Flap Switch
lbgjb10
PostPosted: Wed Apr 02, 2008 1:07 pm    Post subject: Flap Switch Reply with quote
anyone know where to get a flap switch--3 position like some use on the Infinity grip, but for panel mounting. I would like it to have a broader 'toggle' than standard toggle switch so I can tell by feel it is flaps. thanks
Larry and Gayle N104LG
sam(at)fr8dog.net
PostPosted: Wed Apr 02, 2008 1:52 pm    Post subject: Flap Switch Reply with quote
A/C Spruce has the infinity switches.
Larry N104LG
http://forums.matronics.com/viewtopic.php?p=174398#174398
lbgjb10
PostPosted: Wed Apr 02, 2008 3:23 pm    Post subject: Re: Flap Switch Reply with quote
thanks for the reply, but I want a functioning switch 'like' what is on the infinity grip, but for panel mounting not on the grip. AT A/C they had switches for the grip. I would like the 'handle' on the toggle to be flat rather than regular round toggle. lbb
sam(at)fr8dog.net
PostPosted: Wed Apr 02, 2008 4:24 pm    Post subject: Flap Switch Reply with quote
The toggle switch on my infinity grip, that I use for the flaps is a
flat blade type. It could be used anywhere. You just need the correct
part numbers, which I unfortunately don't have at the moment. But I'm
sure someone on the list has them readily at hand.
Larry & Gayle N104LG
http://forums.matronics.com/viewtopic.php?p=174426#174426
John Ackerman
PostPosted: Wed Apr 02, 2008 4:31 pm    Post subject: Flap Switch Reply with quote
Apparently they're pretty hard to come by. You might try one of the A/
C salvage yards, such as Wentworth in the twin cities.
Some folks here have "rolled their own" with appropriate machine
tools. They slipped a "home-made" flap-shaped Al cover on a standard
toggle, and held it in place with a set screw. That's beyond my level!
We put our flap switch inside a cage-like guard and just used a
standard toggle configuration. It's the only guarded switch on the
panel - I think that will work well, and it's protected from
accidental activation in turbulence, for example.
Good luck!
Marlys and John 40458
LarryRosen
PostPosted: Wed Apr 02, 2008 4:32 pm    Post subject: Flap Switch Reply with quote
Avionics Hanger has them for $89.
<http://www.avionicshangar.com/index.asp?PageAction=VIEWPROD&ProdID=85>
Or roll your own. Some photos and instructions from Aeroelectric Bob
http://www.aeroelectric.com/Pictures/Switches/Flap_Switch.jpg
http://www.aeroelectric.com/Pictures/Switches/FLAPS1.JPG
http://www.aeroelectric.com/Pictures/Switches/FLAPS2.JPG
http://www.aeroelectric.com/Pictures/Switches/FLAPS3.JPG
http://www.aeroelectric.com/Pictures/Switches/Toggle_Shaft.jpg
Larry Rosen
Larry &amp; Gayle N104LG
Larry Rosen
#40356
N205EN (reserved)
<http>
jesse(at)saintaviation.co
PostPosted: Wed Apr 02, 2008 4:37 pm    Post subject: Flap Switch Reply with quote
On this subject, does anybody know how much power this switch needs to
handle when wired to the Showplanes FPS? I know the power connects
both to the FPS controller and to the switch, so a switch that is made
for 1A might not be desirable for a circuit with a 10A breaker for the
flaps.
Jesse Saint
Saint Aviation, Inc.
jesse(at)saintaviation.com
Cell: 352-427-0285
Fax: 815-377-3694
Deems Davis
PostPosted: Wed Apr 02, 2008 4:41 pm    Post subject: Flap Switch Reply with quote
t's a bit pricey, but here's a link to Pacific Coast who has a 'paddle'
type flap switch..
http://www.pca.aero/OnlineCatalog/PCA_pg40-41.html
Right side of page 3/4 way down page.
Looks like this installed. (see attached)
Deems Davis # 406
'Its all done....Its just not put together'
http://deemsrv10.com/
 Filesize:  43.56 KB
 Viewed:  592 Time(s)
pitts_pilot(at)bellsouth.
PostPosted: Wed Apr 02, 2008 5:24 pm    Post subject: Flap Switch Reply with quote
I don't know what the postioons are for the infinity grip, so here's
some suggestions.
Make your own 'flap handle' like a flap section, drill a hole in the
hinge side and use some JBWELD to hold it on the switch handle. You can
buy switches with threaded handles too. Google 'electronic parts'
..... jameco mouser allied digikey are all possibilities. You can get
flat handles ..... maybe 1/4" wide but I think you'd rather have
something 1" wide. Also, you want a round one (lollipop) for the gear
switch. Wink
You can also go to http://www.fletchair.com/ and order a flap switch for
a 2-place grumman. It has a center off, momentary (for flaps down .....
you hold it) and the other way is up (not momentary).
Linn
lbb
PostPosted: Wed Apr 02, 2008 5:31 pm    Post subject: Flap Switch Reply with quote
to handle when wired to the Showplanes FPS? I know the power
connects both to the FPS controller and to the switch, so a switch
that is made for 1A might not be desirable for a circuit with a 10A
breaker for the flaps.
Remember that breakers are there to protect the wiring ...... the
devices connected to a 10A breaker may be very small current
consumers. However, this doesn't really answer the question either! Razz
Linn
Jesse Saint
Cell: 352-427-0285
Fax: 815-377-3694
