Sam Brunson
Posted: Mon Apr 07, 2008 5:09 pm Post subject: wiring of 477 rotax |
I need a little help!!! I have a used rotax 447 with single carb. There are three wire looms coming out of case. #1 has a yellow wire, and a yellow wire with black stripe on it. #2 has a green wire, and a green wire with black stripe on it. #3 has two black wires, and one brown wire. I need to know where these wires should be hooked up. There is only a pull starter, and no lights. I need to know how to wire it to run and how to wire in a tach. Also I think is puts out some voltage when running that may be used somewhere. Please Help????
Dale Ensing
Joined: 11 Jan 2006 Posts: 571 Location: Aero Plantation Weddington NC
Posted: Mon Apr 07, 2008 6:15 pm Post subject: wiring of 477 rotax |
Sam, I have the info but it is in my hangar. If no one else gets the info to
you by tomorrow I'll send it to you.
Dale Ensing
_________________ Dale Ensing
RV-6A
Aero Plantation
Weddington NC |
nuckolls.bob(at)cox.net Guest
Posted: Mon Apr 07, 2008 8:11 pm Post subject: wiring of 477 rotax |
At 06:09 PM 4/7/2008 -0700, you wrote:
You can find a number of Rotax data packages at:
http://www.aeroelectric.com/Mfgr_Data/Rotax/
In particular, the information you want is in
the 503 series installation manual:
http://www.aeroelectric.com/Mfgr_Data/Rotax/Rotax_503_installation_manual.pdf
If you're wanting only the electrical system, download:
http://www.aeroelectric.com/Mfgr_Data/Rotax/Rotax_503_Electrical.pdf
( -Thomas Paine 1776- )
