Posted: Wed Apr 02, 2008 5:05 pm Post subject: oil mix |
Re: oil mix
Cristal- Which engine do you have?
Bill Sullivan
FS/KX/447
Windsor locks, Ct.
Posted: Wed Apr 02, 2008 5:23 pm Post subject: oil mix |
Cristal- never mind, I found it. Sorry. Does your 503 have oil injection? Again, I don't know about Rotax, but all oil injection systems I've been exposed to worked great. You only have to worry about it if somebody disconnected it, or played with it. As long as it works, there is no pre-mixing like on my 447. Just in case you don't know- you said you did not have papers- you can't use both systems at once. Don't put pre-mixed gas into the tank, and also use the oil injection system. Too much oil that way. I just want to make sure that no mistakes are made.
Someone here can give you tips on checking adjustments, cables, etc., or the Matronics Rotax List.
Bill Sullivan
FS/KX/447
Ct.
cristalclear13
Joined: 19 Sep 2007 Posts: 363 Location: Southeast Georgia
Posted: Thu Apr 03, 2008 4:46 am Post subject: Re: oil mix |
Thanks Bill. No, I don't have oil injection system.
_________________ Cristal Waters
Private Pilot Aug 2008
Rotax 2 stroke maintenance April 2009 |
