knowvne(at)aol.com Guest
Posted: Wed Apr 02, 2008 6:44 pm Post subject: 2 strokes Oil and a Clutch |
Keep in mind that 503s that have oil injection,Â
vary the amount of oil ingested depending on throttle applied at the time.
GaryÂ
QUESTION FOR YA...
What about Long steep dives that Wind Mill the Prop and Raise Motor RPMs ?
In this situation, ARE we destroying the motor because were rapidly cooling theÂ
Motor while depriving it of needed oil due to a retarded throttle setting ???
Isn't this happening with both Oil Injected and Pre Mixed systems???
AND if this is true, Isn't this a good justification for using a Clutch on the Prop??
Mark
50 to 1 may be enough at full throttle,but more than needed at partial throttle.It may not be as critical as we make it An extra ounce in 5 gal doesn't seem too critical.Too much oil builds carbon,thats why oil injection is desirable.The total amount of oil used per 5 gal of gas is less than 50-1.
Dana
Posted: Thu Apr 03, 2008 3:03 am Post subject: 2 strokes Oil and a Clutch |
At 10:40 PM 4/2/2008, knowvne(at)aol.com wrote:
| Quote: | What about Long steep dives that Wind Mill the Prop and Raise Motor RPMs ?
AND if this is true, Isn't this a good justification for using a Clutch on the Prop?? |
It IS a concern (for reasons of lean mixture alone regardless of oil ratio, see the article at http://curedcomposites.netfirms.com/twostroke.html ). However, at ultralight or Kolb speeds, just how much does a reduction driven prop on a 2-stroke prop really windmill?
-Dana
The family that shoots together..... shouldn't be messed with! [quote][b]
gaman(at)att.net Guest
Posted: Thu Apr 03, 2008 4:33 am Post subject: 2 strokes Oil and a Clutch |
Mark,
Possible,but my 503, which idles at 1750rpm to allow slow steep descents, has shown no ill effects in over 550 hrs.The cyl hd and exh temps are both low during steep dives with throttle at idle.Could be that a closed throttle acts like a choke under these conditions.If the throttle is only partially closed, the exh temps really go up.But as soon as I close it completely they come right down.
lucien
Posted: Thu Apr 03, 2008 6:07 am Post subject: Re: 2 strokes Oil and a Clutch |
| knowvne(at)aol.com wrote: | Hmmmm interesting..
So are there advantages disadvantages to using a clutch??
Pros / Cons for Clutch on the Prop
Pros
Safer on the ground,
Less ware on a starter,
Cons
More weight effecting Gross and CG
One more thing that could fail..
Are there others????
Mark
Yes, some cons too but the pros vastly outweigh the cons:
- as for the weight, the overall addition is only about 3lbs, which is pretty minimal
- failure is almost a non-issue, as the rk400 is a very well made, precision unit. It's also surprisingly long wearing.
Other cons:
- engages at 2700 rpm, which may be a perfect taxiing rpm as it was on my old FS II, changes the way you taxi the plane.
- expensive sucker, at about 500 bucks.
- makes a mess at removal of the box, lots of dust that needs to be blwon out.
- windmilling prop adds drag in the air at idle.
Pros:
- eliminates any and all stress on that expensive crankshaft at idle as prop is completely disengaged below 2700 or so.
- vastly easier starting, basically eliminates need for expensive, heavy electric starters. Pulling the rope is just like on your lawn mower or snomobile.
- eliminates the extra spinning of the engine in a low-throttle or idle descent that can be hard on the motor. Pull it back to idle and descend at Vne if you want to, you no longer need to worry about this being hard on the motor (PS, no shock-cooling is not an issue, but shock heating is - that's another thread entirely)
- windmilling prop adds drag in the air at idle, adds an extra feature to your plane, a poor-man's drag brake which can be useful in adjusting a high approach.
- stopped prop at idle is quite a novelty on the flight line....
Personally, I'll never NOT use the clutch again on a 2-stroke/C box combination. The advantages are so much more than the disadvantages; I still have my old clutch and C box here in the apt., just in case I get hold of another 503 powered plane at some point.....
LS
--[/quote]
_________________ LS
Titan II SS |
