. My question is, has anyone done it?
I am not talking about rudder or aileron deflections, just "full elevator deflections from neutral." Flight 587 reminds us that flying below Va does not protect us from limit to limit vertical surface movement.
Bryan Martin
Zenith 601XL N61BM
Ram Subaru, Stratus redrive
_________________ --
Bryan Martin
do not archive. |
