ncol(at)xtra.co.nz Guest
Posted: Tue Apr 08, 2008 9:51 am Post subject: Engine stop tests. |
Hi
I would like to report on some tests we did this evening.
We wanted to know what would happen when the engine stops. In flight!
We have a Barratts IO540, standard compression, with the MT 3 blade
prop, dual mags.
The object of the exercise was to see just what happens when the fuel
runs out in one tank, and how easy it is to re-start.
First exercise was to practise some forced landings in case we really
couldn't restart it. So complete with clearance from our local
Airforce base, and with one of their squadron leaders in the right
hand seat, the tower fully briefed on what we were doing, off we set
to 5000ft.
There was a relatively strong wind of about 35 knots at 2000ft & 25
gusting 30 on the ground . So we came up a bit short (just a bit) on
the runway. I was reminded then that I need to practice forced
landings from all heights, not just pattern (or circuit) height.
Then it was back up to 5000ft.
Cool the engine a bit, then ( all in controlled airspace I hasten to
add), we cut mixture to full idle cut off. The engine just kept on
going at about 500 rpm in the glide at about 80 knots or so, so
eventually with full flap, and mushing down at about 55 knots, we
managed to finally get it to stop. It's certainly odd seeing the prop
stopped, and the ground so far below. Yes we do know that it is less
than ideal for the prop to drive the engine, but we wanted to do the
tests. There is no doubt that if the engine stops, the glide rate is
about 200 ft/m better with the prop in full course.
So it was full rich, full fine, and about 1/2 inch. Fuel pump on, a
flick of the starter and away it went. So no problems there at all.
The next test was a bit harder, because we wanted to check if we could
start the engine without the starter (just in case of a flat battery /
broken starter etc.) I've had two occasions where the engine started,
but the starter failed in the process. So I was unable to restart.
With the prop stopped again, we went flaps up, full rich,full fine,
1/2 inch on the throttle and entered a dive.
The prop looked as if someone was trying to hand swing it (though at
4500ft and rapidly decreasing, that was unlikely!)
After a few seconds it finally passed TDC, then again, and eventually
it did restart after having lost about 2600ft, and at a speed of about
130-150 knots.
Very quickly it builds up revs, so pulling back on stick & throttle we
were quickly under control. But it is not something you will get away
with under 3000ft.
Our final test was to deliberately run out of fuel. With plenty in the
other tank!
So we simply cruised around for a further 15 mins or so, until finally
the engine cooughed & spluttered. There was plenty of time to switch
pump on and change tanks and away she went. So no dramas at all.
Having completed our tests it was back up to 7000ft t play on the
overcast for a short while.
So in conclusion, there is nothing to be feared about running a tank
dry. So long as the starter works, or you have sufficient height.
However, if you have totally run out of fuel, it will happily continue
to turn. So bearing in mind you have little or no oil pressure, then
there is very little time to coursen up the prop to minimise drag. And
if you are thinking of saving the engine on your forced landing, then
you need to drop the flap and stall for a while to get the engine to
stop.
So what a fun evening. Just wish I had taken the camera with me.
If anyone else has done such tests, it would be great to hear from
you. Or if anyone has any other thoughts on such matters.
Neil
ps- Take off with Sarah PIC at Warbirds over Wanaka a couple of weeks
back. Osh may be bigger, but Wanaka surely has the best setting
anywhere for an airshow.
33.2 KB |
485 Time(s) |
AV8ORJWC
Posted: Tue Apr 08, 2008 10:23 am Post subject: Engine stop tests. |
Fabulous detail and invaluable research. We need more of this stuff and
less accident reporting. By the way, did you go with the stock James
engine cowl?
The Warbirds acts as breathtaking as the setting at Wanaka. See you for
OSH '08.
msausen
Joined: 25 Oct 2007 Posts: 559 Location: Appleton, WI USA
Posted: Tue Apr 08, 2008 10:43 am Post subject: Engine stop tests. |
Neil,
Excellent right up. Thanks for sharing!
Michael
Posted: Tue Apr 08, 2008 11:25 am Post subject: Engine stop tests. |
James cowl & plenum. Had to add a slightly bigger oil cooler.
Neil
On 9/04/2008, at 6:20 AM, John W. Cox wrote:
<johnwcox(at)pacificnw.com>
and
engine cowl?
for
OSH '08.
Ray.R.Doerr(at)sprint.com Guest
Posted: Tue Apr 08, 2008 11:43 am Post subject: Engine stop tests. |
During these tests, what did you find the best glide to be with and without the prop being stopped.
Thank You
Ray Doerr
40250 (N519RV)
Posted: Tue Apr 08, 2008 12:11 pm Post subject: Engine stop tests. |
The best glide with the engine at tickover (minimum throttle) was 75
knots. We must have done over an hour of tests to establish this.
Last night we were gliding at about 80 knots. Full fine was about 1000
ft/m, full corse was about 200 ft/m better. Sorry, but we didn't
attempt to establish best glide with engine stopped as the focus was
on re-starting.
