lcottrell
Posted: Thu Apr 03, 2008 7:30 pm Post subject: Die grinder? |
Hi,
I am in the process of installing new steel gear legs, and I am running into problems getting the legs far enough into the sockets. Does anyone have a source for a die grinder that is long enough to get up inside the socket far enough to clean the burrs out? I'm out of ideas and local sources. I am only able to get them about 8 1/2 inches now.
Larry C
DAquaNut(at)aol.com Guest
Posted: Thu Apr 03, 2008 7:46 pm Post subject: Die grinder? |
In a message dated 4/3/2008 9:30:55 P.M. Central Standard Time, lcottrell(at)fmtcblue.com writes:
| Quote: | Hi,
Larry C
Larry,
You might be able to use an automotive brake or wheel cylinder hone . The kind which has three cutting stones on it and goes into a drill gun. It could be this might reach a little farther up the gear leg socket. Just a thought.
Ed ( FF #62 )
Planning your summer road trip? Check out AOL Travel Guides.
ElleryWeld(at)aol.com Guest
Posted: Thu Apr 03, 2008 8:17 pm Post subject: Die grinder? |
A tapered Reamer the size of your gear leg would work best for something like that but you would have to use an extension on it for that deep of job Check with your local machine shop buddies they might have one if so, it will look like you should spin it left hand direction but don't or you will have bigger problems it is made that way for a good reason so you don't get it stuck inside something like that it will clean out any burrs inside there the easiest way I can think of
Ellery in Maine
In a message dated 4/3/2008 10:47:20 P.M. Eastern Standard Time, DAquaNut(at)aol.com writes:
| Quote: | In a message dated 4/3/2008 9:30:55 P.M. Central Standard Time, lcottrell(at)fmtcblue.com writes:
| Quote: | Hi,
Larry C
Larry,
Ed ( FF #62 )
="http://www.matronics.com/Navigator?Kolb-List">http://www.matronics.com/Navigator?Kolb-List
.matronics.com/">http://forums.matronics.com
://www.matronics.com/contribution">http://www.matronics.com/contribution
Posted: Thu Apr 03, 2008 8:44 pm Post subject: Die grinder? |
A handy thing to have around a shop is a roll of plumber's sandcloth. Comes in two grits.Put some on a wood dowel and smooth the bore.
BB
On 4, Apr 2008, at 12:14 AM, ElleryWeld(at)aol.com (ElleryWeld(at)aol.com) wrote:
[quote] A tapered Reamer the size of your gear leg would work best for something like that but you would have to use an extension on it for that deep of job Check with your local machine shop buddies they might have one if so, it will look like you should spin it left hand direction but don't or you will have bigger problems it is made that way for a good reason so you don't get it stuck inside something like that it will clean out any burrs inside there the easiest way I can think of
Ellery in Maine
In a message dated 4/3/2008 10:47:20 P.M. Eastern Standard Time, DAquaNut(at)aol.com (DAquaNut(at)aol.com) writes:
| Quote: | In a message dated 4/3/2008 9:30:55 P.M. Central Standard Time, lcottrell(at)fmtcblue.com (lcottrell(at)fmtcblue.com) writes:
| Quote: | Hi,
Larry C
Larry,
Ed ( FF #62 )
| [b]
biglar
Posted: Fri Apr 04, 2008 3:13 am Post subject: Die grinder? |
The wheel cylinder hone is what I used. Worked fine. Lar.
DAquaNut(at)aol.com (DAquaNut(at)aol.com) wrote: [quote] In a message dated 4/3/2008 9:30:55 P.M. Central Standard Time, lcottrell(at)fmtcblue.com (lcottrell(at)fmtcblue.com) writes:
| Quote: | Hi,
Larry C
Larry,
Ed ( FF #62 )
Larry Bourne
Santa Fe, NM
www.gogittum.com
www.gogittum.com/blog[b]
_________________ Larry Bourne
Palm Springs, CA
Building Kolb Mk IIIC
"Vamoose" |
lcottrell
Posted: Fri Apr 04, 2008 5:25 am Post subject: Die grinder? |
I am going to make a trip into town and will see if I can find anything that will work. I will check on the suggestions and see what I can find.
Larry C
Rex Rodebush
Joined: 10 Jan 2006 Posts: 209 Location: Branson West area, Missouri
Posted: Fri Apr 04, 2008 6:09 am Post subject: Re: Die grinder? |
I used a stone with extensions and a flapper wheel. See picture.
I bought the extensions through the mail from McMaster-Carr.
Rex Rodebush
46.81 KB |
599 Time(s) |
lcottrell
Posted: Fri Apr 04, 2008 8:23 pm Post subject: Die grinder? |
Rex Rodebush
Gang,
I found a "Brake Cylinder" hone and a extension that all should do a
great job. Thanks guys for your suggestions and help. I couldn't seem to
think of what to ask for.
Thanks again.
Larry C
