Posted: Sun Mar 30, 2008 5:28 pm Post subject: Q on sump fit on O- & IO-360's |
Anyone know whether the various sumps for Lyc 360 engines are
interchangeable between the parallel valve & angle valve engines?
I've got a parallel valve engine & a chance to purchase a sump off an
angle valve engine (no p/n supplied for the sump).
Seems unlikely that the original intake tubes would fit, but will they?
If not, are the sumps 'standardized' on inlet tube position so parallel
valve tubes would be available to fit?
gyoung
Joined: 09 Jan 2006 Posts: 211 Location: Republic of Texas
Posted: Sun Mar 30, 2008 10:12 pm Post subject: Q on sump fit on O- & IO-360's |
The bolt pattern for the sumps are the same on parallel 320's, 360's and
angle valve 360's. As you surmised the problem is the intake tubes. The
angle valve sump tubes use an O-ring and insert into the sump. The parallel
sump tubes mate with an external sleeve. The geometry is also different. The
exhaust flange on the parallel cylinders are ~1/4" higher than the angle
valve cylinders requiring at minimum a spacer with extra exhaust gaskets and
possibly longer studs to use the angle valve tubes. There may be other
issues depending on which sump you use. I put a C model sump on my first RV.
It's tubes mount further aft that the A model. I had to cut and re-weld 2 of
the tubes along with using the spacers. The C sump also required an oddball
exhaust and modification to my mount. I would not do it again and don't
recommend it. It's possible a poor fit might have caused an induction leak
and contributed to my accident.
The good news is that you can now buy the proper tubes to use the A model
angle valve sump on a parallel engine. They are not cheap but at least they
are plug-and-play. A friend got his from Aerosport. Last year I bought a
sump with stainless tubes from SuperFlight for about $2600. I don't know if
they sell the tubes separately from the sump. I didn't see it on the
SuperFlight site right now. I think they split their engine business off
under another name. Try this link
www.aeroinstock.com/products/Oil-Sump320%252F360/6160/0/product_cat/index.ht
ml or call SuperFlight.
Greg Young
[quote] --
Posted: Mon Mar 31, 2008 5:08 pm Post subject: Q on sump fit on O- & IO-360's |
Thanks; good info. What did you have to do to your mount, & was your's a
trike or TD? (mine's a TD)
Greg Young
gyoung
Posted: Mon Mar 31, 2008 7:07 pm Post subject: Q on sump fit on O- & IO-360's |
Charlie,
Mine is a -6 taildragger. I've attached a picture that shows the mod that I
had to make on the engine mount. The IO-360-C sump has the intake tubes much
further aft than most of the others and there was virtually no clearance
without the mod. If you compare your sump to the picture the difference is
very apparent. The C sump is also magnesium. The IO-360-A1A sump is the most
common forward facing. That's what I got from AERO/Superflight. It gives you
the equivalent of the IO-360-M1B forward facing parallel engine and you can
use exhausts made for it. I got the 4 into 1 from Aerospace Welding. I
haven't fit it to the engine yet but it is beautifully built.
http://www.awi-ami.com/4%20into%201%20exhaust.htm
Greg Young
[quote] --
121.58 KB |
325 Time(s) |
