Steve Boetto
Posted: Mon Mar 24, 2008 2:05 pm Post subject: New Firefly |
Been working non stop on a Firefly for Sun n Fun. After about 20 hrs work I just finished the gap seal. Hopr to see everyone there.
Steve B
Firefly 007/Floats
Create a Home Theater Like the Pros. Watch the video on AOL Home.
32.62 KB |
798 Time(s) |
Steve Boetto
Posted: Mon Mar 24, 2008 2:14 pm Post subject: New Firefly |
Photo 2
33.58 KB |
873 Time(s) |
Jim ODay
Joined: 09 Jul 2007 Posts: 61 Location: Fargo North Dakota
Steve Boetto
Posted: Mon Mar 24, 2008 4:37 pm Post subject: New Firefly |
In a message dated 3/24/2008 8:10:03 P.M. Eastern Daylight Time, jimoday(at)hotmail.com writes:
| Quote: | | The only thing I do not like is the Velcro is tenacious in its grip and hard to remove the seal. |
Jim,
I do not use both halves of the Velcro. Only the soft side is used. the gap seal is held front and back with fasteners.
Steve B
Firefly 007/Floats
Jim ODay
Posted: Mon Mar 24, 2008 4:54 pm Post subject: Re: New Firefly |
Steve:
I see how you did that now. Much better than mine!
I think I may have another project to add to my to-do list. Mine is similar to yours but .... not as nicely done.
Thanks for pointing that detail out. I can add some more fasteners to mine, I used fasteners around my engine. The Velcro is a b%#* to separate and I need to slide in a strip of plastic to get the darn thing on/off.
Jim
_________________ Jim O'Day
Fargo, ND
Former Firestar II Builder/Pilot |
Dana
Posted: Mon Mar 24, 2008 6:21 pm Post subject: New Firefly |
At 08:27 PM 3/24/2008, N27SB(at)aol.com wrote:
In a message dated 3/24/2008 8:10:03 P.M. Eastern Daylight Time, jimoday(at)hotmail.com writes: The only thing I do not like is the Velcro is tenacious in its grip and hard to remove the seal.
Jim,
I do not use both halves of the Velcro. Only the soft side is used. the gap seal is held front and back with fasteners. |
What is the Velcro for, then?
My gap seal is held on with Velcro... but it's a soft (clear vinyl) seal so it peels off relatively easy as I roll it up.
-Dana
In the 60's people took acid to make the world weird. Now the world is weird, people take prozac to make it normal. [quote][b]
Steve Boetto
Posted: Tue Mar 25, 2008 3:42 am Post subject: New Firefly |
Dana, It keeps things from chaffing.
In a message dated 3/24/2008 10:22:09 P.M. Eastern Daylight Time, d-m-hague(at)comcast.net writes:
| Quote: | What is the Velcro for, then?
Steve Boetto
Posted: Thu Apr 03, 2008 1:15 pm Post subject: New Firefly |
All, Just completed the new Firefly just in time for Sun n Fun. For those of you that can't go here is a preview.
Planning your summer road trip? Check out AOL Travel Guides.
16.38 KB |
809 Time(s) |
19.47 KB |
733 Time(s) |
21.57 KB |
762 Time(s) |
26.53 KB |
756 Time(s) |
Steve Boetto
Posted: Thu Apr 03, 2008 1:36 pm Post subject: New Firefly |
High res for those with cable
401.04 KB |
798 Time(s) |
ElleryWeld(at)aol.com Guest
Steve Boetto
Posted: Thu Apr 03, 2008 1:56 pm Post subject: New Firefly |
Thanks Ellery, I went for that Ultrastar wide open thing. Looks like it will weigh about 332. That's about 5 or 6 lbs under the UL limit with floats and BRS.
steve
In a message dated 4/3/2008 5:39:15 P.M. Eastern Daylight Time, ElleryWeld(at)aol.com writes:
| Quote: | Steve nice looking light one
Now that's what I call wide open ) & I like the Green paint ,did you leave out the other parts to make it lighter ? what does it weigh in at ?
Ellery in Maine
="http://www.matronics.com/Navigator?Kolb-List">http://www.matronics.com/Navigator?Kolb-List
.matronics.com/">http://forums.matronics.com
://www.matronics.com/contribution">http://www.matronics.com/contribution
Posted: Thu Apr 03, 2008 1:59 pm Post subject: New Firefly |
OK Steve, I'm drooling here. A question for all: what's the current dealas far as putting retractable floats on a MkIII and sport pilot regs?
any loopholes?