Neil
Thank You
Ray Doerr
40250 (N519RV)
Tim Olson
Posted: Tue Apr 08, 2008 12:20 pm Post subject: Engine stop tests. |
Awesome job Neil! I did shut off fuel on mine and let the prop
windmill, but as I lack the balls that you have, I didn't
stop the prop. For you though, the man who's going to fly to
OSH from NZ....you've definitely got the cahones to tackle
such tests.
With a windmilling prop, you can't really hardly even tell that
the engine has stopped, and a restart is dirt simple.
Glad you're having such a blast!
Neil & Sarah Colliver wrote:
| Quote: | Hi
We wanted to know what would happen when the engine stops. In flight! We
have a Barratts IO540, standard compression, with the MT 3 blade prop,
dual mags.
couldn't restart it. So complete with clearance from our local Airforce
base, and with one of their squadron leaders in the right hand seat, the
tower fully briefed on what we were doing, off we set to 5000ft.
gusting 30 on the ground . So we came up a bit short (just a bit) on the
runway. I was reminded then that I need to practice forced landings from
add), we cut mixture to full idle cut off. The engine just kept on going
at about 500 rpm in the glide at about 80 knots or so, so eventually
with full flap, and mushing down at about 55 knots, we managed to
finally get it to stop. It's certainly odd seeing the prop stopped, and
the ground so far below. Yes we do know that it is less than ideal for
the prop to drive the engine, but we wanted to do the tests. There is no
doubt that if the engine stops, the glide rate is about 200 ft/m better
With the prop stopped again, we went flaps up, full rich,full fine, 1/2
After a few seconds it finally passed TDC, then again, and eventually it
130-150 knots.
with under 3000ft.
other tank!
you need to drop the flap and stall for a while to get the engine to stop.
If anyone else has done such tests, it would be great to hear from you.
Neil
back. Osh may be bigger, but Wanaka surely has the best setting anywhere
for an airshow.
Posted: Tue Apr 08, 2008 12:47 pm Post subject: Engine stop tests. |
You're kidding! Neil hasn't got the balls to do it . He cheated and
took the test pilot with him who has got the balls to do it!! I
certainly wasn't going to do it with him. I haven't got any balls full
stop!
Sarah
definitely do not archive
On 9/04/2008, at 8:17 AM, Tim Olson wrote:
such tests.
> Hi
> flight! We have a Barratts IO540, standard compression, with the MT
> 3 blade prop, dual mags.
> fuel runs out in one tank, and how easy it is to re-start.
> really couldn't restart it. So complete with clearance from our
> local Airforce base, and with one of their squadron leaders in the
> right hand seat, the tower fully briefed on what we were doing, off
> we set to 5000ft.
> on the runway. I was reminded then that I need to practice forced
> to add), we cut mixture to full idle cut off. The engine just kept
> on going at about 500 rpm in the glide at about 80 knots or so, so
> prop stopped, and the ground so far below. Yes we do know that it
> is less than ideal for the prop to drive the engine, but we wanted
> to do the tests. There is no doubt that if the engine stops, the
> glide rate is about 200 ft/m better with the prop in full course.
> could start the engine without the starter (just in case of a flat
> battery / broken starter etc.) I've had two occasions where the
> engine started, but the starter failed in the process. So I was
> unable to restart.
> at 4500ft and rapidly decreasing, that was unlikely!)
> eventually it did restart after having lost about 2600ft, and at a
> speed of about 130-150 knots.
> we were quickly under control. But it is not something you will get
> away with under 3000ft.
> the other tank!
> finally the engine cooughed & spluttered. There was plenty of time
> to switch pump on and change tanks and away she went. So no dramas
> at all.
> tank dry. So long as the starter works, or you have sufficient
> height.
> continue to turn. So bearing in mind you have little or no oil
> pressure, then there is very little time to coursen up the prop to
> minimise drag. And if you are thinking of saving the engine on your
> forced landing, then you need to drop the flap and stall for a
> Neil
> weeks back. Osh may be bigger, but Wanaka surely has the best
> setting anywhere for an airshow.
n212pj(at)gmail.com Guest
Posted: Tue Apr 08, 2008 12:57 pm Post subject: Engine stop tests. |
Just gotta love it....!
Tim Olson
Posted: Tue Apr 08, 2008 1:10 pm Post subject: Engine stop tests. |
Ahhhhhhhh yes, and if there's anyone who would know Neil, it
would be his wife. Glad you're keeping him honest there
Sarah!
You're kidding! Neil hasn't got the balls to do it . He cheated and took
the test pilot with him who has got the balls to do it!! I certainly
wasn't going to do it with him. I haven't got any balls full stop!
Sarah
> such tests.
> Tim Olson - RV-10 N104CD - Flying
> do not archive
>> Hi
>> prop, dual mags.
>> to 5000ft.
>> unable to restart.
>> the other tank!
>> finally the engine cooughed & spluttered. There was plenty of time to
>> switch pump on and change tanks and away she went. So no dramas at all.
