AV8ORJWC
Posted: Mon Apr 07, 2008 8:13 am Post subject: The King has no Clothes |
Okay, no one is publically discussing the comprehensive and excellent
pictures on the door departure from N416EC. My count is over 100
followers of this documented build technique.
Would some Articulate and Tactful builder please expand and clarify the
correct installation of door pins as directed in writing by VANS.
Taper IN (towards the POB) or Taper OUT (towards the vast space
outside). Then secondly, the subject of adequate pin engagement in the
Jam (what is adequate?). Thirdly how to keep the pin engaged during
flight (so buffeting cannot cause the rack to move without human
assistance). And Fourth, the reasonable consideration of a Secondary
Latching mechanism to prevent catastrophic door loss.
I know, I know my wife tells me I am already in the Dog House for even
mentioning the existence of an AFS4500 before it's time. Have a great
and informative week. I suspect those of us that do not get to go to
SNF will just keep reading the plans for answers. Tomorrow I will hover
over the AFS website.
John Cox
#600
Tim Olson
Posted: Mon Apr 07, 2008 9:01 am Post subject: The King has no Clothes |
It's happened a few times now so it's not surprising to see...just
that in this case the door damaged the tail, and there was much
more to clean up. So yeah, it's a problem that can have more
than just "I need to build a new door" repercussions. But, it's
still just the same ol' problem.
As far as the taper IN or taper OUT, I'm sure that their
reasoning is that a taper on the outside will tend to
suck the door in to alignment as the pin goes into
the door post. From a ping engagement length stanpoint,
this gives perhaps a little less pin length to hold the door
all the way in, but the pin should have a lot of
travel to it. It may ideally be that you don't want to
make that taper quite as long.
The pin should engage plenty, so that there's quite a
bit of pin on the back side of that metal door post.
Lest people think that this is a problem with the nylon
blocks, it's not. Those shouldn't be part of what holds
the door shut...they're just there as a guide. The
pin is held by the metal door frame, so not even
the fiberglass should matter much in keeping the door
latched. This is NOT to say that you wouldn't be
better off with the rivethead door latch pins. I don't
have them, but I see that there are some good benefits
to having them. Anything you can do to make it better
is good.
Now, on a pin adequacy as built per-plans, I really
feel that if someone has problems of this sort, and they
built the latches with the proper pin length and engagement,
then the fault is squarely on the pilot. This sort of
accident, with a properly built door/latch, that is
properly secured, just would not happen. Someone has
to screw up somewhere, to have an incident. This is
one reason why door latches without some form of positive
latching mechanism shouldn't be considered at all. The
standard van's inside handles, although ugly, are actually
very functional and provide a great positive latch.
I actually have to make sure to instruct the passenger
how to release pressure by pushing the handle down a bit
so they can squeeze the thumb button. It is very
solid, and just won't move a bit in flight. No,
vibration won't cause it to move, and there is no
way vibration and airframe flexing will release those pins.
It has to have a screwup on the pilots part, or an
improperly cut pin length, or a broken pin, or something
of that nature.
Should a secondary latching mechanism be used? Perhaps.
Again, if you can do something to improve it, just like
the rivethead pins, then it might not be a bad idea.
But, you're going to need to do something that will
latch on the forward are of the door bottom...so that
the front of the door can't come out and catch the
200mph breeze. Straps just won't cut it. A solid
mechanical latch would, perhaps. Is it needed? Well,
it might be a good idea, but again, if you have all the
pins latched right and built it well, you shouldn't have
a big problem the way it is per-plans either. If
someone comes up with a great kit of parts to do such
a nice latch, with drawings on how to install them, and
especially if you can do it as a retrofit on a flying
plane, then I think they could be successful selling
them.
I took 4 flights this weekend and gave rides to a few
various people. On every flight, I personally was
the one to latch the door(s)...both of them. I was
also the one to inspect the pin engagement. You can
even put your fingers on the pin tips on the back pins.
Considering that the pins are latched, and in place
properly, and built properly, I don't live in fear that
my doors are going to fly off. I'm awaiting someone
else putting the rivethead system on AFTER having
completed their doors, and if it goes well for them
I'm considering adding them to mine. The one worry I
have is that I don't particularly like only having the
tips of the pins be nice and solid on those. It would
be nice to have 6 or more inches of tough pin, bonded
in permanently with threads and loctite, so you never
have to worry about the pin tips letting loose.
Still, it seems like it's a great solution that adds
some security.