BB
(love jumping in warm water)
On 3, Apr 2008, at 5:33 PM, N27SB(at)aol.com (N27SB(at)aol.com) wrote:
[quote] High res for those with cable
Planning your summer road trip? Check out AOL Travel Guides.<newfly.JPG>
knowvne(at)aol.com Guest
Posted: Thu Apr 03, 2008 2:02 pm Post subject: New Firefly |
NIce Bird...
Sure hope you got her in doors before that Gust Front hit you I see in the distance
Mark
16.38 KB |
727 Time(s) |
19.47 KB |
764 Time(s) |
21.57 KB |
706 Time(s) |
26.53 KB |
705 Time(s) |
russ(at)rkiphoto.com Guest
Posted: Thu Apr 03, 2008 2:12 pm Post subject: New Firefly |
WOW, NEAT-O!!!Whose floats?
On Apr 3, 2008, at 5:12 PM, N27SB(at)aol.com (N27SB(at)aol.com) wrote:[quote] All, Just completed the new Firefly just in time for Sun n Fun. For those of you that can't go here is a preview.
<DSC00948.JPG>
<DSC00949.JPG>
<DSC00950.JPG>
<DSC00951.JPG>
Planning your summer road trip? Check out AOL Travel Guides.<DSC00948.JPG><DSC00949.JPG><DSC00950.JPG><DSC00951.JPG>
Steve Boetto
Posted: Thu Apr 03, 2008 2:19 pm Post subject: New Firefly |
BB, The FAA amended the Port Pilot rule to allow retract.
steve
In a message dated 4/3/2008 5:59:49 P.M. Eastern Daylight Time, slyck(at)frontiernet.net writes:
| Quote: | OK Steve, I'm drooling here. A question for all: what's the current deal as far as putting retractable floats on a MkIII and sport pilot regs?
any loopholes?
BB
| Quote: | High res for those with cable
Planning your summer road trip? Check out AOL Travel Guides. <newfly.JPG>
Steve Boetto
Posted: Thu Apr 03, 2008 2:21 pm Post subject: New Firefly |
Mark, Sure did, Hit 5 min after I shot the photo
steve
In a message dated 4/3/2008 6:03:25 P.M. Eastern Daylight Time, knowvne(at)aol.com writes:
NIce Bird...
Mark
16.33 KB |
695 Time(s) |
19.39 KB |
636 Time(s) |
21.5 KB |
614 Time(s) |
26.4 KB |
600 Time(s) |
Steve Boetto
Posted: Thu Apr 03, 2008 2:25 pm Post subject: New Firefly |
Thanks Russ, Those are the same old boats I had on the other Firefly. Can-Zac from Canada failed to supply the new floats on schedual. Oh.BTW I poliched em up a bit
steve
In a message dated 4/3/2008 6:13:35 P.M. Eastern Daylight Time, russ(at)rkiphoto.com writes:
Steve Boetto
Posted: Thu Apr 03, 2008 2:34 pm Post subject: New Firefly |
Sorry, forgot to mention that Bryan Melborn did the Quick-Build and Cover and Paint. Bryan does the best work in the industry
Steve B
Firefly 007/Floats
Don G
Joined: 10 Jan 2006 Posts: 156 Location: Central Illinois
Posted: Thu Apr 03, 2008 3:20 pm Post subject: Re: New Firefly |
Steve,
The new Fly looks great pard!...I am not going to Lakeland this year...but really wish I could just to look at that bird. I wish you the best of luck.
BTW....When Kermit sees it, watch out, he might try to trade you for a PBY or a P-51 or something!...try and get plenty of boot!
_________________ Don G.
Central Illinois
Kitfox IV Speedster
Luscombe 8A
RV9A |
Steve Boetto
Posted: Thu Apr 03, 2008 3:34 pm Post subject: New Firefly |
Thanks Don, bet you like that Speedster but I bet you will always have a Softspot for the F fly
steve
In a message dated 4/3/2008 7:23:46 P.M. Eastern Daylight Time, donghe(at)one-eleven.net writes:
| Quote: | --> Kolb-List message posted by: "Don G" <donghe(at)one-eleven.net>
Steve,
Don G.
Central Illinois
Kitfox IV Speedster
Luscombe 8A
http://www.geocities.com/dagger369th/my_firefly.htm
http://forums.matronics.com/viewtopic.php?p=174675#174675