>> forced landing, then you need to drop the flap and stall for a while
>> Neil
coop85(at)cableone.net Guest
Posted: Tue Apr 08, 2008 3:47 pm Post subject: Engine stop tests. |
Neil,
Fantastic write up, thanks for all the very valuable information. I had
planned to do similar tests down the road but your experience builds a lot
of confidence in the mean time.
Just to add to your statement that running a tank dry isn't a dramatic
event, in the Skybolt (same engine) I was told the best (actually only) way
to know the aux tank was dry was to hear the engine start to fade from fuel
starvation. I was never impressed with that idea, but there's no fuel gauge
for that tank. Worked great every time.
Marcus
Lew Gallagher
Posted: Tue Apr 08, 2008 5:15 pm Post subject: Re: Engine stop tests. |
Hey Neil, et al
A quick question from a newbie. If the prop/crank is turning, why no oil pressure?
I don't doubt it, I just don't understand it. I have no experience with aircraft engines, just automotive that use mechanical driven oil pumps taken off distributor gear, etc. which don't care if the pistons, wheels, starter, etc. is powering it.
I know I can find complete books/manuals, and eventually I will, but it's easier and quicker to ask here.
Thanks, - Lew
_________________ non-pilot
crazy about building
NOW OFICIALLY BUILDER #40549
Fly off completed ! |
billderou(at)yahoo.com Guest
Posted: Wed Apr 09, 2008 8:12 am Post subject: Engine stop tests. |
Something that I was playing with (experimenting is too strong a word) is when the engine dies (in my case idling) and is still turning - if you pull the prop out the RV10 takes a leap forward. Does the glide range increase with the prop all the way out? Is this in fact the standard emergency procedure with a constant speed prop?
It seems that the engine turning would power the oil pump and could turn the blades to full coarse decreasing the drag.
Any comments? My previous constant speed prop experience was just sufficient to get my high performance signoff.
Bill DeRouchey
N939SB, flying
"John W. Cox" <johnwcox(at)pacificnw.com> wrote:
[quote]--> RV10-List message posted by: "John W. Cox"
engine cowl?
OSH '08.
Posted: Wed Apr 09, 2008 10:24 am Post subject: Engine stop tests. |
The glide definitely got better at full coarse, but when it stopped,
there was obviously no oil pressure, and so we were unable to change
pitch. I have no idea if it's standard proceedure, but it was what I
was taught to do.
Neil
ZK-RVT
Not flying - sitting at a computer instead. However, both Sarah & I
did our first night flying last night. It was great. Although as
virtually no one in NZ is RV 10 rated, we had to revert to C152's -
aarrgghh. Although it was a bit like meeting a crusty old family
friend. There is no doubt that we are spoiled with Vans. I really did
miss the EFIS & GPS though.
On 10/04/2008, at 4:09 AM, Bill DeRouchey wrote:
| Quote: | Something that I was playing with (experimenting is too strong a
Bill DeRouchey
N939SB, flying
Posted: Wed Apr 09, 2008 7:33 pm Post subject: Engine stop tests. |
Bill,
This info is based on my understanding of the props, if I’m off base someone please chime in. Doesn’t that make you feel confident about what I’m about to write
The non-reversing constant speed props (like on the -10) are designed to go flat pitch in the event of a loss of oil pressure. The main concern is if you have to execute a go-around or steep climb you want the high RPM available for performance.
I think what you are experiencing is simply increased thrust by going more coarse on the pitch while there’s still oil pressure. Once the prop stops I seriously doubt there is a significant difference in drag between flat and coarse pitch. So first, I don’t think you can control the pitch as the engine quits and second I don’t think it would make a difference.
Marcus
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bill DeRouchey
Sent: Wednesday, April 09, 2008 11:10 AM
Subject: RE: Engine stop tests.
Bill DeRouchey
N939SB, flying
engine cowl?
OSH '08.
AV8ORJWC
Posted: Wed Apr 09, 2008 8:15 pm Post subject: Engine stop tests. |
Two ways to flatten a coarse pitch to fine pitch in the event of engine failure with a Constant Speed Prop Assembly . Adequate Oil Pressure or Counter weights. With the choice of no weights, the reaction time on the prop control is a important skill set. Low pressure – Lots of Luck. Neil gave a great example of the loss of altitude and significant increase in airframe speed necessary to overcome loss of adequate oil pressure.
Loose your oil….. Think fast, move faster. Fly the aircraft safely to a walk away landing. – Bob Hoover.
Get some practice with a dead engine in course pitch and again in fine pitch. It will drive home the importance in no short order. Practice, practice, practice with lots of altitude and options.
John C
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Marcus Cooper
Sent: Wednesday, April 09, 2008 8:31 PM
Bill,
Marcus
Bill DeRouchey
N939SB, flying
engine cowl?
OSH '08.
ricksked(at)embarqmail.co Guest
Posted: Thu Apr 10, 2008 2:07 pm Post subject: Engine stop tests. |
I may be mistaken but I beleive that you need 1700+ RPM to get the prop to change pitch, in any direction, regardless of the oil pressure. I understood the govenor needed the 1700 rpm to function and allow the oil pressure to vary the pitch.
Rick Sked
40185