John Cox
#600
rene(at)felker.com Guest
Posted: Mon Apr 07, 2008 9:31 am Post subject: The King has no Clothes |
I added the pins after I had completed my door. Worked fine. I rechecked
them this weekend after hearing about the mid air door departure and the
adjustment looked fine. Per design the pins do not go all the way into the
frame, they only go to the edge so that when they are extended they do not
hit the side of the air frame only the metal block. In normal opening and
closing I have not had the back pin go outside the guide, but I do have to
"help" the passenger door sometimes to get rear pin the hole, otherwise it
will just hit the edge of the block.
Rene' Felker
RV-10 N423CF Flying
801-721-6080
Posted: Mon Apr 07, 2008 10:37 am Post subject: The King has no Clothes |
Important question not adressed in the building instructions. When placing the latch mechanism inside the latch pocket, is it necessary to cut access holes for the geared arms that interface with the rod pin and the gear so that not only is there a cut in the pocket for the pin, but also the back half of the gear arm. Basically, when the door is open does the handle go up to the 90 degree position or does it go all the way to the 180 degree position.
If the pin was just emerging from the door side while the handle was in the 180 degree position(Facing aft), just think how far the pin will travel when the handle is placed in the closed position. The manual does not state the number of cuts in the latch pockets??????I haven't fitted the entire mechanism yet, but real close so I am not certain of how it is supossed to be..
JG
Quote: | Date: Mon, 7 Apr 2008 11:56:21 -0500
Subject: Re: The King has no Clothes
--> RV10-List message posted by: Tim Olson <Tim(at)myrv10.com>
is good.
of that nature.
them.
some security.
John W. Cox wrote:
> --> RV10-List message posted by: "John W. Cox" <johnwcox(at)pacificnw.com>
seipel(at)seznam.cz Guest
Posted: Mon Apr 07, 2008 3:02 pm Post subject: The King has no Clothes |
I installed mine after the fact, and was able to do it just fine. I
took a 7/16" drill and went all the way through the Rivethead blocks, as
well as the door frame, so my pins go all the way through and can be
felt out the back side.
PJ Seipel
RV-10 #40032
Rene' Felker
RV-10 N423CF Flying
801-721-6080
Tim Olson
Posted: Mon Apr 07, 2008 7:39 pm Post subject: The King has no Clothes |
One thing I'm not quite sure I understand about the initial posting
origination and that website. Not sure that it matters but...
From information that is pretty reliable that I have been told,
the person who posted the thread and page about that door separation
on 416EC isn't actually the person who was flying the plane at the
time, although that information isn't being presented. The other
perhaps stranger bit of left out information is that the 4G landing
that was described actually happened on a landing prior to the
door separation, and presumably that caused some of the cracking
of the airframe and popped rivets under the wing and such. Also,
the gear leg fairings and wheel fairings were crunched pretty good.
So considering there was so much other damage that would not be
attributable to the door itself, it's a bit strange that it isn't
being offered up that the other damage happened prior.
Oh well, just curious, because the source I had (yes, I've known
about that incident for a while now) is pretty reliable.
Rene' Felker
RV-10 N423CF Flying
801-721-6080
daveleikam(at)wi.rr.com Guest
Posted: Mon Apr 07, 2008 8:27 pm Post subject: The King has no Clothes |
Tim,
Are you suggesting that the hard landing damage may have caused the later
door failure?
Dave Leikam
dlm46007(at)cox.net Guest
Posted: Mon Apr 07, 2008 8:31 pm Post subject: The King has no Clothes |
That does make a little more sense. Possible structural damage prior to the
loss of the door. I wondered how the left dor block got so beat up.
Tim Olson
Posted: Tue Apr 08, 2008 3:13 am Post subject: The King has no Clothes |
I'm not saying I know how the plane was damaged, but what I heard
from a reliable source that was a firsthand source, was that the
plane was landed hard with that 4G landing, prior to the door
departure flight. If and how those events are tied together, is
all speculation. But, things like the cracking in front of
the windshield, and popped rivets under the wing, and cracked
wheel fairings and leg fairings would seem to indicate at least
something significant happened to that plane only a couple of
flight hours before the door came off. Not sure how the events
may or may not relate, but it would be nice if the story actually
happened that way that it was presented that way, right?
Dave Leikam wrote:
Tim,
later door failure?
Dave Leikam
Posted: Tue Apr 08, 2008 7:32 am Post subject: The King has no Clothes |
it would be even more nice if they repaired an obviously damaged plane
before flying it.. Looks like a "red X" in my maintanence book.
Pascal
AirMike
Posted: Tue Apr 08, 2008 8:58 pm Post subject: The King has no Clothes |
I cannot imagine why anyone flying an RV10 does not install the very excellent Rivethead door pins. They are tedious to install and adjust, but they are really sweet and center the closure on the door giving a positive feel when closing your door plus the whole install feels very strong
_________________ See you OSH '18
Q/B - sold. |
VHMUM(at)bigpond.com Guest
Posted: Tue Apr 08, 2008 9:19 pm Post subject: The King has no Clothes |
Maybe because you pay and they may or may not turn up. Sorry to be negative
but if the hat fits.
regards Chris
John Ackerman
Joined: 19 Jun 2006 Posts: 130 Location: Prescott, AZ
Posted: Tue Apr 08, 2008 10:32 pm Post subject: The King has no Clothes |
Here's another vote for the Rivethead latch pin setup. It's not exceptionally hard to install. I made a thick linen/phenolic [Micarta] template and used it as a drill guide. The doors close easily and are _very_ solid once closed.Yes, it's hard to get in contact with Dave, but my deliveries of several of his items were timely. I don't know of anyone who paid and did not get what he paid for on any of his items.
I have had no problem with simply sending payment for what I want, and the quality is a delight.
No relationship, just a satisfied customer.
John Ackerman 40458
On Apr 8, 2008, at 10:16 PM, Chris and Susie McGough wrote:[quote] [quote][b]
capsteve
Joined: 09 Jan 2006 Posts: 111 Location: NIAGARA FALLS NY
Posted: Tue Apr 08, 2008 11:58 pm Post subject: The King has no Clothes |
When I went to install a set in my rv10, I modified them to be much easier
to install. After seeing my mods coupled with the shipping delays I was
asked to reproduce a similar product by a few builders. I think they are a
very good anchor for the door rods to latch into, and should add a margin of
strength to the latch mech. I do offer them on my website (available
immediately sorry for the commercial announcement, I just want all to
know there are options...
Steve dinieri
Iflyrv10.com
[quote] --
Description: |
Filesize: |
142.02 KB |
Viewed: |
667 Time(s) |
roadmaps
Posted: Wed Apr 09, 2008 4:16 am Post subject: The King has no Clothes |
Steve,
How much for a set?
John Testement
jwt(at)roadmapscoaching.com
40321
Richmond, VA
Painting
capsteve
Posted: Wed Apr 09, 2008 7:58 am Post subject: The King has no Clothes |
John,
99 gets you parts for both doors, aluminum sockets, stainless pins
with magnets, 10-32 stainless allen-screws and platenuts. Includes priority
shipping (3 day) usps.
Thanks steve
Iflyrv10.com
scottmschmidt(at)yahoo.co Guest
Posted: Wed Apr 09, 2008 1:59 pm Post subject: The King has no Clothes |
I have ordered the Rivethead door pins and I'm looking forward to installing them.
Is anyone concerned about cutting the door rod and having a weak point where it threads in?
Does anyone have any concerns about the system being less robust than the standard rods?
Scott Schmidt
scottmschmidt(at)yahoo.com
Tim Olson
Posted: Wed Apr 09, 2008 2:23 pm Post subject: The King has no Clothes |
That was my concern as well. I really would like to do it but
it would be nice to get the pins in hand so you can see exactly
where the threaded connection is. I'd really prefer to have 4 or
6 inches of pin before the threaded area, because I don't want
to tap my pins, and then have that junction crack, the pin to
fall out of the main rod, and then have the door come off.
With enough pin both inside the door and inside the frame though
that is one solid piece, I'd have no worry.
Scott Schmidt wrote:
[quote] I have ordered the Rivethead door pins and I'm looking forward to
installing them.
the standard rods?
Scott Schmidt
Posted: Wed Apr 09, 2008 2:39 pm Post subject: The King has no Clothes |
My general comment would be no, I do not have any concerns. The end of the rod was already threaded per plans and all I did was fill them. ( Not exactly since I cut and threaded the rods again to shorten them.) But, they are not real tight. After 25 flight hours and the web traffic from last week, I inspected them and did not see any signs of wear. I rechecked their alignment and put some locktite on the threads. I installed mine per the video and thus they do not extend all the way into the cabin frame, only into the block itself. I am re-thinking that………..
Also, when you install the blocks there is very little room between the AL blocks and the nylon blocks in the door. I had to cut down the blocks on the door just to get the door to close. I think this closer tolerance helps to reduce the stress on the rod itself.
Rene' Felker
RV-10 N423CF Flying
801-721-6080
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Scott Schmidt
Sent: Wednesday, April 09, 2008 3:56 PM
Subject: Re: Re: The King has no Clothes
Scott Schmidt
----- Original Message ----
Sent: Tuesday, April 8, 2008 10:58:54 PM
Subject: Re: The King has no Clothes Quote: | http://www.matronics.com/Navigator?RV10-List | 0123456789
Posted: Wed Apr 09, 2008 2:40 pm Post subject: The King has no Clothes |
I am concerned about it. Not sure how to fix it though.
PJ Seipel
RV-10 #40032
installing them.
the standard rods?
Scott Schmidt
